Question about Vacuums
Kenmore quick clean model 116.34720401
I've had this vac for awhile, but used it little. It has no suction. I've cleaned and cleared all hoses and filters. I'm a pretty good "fixer", but feel it must be in the engine. Does Sears still honor their lifetime guarantee on their Kenmore products?
2 Suggested Answers
  • 71 Answers
SOURCE: poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
Posted on May 02, 2009
Can anyone help with an older Euro Pro EP055, It has very little suction.
Cleaning filters on a bagless vacuum helps but filters should be replaced frequently, as often as every 3 to 6 months on some vacuums. Foam filters aren't as critical to replace because the pores are very large (which also means they don't filter out the small particles) so they don't clog as easily but paper filters have much tighter pores which become clogged and restrict the airflow. Cleaning paper style filters with water which can pack the fine dust into the pores clogging the airflow even more.
I recommend replacing filters st least onceor twice per year and cleaning them after each use for best performance and longer vacuum life. Blowing the dust out with an air compressor is my preferred method.
Changing filters frequently on a bagged vacuum isn't as critical because the bag collects most of the fine dust, dirt and gunk. The surface area of a bag is much greater than that of a filter so a bag is less likely to get clogged than a filter. Most homeowners change the bag once per month which keeps the air flowing smoothly.
Sep 30, 2017 | Euro-Pro EP055 Bagged Canister Vacuum
My vac has lost suction. When I vacuum it picks up very little, but when I remove the wand hose it has good suction. We have cleaned both filters, checked for blockage in all hoses & cleaned the...
Sorry to hear you're having a problem with your DC14. Since you say you've already washed the filters and checked for blockages, it's probably best if you get in touch with us so we can run through some simple troubleshooting steps over the phone, and arrange service if necessary.
You can call us free on 08002980298 (UK) or 1866MYDYSON (US). I'm sure we'll be able to help.
Kind regards,
Jack
Dyson Customer Service
Jul 10, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
No vacumm pressure. the passages are clear and the motor runs but there is very little suction.
if you are certain no blockages ? and the dust collector is clear/clean ? have you checked that the outlet filter which is located inside dust compartment is clean/clear this is usually a gauze filter its purpose is - as vac works and draws dust into collector the air that is sucked up thro vac builds up in collector chamber or bag on most vacs? and so for vac to maintain suction the air has to be able to escape to atmosphere/room without dust which is left insude chamber/bag if fitted and so air escapes via the gauze vent as prev mentioned ? however if gauze filter is not clear to vent then vacuuum is restricted due to air drawn being unable to expel sometimes on vacs they will eventually cut off due to o/heat but will operate when cooled so may i suggest checking the above possibility ?
Dec 13, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
How do I clean out the suction side of a Hoover steam-vac Model#f6020-900. I took all the screws out and still cant get it apart.I vacuum before using it, but it still seems to find more hair.
These don't come apart. Hoover makes a thin long tool that will allow you to stick up into this suction side to clean it or use a long piece of galvanized metal strip to slide up into it and clear away the hair.
Nov 26, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Filters all seem clean and clear, suction is fine,but loud noise
Sounds to me it could be tha fan impellor.
This is vac's etc... email us if you need to.
vacs.etc@live.com
Nov 04, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Poor suction (new bag, clean filter, clear hose)
May 01, 2009 | Vacuums
Kenmore vac has no suction in hose or base
Find a Shop that sells these & get them to show you.how it works.
Apr 08, 2009 | Kenmore 31912 Progressive Direct Drive...
We have a Kenmore Stylite Retrax vacuum cleaner, brand new. Suction is not working properly.
I actually pulled back my old vac after using this thing. Having said that I have played around with it and one quick cure is the remove or clean the little circle sponge filter at bottom. If you remove the canister and look at the bottom of vac you will see where the air travels down through a small circle. In there is a sponge filter that is probably clogged. Now Being frustrated, I just removed it and the vac sucks like crazy now. There are just way to many filters to worry about. As mentioned you need to clean the top main filiter, then the top sponge filter, and then dont froget there is alson one in the front of the machine (square paper filter) that catches dust leaving vac. These are on top of the little circle one that I removed, so I dont think it will be missed. Try and see what you think.
Apr 21, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
