Question about Vacuums
Armature 220v to fit kirby vacuum cleaner - Vacuums
  • 112 Answers
SOURCE: fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Posted on Jan 14, 2008
  • 112 Answers
SOURCE: Help on kirby G4D
here is a link to taking the fan off of the kirby...all the Generation Series Kirbys are the same :)
Hope that helps!!!
Posted on Apr 08, 2008
  • 231 Answers
SOURCE: Our Kirby g6 vacuum cleaner will not turn on and
you probably have a bad switch. let me know if you want me to walk you through replacing it
Posted on Jan 03, 2010
VacuumRepair
  • 438 Answers
SOURCE: how do I replace the drive belt on a Kirby G5
Greetings,
I have shot an excellent video repair on how to replace the belt on Kirby Generation Vacuum Cleaners including your Generation 5 (G5). The belt change procedure is the same for Kirby Models G3-G10 Sentria. The video is below in an easy to follow, and understand video. Feel free to use the pause controls to pause the movie as you're fixing the belt on your Kirby.
I hope this video was able to teach you the exact process of how the Kirby belt has to be installed in order for it to work properly. Please, if you have any questions just request a clarification of the repair and I'll be more then happy to help you further, I'm always happy to answer any questions. If you found this video helpful, please kindly rate this repair solution as helpful also. I really do appreciate it, thank you.
Thanks for watching!
Chris J
Posted on Mar 21, 2010
VacuumRepair
  • 438 Answers
SOURCE: How do you attach the belt for the roller-brush on
Greetings,
Please see the attached video on how to replace the belt on a Kirby Generation Vacuum Cleaner. This is an easy to follow step by step direction on the proper way to replace the belt, as well as do basic maintenance on your Kirby's roller brush which will prolong the life of your belt greatly if done regularly. I you find this video to be helpful, please be kind and rate it well by clicking the thumbs up icon below.
Feel free to request a repair clarification if you have any quesitons on how to replace the belt on your Kirby.
How to Replace the Belt on a Kirby Generation 3 (G3) Vacuum Cleaner:
Chris J.
How to remove a Kirby Heritage II Armature
The armature that holds the fan on is reverse threaded. It turns to the right to remove it. You can put a nail or nail punch in the hole on the armature and tap it gently to the right. this should loosen it enough to unscrew. There's a washer, then the fan, and a spacer that fit over the shaft.
Sep 02, 2012 | Kirby Heritage II Vacuum
Kirby armature replace
phone your local kirby engineir for this
Jul 31, 2012 | Kirby G6 Bagged Upright Vacuum
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
My Kirby vacuum cleaner will only run for a few
could be caused by bad bearings in the motor or bad carbon brushes and a worn commotator on the armature. check the cord where it connects to the top of the handle on the swivelling strain relief. usually the cord fails there .
Jan 03, 2010 | Vacuums
Kirby Heritage II Vacuum Carbon Brush Placement
yes the carbon brushes float on the commutator and are spring loaded. the spring washer goes in the housing first then the other washer. let me know if you have any other questions
Jan 14, 2009 | Kirby Heritage II Vacuum
Sparks from the Kirby Motor
1. Do you think this may be the problem?
YES
2. How come it continues to rotate?
Motor armature consists of multiple coils and just some of them burned so even though it keeps spinning it does not function properly.
3. Do I need to replace the armature?
We have switch replacement instructions HERE and they will take you as far as accessing the motor. We do not have motor assembly instructions yet but if you get that far - motor is not that hard to reassemble. You may have to spend some time getting tolerance ring back in and make sure you install finger spring properly.
Good Luck
Dec 28, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Replacing the fan hub on a kirby classic omega 1CB
I resolved the problem .I found a way to hold the armature shaft still while I unscrewed the pulley drive nut ,which must be removed in order to remove the vacuum fan.
> There probably is a special tool somewhere that would fit over the armature ( the metal part that spins on the shaft of the motor inside the stature) to hold it still ,but since it was suspiciously omitted from the rest of the fan blade parts ,I had to fabricate one myself.
>I happen to have three ,steel blade ,broad paint scrappers which were about 2 to 3 inches wide and thin enough so there blades fitted nicely into the groves that run the length of the armature without damaging it, as would be the case with a narrower screw driver blade .
>Bracing the handles of the 3 scrapper blades in a slot that was in the side of the case ,which was probaby its' intented purpose, held the armature shaft still while I unscrewed the fan nut which happened to have a reverse thread.( turns clockwise to loosen) .
>It unscrewed with ease. Problem solved!
Aug 30, 2008 | Kirby Heritage II Vacuum
Kirby making clicking noise
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=667246
Generic problem for all Vacuums
Posted by jenad on Jun 12, 2008
In the middle of vacuuming my car out, my Kirby Sentria began making a loud clicking noise, sounds like it's coming from the motor. It's never done this before. I checked for debris in the fan and removed the bag and checked there too. The vacuum still works, just not sure if I should continue to use it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The clicking noise sound s to me that it is coming from the motor like you said and I am not sure how new the Kirby vacuum is, but if it is still under a factory warranty it is a good idea to have Kirby take a look @ the vacuum because it could be the fan, carbon brushes or something could be hitting the armature making a clicking sound and if it is the armature then I would get it check ASAP. Feel free to contact your local factory authorized Kirby dealer in your area and also I will give you the website and the customer service phone # to Kirby for further assistance. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 12, 2008 | Vacuums
110-220V
You may have burnt up the motor field when it was plugged into a 220V power source. But there are drop down transformers you can get to reduce the voltage form 210 to 110. AS Radio Shack or similar store would have them.
Jan 05, 2008 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
