Question about Microwave Ovens
Microwave joe boxer
The door no longer stays close
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave door
It sounds like the mount which holds tension on your door latch heads (door hooks) is broken. You can confirm that by pushing up on the door hook. If it goes up with no real resistance, the spring is unhooked. Fixing that would require disassembly of the door (by separating the panels) and repairing or replacing either the door hook assembly or the door panel inside.
Posted on Nov 01, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Door Won't Close
What usually breaks is the door open lever, but sometimes there's just a grease buildup around the door open button.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If it's a Sharp or Kenmore, you can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you still have trouble, please reply back with your model number so we can help you.
Posted on Sep 26, 2008
  • 93 Answers
SOURCE: I just changed the buld
there is normally 2 swicth in the door actuater one may be def or sticking check them out
Posted on Mar 15, 2009
SOURCE: Loose microwave door
My over the range microwave had a loose door, it sagged when it was open but you could lift it to close. Called repair person he said no it could not be fixed. You could see the bottom hinge was loose and slipping. I loosened 3 screws that holds the bottom on the microwave -you have to do this to change the light bulb also. The bottom hinge on the door was loose there was a hole there, so took a screw and nut to hold the hinge in place..I am a 70+year old woman-if I can you can.
Posted on Aug 19, 2010
Panasoni microwave NN-H965WF fan stays on when door closed
Because Panasonic use an inverter system to generate microwave energy the machine has to cool itself down at a steady rate and this is generally the reason the fan stays on when the door is closed,hope this helps
Mar 04, 2015 | Microwave Ovens
My microwave door wont stay close , how do i fix ?
Hey Abraham Acevedo, thank you for the post!
From my understanding the door on your Frigidaire microwave, PLMV168, is not staying closed. You could be seeing an issue with either your door latch or latch assembly within the microwave. Since these components require patience and precision to replace or remove from your appliance, I always suggest seeking professional assistance. One must be very careful handling these replacement parts as they can lead to potential harm. -Matt
Jul 30, 2014 | Frigidaire PLMV168 Microwave Oven
Microwave door wont stay closed
replace the door hooks and door release button.
if this is broken the switch will not close very well, and NOT start the microwave.
God bless you
Jul 19, 2012 | Samsung SMH9187 Microwave Oven
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
Mine is a similar problem - light and fan BOTH stay on when the cooking/heating finishes! The door remains closed and the food/beverage cooks. However, when it's finished the light remains on and the
There are a number of interlock switches that the oven door activates when closed, sometimes one becomes defective causing the main fuse to blow in the microwave or continue to run when time is up.
Nov 11, 2011 | Microwave Ovens
Closing the door on my microwave no longer activates the Start. It seems like the door won't close tight.
youll need to replace the latch on the door. you can buy the parts and do this yourself or you can hire a repairman.
Feb 11, 2011 | Dacor DMT2420 1200 Watts Microwave Oven
Interior light always on Ge advantium 120
I bet by now your microwave is no longer working....did the bottom or top "hook" finally break off? I found that mine had cracked and started coming loose and so when it closed it was no placing enough pressure on the internal safety switch that tells the oven the door is shut. I was able to use a sturdy plastic glue to solve the problem but finally after about 2 years of fixing it I can no longer get it to bond. Now, I'm looking for a new part. Who makes a product this expensive with plastic parts!!?!??!?!? So frustrating.
Apr 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Door does not stay fully closed
This could be due to a faulty door interlock but in most microwave ovens I have seen the light remains on during the cooking process.
May 18, 2017 | Microwave Ovens
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
