Question about Refrigerators
I need a manual for Amana refrigerator
Amana refrigerator with bottom freezer drawer Model # ABB1924WES1
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
aborcass
  • 2651 Answers
SOURCE: Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Posted on Feb 13, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 6 Answers
    Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
    Posted on Jun 13, 2010
    BarrettDenCo
    • 1772 Answers
    SOURCE: My Kenmore Elite bottom freezer
    rewrwer
    Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
    Here is a list of some things that can go wrong.
    In addition, your drain tube maybe clogged
    1. Defective heat coil
    2. Defective defrost timer
    3. Defective defrost sensor
    4. Defective Fan
    5. Defective compartment inlet damper (on some models)
    You should call a service company to resolve your issue.
    Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
    4 Thumbs - Very Helpful
    3 Thumbs - Helpful
    2 Thumbs - Somewhat Helpful
    1 Thumb - Not Helpful
    Posted on Dec 27, 2010
    My bottom mount french door refrigerator, the upper part does not cold, it's warm
    Sorry your having trouble so soon!
    First thing you need to check is inside the freezer section.
    The freezer fan, the fan is W10128551 and should be running
    along with the main compressor. Since the freezer is working,
    I would check the food on the top drawer or on the freezer door shelf.
    They too might be soft..without the fan.
    I would You tube 'evaporator fan motor replacement Amana bottom freezer model' Yes I know it say's Whirlpool, but your unit is really
    a Amana designed unit. I would give this a difficulty of 3 out 5 wrenches.. Take your time..
    John Wright
    Jul 27, 2014 | Whirlpool GX5FHTXT Bottom Freezer French...
    ACCESSING DRAIN TUBE ON AMANA BOTTOM MOUNT FREEZER
    You pull the drawers out as far as they go then lif up and again pull straight out. That can be found on page 15-16 in the user manual found HERE If you need help I will be here just ask, Thanks Sea Breeze
    arrow_results_summary.gif Get Adobe Acrobat Reader
    Jul 06, 2012 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
    I have a Amana Bottom Freezer Refrigerator Model BC20ML that is about 20 yr.s old, works fine except the drain tube from refrig. compartment to evaporator drain pan sames to be plugged. Water and ice...
    You have to remove the bottom drawer, remove one of the drawer slider mounts on the freezer wall, and remove the rear panel. If yours has an ice maker you will have to disconnect it and remove it also. Unplug it so the water valve does not dump water on you while you are working inside.
    Aug 13, 2011 | Amana Refrigerators
    Amana bottom refrigerator bx20rw, how do i replace the defrost thermostat
    This link will show an exploded view of the area. Part number 6 is the defrost thermostat. Cut and paste into your browser.
    http://www.appliancepartspros.com/partsearch/model.aspx?model_id=273&diagram_id=810195#d810195
    Basically you need to empty the freezer, remove the drawer and back panel, unclip the thermostat and replace, there are two wires and should be the same on the new one, use caution not to damage the evaporator coils.
    Apr 18, 2010 | Amana ABB1927DE Bottom Freezer...
    Amana bottom freezer: water leaking & ice build-up
    There should be some kind of drain at bottom of freezer compartment to collect and run off any condensate that collects during defrost cycle.. Clean out the drain and snake out the line that leads from it. Right now the liquid is collecting where it should not and it will leak out the gasket when you have enough of it.
    Sep 09, 2017 | Amana ABB1927DE Bottom Freezer...
    Freezer leaks water!
    luvbug, Your refrigerator is "frost free" which means it is automatically defrosts after the compressor runs 8 to 12 hours. The defrost cycle lasts approximately 30 minutes. If it is in normal condition, defrosted water goes through the drain into the drip pan under the refrigerator and then evaporates. The problem you are having is one of the most common - the drain line is clogged up. To fix it you have to remove the freezer drawer, defrost and clean the drain. The drawer removal procedure described in the refrigerator manual book. If you do not have one you can find it there: http://www.amana.com/amana/jsp/manual.do You will see the drain hole on the freezer floor by the rear panel. To defrost it you can use your hair dryer. To make sure it is open, run a cup of very hot water through the drain. Reinstall the freezer drawer and enjoy it! Gendos....post it back
    Dec 21, 2006 | Amana ABB1927DE Bottom Freezer...
    Refrigerators Logo
    16 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
