Question about Samsung SCH-a870 Cellular Phone
Front display the phone was droped, & know the external display is very pale looking, i have to hold the phone in an angle to view.
  • 27 Answers
Its simple chanhge display streep or chsnge display(lcd)
Posted on Aug 11, 2007
  • Anonymous Aug 11, 2007
    chck canection bitween display and main board
    cleen cunector it will ok
SOURCE:
How do I adjust contrast?
There are Function Keys to do this.
from Troubleshooting section. Keyboard (if contrast and brightness function key)
http://tim.id.au/laptops/acer/aspire%203680%205570%205580.pdf
and Page 10 of the manual
Display Keep your display clean. • Keep your head at a higher level than the top edge of the display so your • eyes point downward when looking at the middle of the display. Adjust the display brightness and/or contrast to a comfortable level for • enhanced text readability and graphics clarity. Eliminate glare and reflections by: • placing your display in such a way that the side faces the window or • any light source minimizing room light by using drapes, shades or blinds • using a task light • changing the display's viewing angle • using a glare-reduction filter • using a display visor, such as a piece of cardboard extended from the • display's top front edge Avoid adjusting your display to an awkward viewing angle. • Avoid looking at bright light sources, such as open windows, for extended • periods of time.
http://www.manualslib.com/manual/205261/Acer-Aspire-3680.html?page=10&term=contrast
Dec 27, 2015 | Acer Aspire 3680 Laptop
Vaio LCD problem
Periods.......Nice little items because they denote the End of a sentence.
See how this works?
"I have a vgn cs36gj, I was working with it, suddenly the LCD became pale black, I connected it to external monitor and it has a picture, sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
Now you try it.........
"I have a vgn cs36gj. I was working with it, suddenly the LCD became pale black.
I connected it to external monitor and it has a picture."
Okay, I got that part.........
"sometimes after turning on for 30 minutes LCD start working normally, but after turning off and disconnecting power when I turn it on, it only shows a pale black picture, you know it is on but only black!"
WHICH LCD?
Laptop LCD?
External monitor LCD?
Man on the moon LCD?
1) If the external monitor LCD goes 'pale black', the problem is the graphics chipset.
This I do not believe
2) If the laptop LCD goes pale black, this I believe.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
Someone asked me to take photos with my Nikon D90. I have the 18-105mm lens that I got with it. Is this able to take 'wide angle' photos?? I know there are special lenses made specifically for wide...
The 18-105mm lens at the 18mm end of the zoom range is a pretty fair wide-angle lens. Look through the viewfinder and turn the zoom ring (the big wide ring at the front of the lens) one way and then the other. The 105mm end is the view that looks like you're using binoculars, the 18mm end is the view that looks like you're using binoculars backward.
Oct 28, 2010 | Nikon D90 Digital Camera with 18-105mm...
My screen is pale and when i press parts of the phone it turns back to the right resolution but it wont do that anymore.
It seems the phone fell from you or you hit the phone surface with a hard surface for your screen to be malfunctioning because it is possible that the screen is not firmed to the panel any longer and you will need to affirm it.
Get a torx6 screw driver.
First thing you need to do is to power off your, remove the baattery, and sim card, Turn the phone over and gently remove the front cover.
After you have pull off the front cover, you can go on with the torx6 screw driver to tighten all the screws that hold the screen of your phone to its panel very well and recouple the front cover back.
Put your sim card and battery to power on, with this it should stop the pale screen.
Take care.
Apr 30, 2010 | Cell Phones
The display screen does not sit any viewing angle.
More than likely both hinges are broken (the screen pivots to the hinges). Nothing to do but to replace both L and R hinges.
Dec 24, 2009 | Toshiba (SD-R2412) for Satellite A10, A15,...
Lg view cu 920
check in the back of the phone and look for a sticker and the color your looking for is ether red or white. If you see it and if its red then the phone has been water damaged and thats the cause of its reaction but if its white then the phone has either been droped or something like that which means that the board was either damaged or it just simply lost its programing. Think of it as like when a computer crashes.
Jun 15, 2009 | LG Vu CU920 Cellular Phone
I have a radio shack weather alert pro 82
Tilt the scanner in a different direction while looking at the display. Do you see anything on the display when you look at it from a different angle? Sometimes manufacturers don't put the LCD display in correctly, and because LCD's have a really small viewing angle it can result in not seeing what is displayed.
Oct 19, 2008 | Radio Shack Pro-82 Scanner
Front display not working
have the lcd replaced , take it to a mobile service center and have them replace it for you.
Nov 12, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Motorola razr display
I can understand this trouble, So You pliz visit service centre of motorola, ur handset is in warranty period, they will repaire it for u.
Oct 23, 2007 | Motorola Mobility RAZR V3
Samsung SCH-a870 Cellular Phone Logo
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
