Question about Samsung SF760P SF-760P Multifunction Laser Printer, Copy/Fax/Print/Scan SASSF760P SAS SF760P
How to sovle samsung sf760p paper feed problem
Received today fax comes in but paper does not feed from bottom tray
  • 4 Answers
SOURCE: paper feed
Is your paper right in slot with grey flap over top of paper feeding into slot.
Posted on Nov 04, 2008
Lidi
SOURCE: Samsung sf-5100 Fax machine - no paper
I want to see driver for my fax
Posted on Mar 12, 2008
checkitright
  • 1362 Answers
SOURCE: Paper will not feed through - Samsung SF-4500c FAX
try isopropyl alcohol it may work for awhile depending on how smooth the tires are, you can replace them:
try this site
precisionroller.com
Posted on Aug 12, 2008
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
  • 220 Answers
SOURCE: Printer attempts to grab/ feed paper from tray
pickup roller worned.
Posted on Jun 26, 2009
I have a Lexmark X364DN and would like to change the default paper tray for incoming faxes.
1- Go to Fax Settings menu
2- Under Fax settings menu, look for Fax Receive Settings
3- Under Fax Fax Receive Settings, look for Paper Source
4- Under Paper Source You should find three options: Auto (default), tray <x> (the tray number you want it to print from), or manual feed.
Change according to your preference.
Hope it helps!
Jun 21, 2011 | Lexmark X364dn All-In-One Laser Printer
I bought a MFC4770 in May 2010 adn it works well till now. But yesterday, paper jams,then I fixed it. Today even there are lot of paper in the bottom,it always say no paper,but I can feed paper one...
When the paper tray is removed, you should see a plastic piece that dangles, this piece rises and falls depending on the amount of paper in the tray. However, if that plastic piece gets bumped or comes out of its housing, it will sense that there is no paper in the tray. I suggest you look for this piece and ensure that when you manually press it up and release, it falls back down to its original position, if not, you will need to correctly seat it.
-David.
Nov 02, 2010 | Office Equipment & Supplies
Fax output error
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes sucessfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Mar 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
A friend gave me this fax machiene. On the screen it sais "out of paper" when there is clearly a lot of paper in the bottom tray. However it is missing the top paper tray but has the lower tray. Could
Make sure you have a receiving tray. You can live without your sending tray. If you have the receiving tray and it says TRAY OFF thats because its not seated properly onto the frame. Make sure the tray engages the black sensor next to the speaker, also make sure you have paper in both trays to get rid of the OUT OF PAPER error. If the OUT OF PAPER error continues then you have a broken sensor in the upper tray.
May 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
The copy/receiving function will not work.
hi,clean feed roll if the feed roll out of use please replace it.
May 14, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Fax double feeds sheets
This may occur if:
-the paper is too thick or too thin
-the roller mechanism is not properly aligned or has worn out
-the sheets of paper stick together
things you can try:
-unload the paper in the main tray and bend the stack of paper to loosen it up. Reload the paper to the main tray
Hope this helps!
Feb 17, 2009 | HP 1240 Plain Paper Inkjet Fax
Canon b640 problem
By cleaning the feed rollers you the fax will feed beter.Remove the dockfeeder and the paper tray.you will find the feed rollers in the bottom of the paper tray.Take a cloth and a stong soap selution and clean the 2 feed rubbers.
Jan 06, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Ricoh 3900 L Fax Machine - Bottom Catch Trays (for receiving faxes)
Here the numbers.
H545 2130 Copy Tray 1
H545 2131 Copy Tray Extension
Apr 30, 2008 | Ricoh FAX3900L Plain Paper Laser
Canon 710i
Can you look into the paper tray and actually see if the feed rolls are turning? You may have either a bad paper feed clutch, or the solonoid that releases the feed rollers is bad.
Also the paper tray should move up and down when the paper feeds to move the paper against the rollers. Up to feed down to eliminate paper drag. One of those fingers that raise the tray may be binding against the bottom of the tray not allowing proper movement.
If you can get a flash light and observe what is going on. Then let me know.
Mar 21, 2008 | Canon FAX-L1000 Plain Paper Laser
Paper Coming from wrong tray for incoming faxes
press setup on printer select preferences and select default tray as 2 and try making copy and also check while receiving fax and also follow this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01096354&cc=us&lc=en&dlc=en&product=1119598&dlc=en&lang=en
Oct 01, 2007 | HP Officejet Pro L7780 All-In-One InkJet...
Samsung SF760P SF-760P Multifunction Laser Printer, Copy/Fax/Print/Scan SASSF760P SAS SF760P Logo
62 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
