Question about Crunch BLX1000D Car Audio Amplifier
I was wondering
How much does a blackmaxx blx1000d amplifier go for?
I own 4boxers.org and that amp is no longer available.
Randi
http://www.boxers.org
Posted on Nov 05, 2007
    Problem Solver:
  • 6 Answers
The cost for a blackmaxx blx1000d amplifier can be obtained at a cost of US$281.00 at www.4boxers.org
Posted on Aug 07, 2007
SOURCE:
Does crunch blackmaxx take aux for iPhone?
The amp is a discontinued model, but I do think I found the specs on it. It will produce :
350 Watts X2 @ 4 ohms
700 Watts X2 @ 2 ohms
1,400 Watts X1 @ Bridged at 4 ohms
It is designed to be ran inline between your stereo and a set of, or a single, sub woofer.
This could be a significant amount of work for a beginner in car audio, but it can be done.
I would do a little research and decide if you want to use this amp. Join in on forums like http://www.caraudio.com/forums/forum.php, and http://mobileaudioforum.com/forum/forum.php to learn what can be done, and how to do it. good luck.
Jan 19, 2014 | Crunch Car Audio & Video
What size fuse goes in the 2 side ports
The amp delivers from the factory with 2 40amp fuses.
Mar 28, 2011 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
I have a DA 1200.5 5 channel amp. It stopped
diconnect all your speakers from the amp and see if the light turns green. if it does, reconnect one speaker at a time to find out what speaker is making the amp go into protect mode
Feb 24, 2010 | Crunch BlackMaxx BLX2000D Car Audio...
Help me sir
here go to this site u can thank me later by rateing me if u could just copy and paste the link
http://www.maxxsonics.net/manuals/crunch/pdfs/crBM_BLX280-2250_1-2000D.pdf
Jul 15, 2008 | Crunch BLX1000D Car Audio Amplifier
Need help (autotek mx1300)
find the input gain controls, theyre usually recessed into little holes, so you have to stick a small regular screwdriver into each of the holes to turn up both the left and right gain controls.
May 15, 2008 | Crunch BlackMaxx BLX2000D Car Audio...
SOUND CUTS ON AND OFF WHILE PLAYING
You may have solved your own problem. If you can tap the unit and have it work that is a sign of a loose connection. I would suggest if you have electronics background you check the circuit for a cold solder joint. Then use a soldering iron to go over the joint. Better still hear up the joint and use a desoldering device remove the old solder and then a soldering iron to apply new solder. This should do the trick it a cold solder joint is indeed your problem.
Sep 03, 2007 | Crunch BLX1000D Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Amplifier stop working
this problemis your amp is dead powerflux you need the asistance techinic
May 27, 2007 | Crunch BlackMaxx BLX2000D Car Audio...
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Crunch BLX1000D Car Audio Amplifier Logo
62 people viewed this question
Top Crunch Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Dalynn Turner
matthew walsh
Level 1 Expert
Are you a Crunch Car Audio and Video Expert? Answer questions, earn points and help others
