Question about Homelite Garden
Homelite f2020 the flexible shaft is very tight,not turning freely. how do i fix it?
5 Suggested Answers
trippssmengi
  • 76 Answers
SOURCE: replace a flexible curved shaft
If you go to www.homelite.comin the red area up top click on order parts then click - click to launch homelite parts catalog, then scroll down thru agreement and click agree and then you will need to know your model number and you can get a breakdown of your trimmer wich will give you a good idea of how your machine is put together.
Posted on Jan 05, 2009
  • 81 Answers
SOURCE: Homelite strin trimmer head wont rotate
The only way to access the bottom of the metal shaft is to break it. This is fused on at the factory. It sounds like your flexshaft has twisted in two. Remove the flex shaft from the engine end and see if it is in one whole piece or is damaged in someway. If it rotates at the top but doesn't rotate at the string head this is probably the problem. However, Homelite no longer offers just the flex shaft for purchase. You would probably have to purchase the shaft and the tube as a unit.
But if you are saying the spool and string is not turning at the bottom it could be that the cup which holds the string has worn and can not longer be turned by the shaft. Replace the cup that holds the string.
Another possibility is that the shaft have moved forward, away from the engine and just need to be jammed back in, and retightened (the handle grip and the boom clamp).
Posted on Jun 17, 2009
  • 110 Answers
SOURCE: i have a homelite f2020 series petrol trimmer i
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Posted on Jun 16, 2010
  • 910 Answers
SOURCE: I can't get the retainer knob off my F2020
With the spool pushed into the housing you need to press on the retaining know white turning it.
Posted on Jul 12, 2011
What is the corrector part number for carburetors fitted on homelite line trimmers model F2020 UT2078
Your missing the last digit of the model number.
UT-20788 and UT-20789 uses the UP00608 carburetor which is a ZAMA C1U-H39.
Mar 28, 2015 | Homelite Garden
Weedeater and Homelite shafts interchangeable?
Just give it a try. Some different brands will interchange. I have done this with a Toro and it is still running.
May 18, 2014 | Homelite Garden
I have a homelite Z830sb that won't stay running. It starts and the shaft and spool rotate, then it appears that the shaft siezes, the spool stops turnng and the engine dies. This all happens in a 2-4...
sounds like your shaft is probably wound up,twisted, this happens sometimes, they get frayed, they are a flexible shaft kinda like a speedometer cable., take the screws out that will remove the housing from the motor should be 4 screws and the eng will slide off the tube and then you can see your flex shaft, then take pliers and pull it out and my guess is that you will find it twisted and frayed so that it winds up catches and springs back, GoodLuck
May 02, 2011 | Garden
I purchased a model f2020 weed eater from bunnings naenae the line cartridge broke up and i went to get a replacement from bunnings they don't stock homelite parts but ordered one for me i have been...
You can order the part from www.homelite.com You will need your model number to help you select the right part. You will need to click on the order parts text in the upper right hand part of the screen. This will take you to another page which will ask you to go to the homelite parts catalog. After you click on the parts catalog link, it will ask you to agree to the terms of use for the website. READ THIS CAREFULLY.
After you have agreed to the terms of use it will take you to another page. From here you can input the model number of your unit. Input the f2020 into the search box and click on search. It will ask you which version of the model you have. On the right side of the screen it will have a parts breakdown. You should select (Shaft-Spool and String- Grass Deflector). This will pop up a diagram with a parts breakdown which will include part numbers to help make ordering the correct part easier. I believe the part that you wish to order is part number 17 of the diagram. When you click on the part number in the diagram it will select it below the diagram and will flash for a second. At this point it has an option to add this part to your shopping cart.
I hope this helps get you back in business.
Apr 02, 2011 | Homelite Mighty Lite Lawn Trimmer
The liquid leaks from the shaft of the bread pan. Upon further investigation, the shaft drops down slightly from it's original position as I can push it back up but it won't stay up. What can I do to fix...
Hi...The paddle shaft fits tightly on a sealed bearing. This allows the shaft to spin freely. Over time the sealed bearing wears out, the shaft gets loose and liquid will leak through. Unfortunately there is no fix for this and a new bread pan is needed. sorry...Hank
Nov 11, 2010 | Cuisinart CBK-200 Bread Maker
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
What do i lubricate the flexible cable, inside the shaft of the line trimmer, with ?
I use a black molybdenum disulfide grease to lubricate the flex shafts. I remove the shaft, wipe off all of the old grease, apply a new coat of grease, and reverse the direction of the shaft when re-installing (top becomes bottom, bottom becomes top) to more evenly distribute the wear on the flex shaft.
Jun 15, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Replace a flexible curved shaft
Dec 16, 2008 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
61 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
