Question about Emerson SpongeBob SquarePants TV
Spongebob tv SB314 no picture or sound
My chidrens spongebob tv got some water spilled on it, it is no longer working. There is no picture or sound. I let it dry, and tried to turn it on. It doesn't do anything.then when I tried to turn it off, there was a static sound that went in and out. I then tried to turn it back on, then nothing again. Turned it back off, then the static sound went in and out again, then the TV turned itself on again, then would not shut off. I was wondering if I should get it repaired or if it is now junk? Or if ther is anything I can do myself to repair this problem. Thank you Sara, IN.
    Scholar:
  • 133 Answers
It's very likely junk and would cost far more to repair with labour than to buy a new one. Sorry to be the bearer of bad news.
Posted on Sep 07, 2007
SOURCE:
I spilled some water on my tv and now the sound is broken
Turn the TV off imediately. Remove the back cover and heat up the wet area with an hair dryer to thoroughly dry the board. Then try tv again.If it doesnt solve the problem look for the board that the speaker wires connect to and replace that board..You should be able to buy online.
Oct 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Green picture on my spongebob tv
check the RGB section resolder or replace the RGB ic transistor
Jun 07, 2009 | Emerson SpongeBob SquarePants TV
13" spongebob Television
Hi Shelly,
It sounds to me like makebe the horizontal output trasnistor is out. This is somethign that will need to be repaired by a technictian. If you are going to change this part yourself ( assuming for sure that is the problem ) always be very careful when opening the back of the TV. Always unplug it first, then discharge the picture tube as there could be as much as 30,000 volts of energy stored in it. The horizontal transistor is the biggest, black, nearly square transistor that is located next to the trasformer that has the large red wire going to the picture tube. You will need to solder it in. I do suggest you do have a qualified technitian do the job since there is some danger in working in the tv set.
I hope this has helped in some way.
Ed
Radio Man
NC Electronics
Mills, Wyoming
Jul 17, 2008 | Emerson SpongeBob SquarePants TV
Emerson Spongbob tv broken remote
go right now to : www.ebay.com , they have about 3 remotes available for you . hope this helps . please rate this solution thanks
Apr 23, 2008 | Emerson SpongeBob SquarePants TV
Spongebob dvd player is not playing on Spongebob sb 314 tv
You need a TV with an A/V input option. I believe your set does not have this option.
You can look at getting an A/V modulator. Check with any local electronics store. The salesman can give you the details about how to set this up with an A/B switch so that you can select between the modulator and the cable system.
Jerry G.
Apr 16, 2008 | Emerson SpongeBob SquarePants TV
Emersons spongebob tv pictur setup
how do i get the channels to show on the tv while im flipping the stations.
Jan 06, 2008 | Emerson SpongeBob SquarePants TV
Spongebob television
It may sound silly, but did you check the batteries inside the remote control? I thought I'd ask since you didn't mention it.
Sep 07, 2007 | Emerson SpongeBob SquarePants TV
Spongebob died
well i just opened mylittle sisters tv and found a c922 capacitor blown ill be replacing this tommorrow and i will see if it works alot of peoplesay they have this problem
May 03, 2007 | Emerson SpongeBob SquarePants TV
Power Outage - now DVD will not play through AV
I am having the same issue with mine. I even set everythign back to factory defaults and it still wil not work. Isn't there any tech support palced to find help? See post by Scriptster. Thanks
Jul 21, 2006 | Emerson SpongeBob SquarePants TV
Emerson SpongeBob SquarePants TV Logo
110 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
