Question about HP LaserJet M1522n MultiFunction Printer
[HP LJ M1522n] Formater board (CC368-60001)
My formater board (CC368-60001) broke down. I could not find such a use, so I bought from M1522nf (CC386-60001) with fax module. But I read on a forum that will not work. Is this true? : ( If so, what does it take to work?
POCBM
  • 121 Answers
SOURCE: Printed confirmation on faxes sent form HP Laser Jet Fax M1522nf
To get confirmation page do this:
1. On the control panel, press Setup ( ).
2. Use the arrow buttons to select Reports, and then press OK.
3. Use the arrow buttons to select Fax Reports, and then press OK.
4. Use the arrow buttons to select Fax Confirmation, and then press OK.
5. Use the arrow buttons to select the option for when you want the fax error reports to be printed.
6. Press OK to save the selection.
To iclude first page with report:
4. Use the arrow buttons to select Include 1st page, and then press OK.
5. Use the arrow buttons to select On, and then press OK to confirm the selection.
Posted on Mar 25, 2009
SOURCE: Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Posted on Jun 02, 2009
SOURCE: HP M1522NF: KEEP RECEIVING A LOW MEMORY MESSAGE
KEEP RECEIVING A LOW MEMORY MESSAGE WITH AN INCOMING FAX??
Posted on Jun 03, 2010
  • 223 Answers
SOURCE: Not receiving any Fax, only can send out Fax.
Hi Mechanic.
The problem could be with your phone service if you are on digital lines, you would have to install a digital to analog filter. If you are analog the comm errors are typical of a line with a lot of static. You can change two settings on the printer which should solve the issue until you install a filter.
The two settings which are under the fax set up menu/ all faxes\
Error correction mode (ECM) set it to off
Fax Speed set it to medium.
Good luck
Al
Eliteprintersolutions@gmail.com
Posted on Jul 15, 2010
printerman40
  • 170 Answers
SOURCE: My M2727nf is not not initilizing and is out of warranty
1. Remove the left cover.
2. Disconnect five connectors (callout 1; GND wire lug, J36, J2, J32, J34) and five FFCs (callout 2;
J4, J27, J28, J31, J26).
Remove the formatter (1 of 5)1
132 Chapter 5 Removal and replacement ENWW
3. Remove six screws (callout 3), and then separate the formatter from the product.
Remove the formatter (2 of 5)
CAUTION: Make sure that you install the protective sheet behind the formatter when you reinstall
it. Failure to install the protective sheet might cause a short circuit and damage the formatter.
4. For products that use an Asian character control panel only
: use a pair of needle nose pliers
to release the Asian-character control-panel-display PCA spacer from the formatter.
5. For products that use an Asian character control panel only: remove the Asian-character
control-panel-display PCA from the formatter. Install the PCA on the replacement formatter
(connector H3).
Here's where you can get your formatter... Click Here!!
Hope this heps and if so Please mark this a FixYa!!
Posted on Jul 19, 2010
Testimonial: "Thanks for your help!!"
49 err 6400444 tune off then on
there is problem with formater board first try to update firmware may be solve yours problem if not just change formater bord and enjoy
Jul 15, 2014 | HP P2055DN LaserJet Monochrome Printer
HP LaserJet M1522nf error # 5
go to www8.hp.com and get the support via ONLINE chat free for fix
it the error # 5.
God bless you
Jul 26, 2013 | HP LaserJet M1522n MultiFunction Printer
Error 49 is showing in the Printer Screen, it is automatically getting switched on and off in close intervals and not functioning. Printer Model is HP LaserJet M1522nf.
49 Error, Turn off then on
The product has experienced an internal embedded software error.
Turn off the power by using the power switch,
wait at least 30 seconds, and then turn on the
power and wait for the product to initialize.
If the error persists, contact HP. See
www.hp.com/support/ljm1522 or the support
flyer that came in the product box.
Jul 11, 2011 | HP LaserJet M1522n MultiFunction Printer
Printer m1522n ,the scanner does not stop moving,then eventually comes with error 5
Check my tips section. This error is covered by HP for almost all machines. It is a known issue and the repair cost is covered entirely by HP.
Apr 27, 2011 | HP LaserJet M1522nf Multifunction Printer...
Tengo una impresora de Modelo Hp LaserJet M1522n MFP presenta el siguiente mensaje de error. Error de memoria consum: 10.1000 pareciera ser por que el cartucho no es original, pero lo he comprado con...
It is possible. The message is caused because the printer cannot read the little chip that is on the cartridge. Usually replace the toner will fix the issue (specially if its not hp). In your case it might be the reader that is not working. Try taking the cartridge and paper out. Then reset the printer by turning it off and press and hold the down arrow and cancel. Then turn it on and wait for the message ''permanent storage init'' then release the keys and will get back to ready.
Aug 30, 2010 | HP LaserJet M1522nf Multifunction Printer...
Cant set up my hp m1522nf scanner to my pc
install full software, download from www.hp.com
Aug 06, 2010 | HP LaserJet M1522n MultiFunction Printer
Hp M1522nf
this is a common problem the main board is faulty
Feb 19, 2010 | HP LaserJet M1522nf Multifunction Printer...
My HP Laserjet M1522n will only scan one page. How can I scan a multi-page document?
Call hp tech support, you need to uninstalla dn reinstall the software. You may have to replace a dll file.
Al
Nov 30, 2009 | HP LaserJet M1522nf Multifunction Printer...
Counter reset
only way is to replace the printer....or the mother board...take your pick
Apr 17, 2009 | HP LaserJet M1522n MultiFunction Printer
HP LaserJet M1522n MultiFunction Printer Logo
Seeker5211
Seeker5211
