Question about Garmin StreetPilot i5 GPS Receiver
UPDATE TROUBLE I put in my Garmin Map Update into my disc drive and nothing happens. I put game dvd in and my player works ok. How can I tell if my map update is damaged? Or how to get it to work. John
  • 944 Answers
First thing to try is to stick the disc into a PC. It will either read no disc, or ignore that there is a disc there; or it may load the disc fine and either autorun or come up with a "what action do you want to take/disc format not recognised" type of message. If a PC will not read the disc, first check it visually for scratches - in particular near the centre, and especially if the scratch is going around the disc not across it. If nothing big visible, then try cleaning the disc with a soft damp cloth, a little water and some detergent - if you have to rub, go from the centre outwards not round and round. Try the disc again in your Garmin. If this doesn't work, check the foil side of the disc for damage - look real close. If there is any, then there are not many ways to fix it that are often successful or that will last for long. next to see is if you can polish any scratches out. Use a fine abrasive polish like Brasso with a soft cloth (not on the foil side). Start with the worst looking scratch, see if it will soften or polish out. Try the disc, then keep polishing each scratch in turn to see if you can get it working. You can buy little machines that do similar by polishing the whole disc, but they are normally more agressive than you need if scratches are the problem. If still no luck, then try Garmin for a replacement CD; http://www.garmin.com/garmin/cms/site/us/supportcontacts sorry I couldn't find any details on their site now (it's a huge site), but they used to replace damaged discs so long as you paid the postage and sent them a damaged legal copy first. Possibly now they do the same by download - check with them for a quick answer - their service is normally good. Please ask again if you need more info. Hope this helps :)
Posted on Aug 08, 2007
SOURCE:
Panasonic dvd recorder DMR-E55GN
with ( MyDriveConnect ) the system make the update and ask you to chosse with coponent you want to remouve ! after you update you select the part of the map you want , the new thing you don't have the complete map only 3/4 of the map , the say with all new town and road the gps dont have not enough memory to have the complete map of the canada /usa and mexico after the update you select the part of the map you want , and now the memory of the gps is half full , and now you have space to add : voice , image , and other things
Jul 22, 2014 | Panasonic DMR-E55 DVD Recorder
I bought a refurbished Garmin 660 and the screen comes up to needing a map update and won't go any further. I am charging but have no idea how long that will take. Tried to downlaod a map update using a...
The unit should still operate even though the map is old. If you press the OK button and nothing happens, most likely the touchscreen is bad and needs to be replaced. An old map should not stop you from using the device.
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Apr 22, 2011 | Garmin Nuvi 660 GPS Receiver
Having a problem with windows media player. I put in a cd and try to get it to rip and it comes back and tells me to put in a disc. I put a disc in to play and it tells me to put in a disc. It is like it...
Does it only happen in Windows media player? If it does try gettting the updated version of media player. if it happens in other applications try changing the dics. If that doesnt work, you need to delete the lower and upper filters in the registry *Note* if you are not really comfortable in doing that then dont, Wrong move in the registry can mess up the operating system, here is the link how to delete the lower and upper filters
http://support.microsoft.com/kb/314060
if these doesnt work uninstall then reinstall the driver for the optical drive..
try also getting an update from your computer manufacturer. update for the optical drive, or BIOS
lastly, try reinstalling the operating system, if these doesnt work change the optical drive because its a hardware issue..
Mar 07, 2010 | Computers & Internet
HLDT GSAH 55N DVD Drive won't read PC Game DVDs
I would suggest contacting the drive manufacture's website to see if they have a firmware update for that drive.
If this is a OEM drive I would contact the computer manufacture that drive came with to see if they have a firmware update.
Sep 16, 2009 | Computers & Internet
Can't install 2010 map update
Try using Mozilla Firefox to download the file that way it resides in DOWNLOADS,
create a folder called update and extract the file to there. then run updater
Jul 06, 2009 | GPS
Map update notice screen
HOLD THE ON OFF SWITCH DOWN AND youPRESS RESET This should reset it back for t
Jun 20, 2009 | Garmin StreetPilot C330 GPS Receiver
My sharp blue ray dvd player wont read the discs right...i put the disc in and it play all the commercials but it gets to the movie menu and it freezes...can you help me figure out the problem!!!
anyone having problem sharp aquos bluray reading disc just call 1-800-be-sharp to update your player you will need a computer and a usb 2.0 drive , so you can load update from computer to drive then pull drive from computer to the back of player load load it to player , they tell you all you need to know
Jan 07, 2009 | Sharp AQUOS Blu-ray Disc Player
Panasonic DMR-E80H Change Disc Error
If you haven't done so, try downloading the firmware update from their support site. Burn the update file to a cd-rom.
I have had numerous times where my unit recovered and I had to format the hard drive(losing all of my shows), but since I did the update this has not happened to me again.
Nov 26, 2007 | Panasonic DMR-E80H DVD Recorder
Garmin StreetPilot i5 GPS Receiver Logo
73 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
