Manual for lioness h4 - Audio Players & Recorders
L have a sharp printer model arm 450 problm h4:02
Good morning .
There is no H4-02 in the manual .
All H4-xx codes are fuser related so be careful .
It could be a paper jam round the fuser or a worn thermistor etc.
Jun 14, 2016 | Sharp Office Equipment & Supplies
Nescafe lioness coffee machine manual
Machine is manufactured by Rhea Vendors. Here is a link to a manual http://belsotech.com/data/downloads/XS_FLASH_INSTANT_GB.pdf
Sep 12, 2011 | Vacuums
I have a h4 recorder and when i turn it on i get a no card reading .changed card still same message
Are you using the type of card recommended in the manual? There's also an update here that you might like to have:http://www.zoom.co.jp/english/download/software/h4.php
Sep 11, 2009 | Zoom H4 Handy Recorder
Is there any way to reset the H4 back to factory settings? I adjusted levels and everythings out of whack now.
Hello.
Do you havce the manual to the H4? If not, I will provide you with a link to the PDF manual online. In thoroughly scanning thfe manual, there is no general reset function (in the manual, that is). It would be advised to call Zoom (who are very easy to work with) and ask them if there is a factory reset procedure which is not in the manual.
The manual for the H4 is very comprehensive, and there are default settings for many areas of the recorder. You could use this manual to reset your adjustments manually.
Here is the link to the manual:
http://www.samsontech.com/products/relatedDocs/H4_manual.pdf
Thanks for using FixYa
Aug 15, 2009 | Zoom H4 Handy Recorder
Title: Zoom H4 / Mac USB Problem
Upgrade firm ware from Zoom website
You will need an external SD card reader.
Good Luck
Mar 07, 2009 | Zoom H4 Handy Recorder
SHARP AL-1216: HOW TO REMOVE H4 ERROR CODE
www.tinli.com.hk/PDF/AL1216.pdf
Hope this helps.
paul
Nov 01, 2008 | Office Equipment & Supplies
Cannot connect to PC
Do you have an SD slot in your mac? plug the sd card there and see if it works. Erase manually the files (leave the system files) and try again with the H4. Luck
Sep 12, 2008 | Zoom H4 Handy Recorder
49 people viewed this question
 Grubhead
Grubhead
