Question about Kodak EasyShare C533 Digital Camera
Pictur when reviewing a pic there are dark lines visible across the screen
  • treeking Apr 21, 2008
    I have the same problem in all modes except for video. It use to occur with every picture and then I cleaned the lense. This seemed to really help. However, it does not totally fix the problem. It still occurs in 1 out of 5 pictures. When it does occur I remove the batteries, then replace them. I also clean the lense again. Its not the perfect solution, but at least the camera partially functions correctly. I suspect there is a fault in the camera's ability to determine the correct light and distance settings.
I have had a similar problem. Pictureres look like they are taken through a Venetial blind with white horizontal bands though I did get one with dark banding. It appears to have something to do with light levels. I took a few pics in a dark area with no flash and now it is working again...until it quits working again. Perhaps it is something to do with light level calibration? Whatever it is the problem is internal. If you are still under warranty, I highly recommend taking your camera in for repairs/replacement. Ours started acting up just after the warranty expired so no love for us.
Posted on Dec 30, 2007
SOURCE:
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
When ever there is some strong white on the screen it gets distored. For example. There was a white tent on screen and where the light was hitting it it was extremely pixelated and distorted. Ny ideas?
Hello
This fault can occur to mainly three reasons. ABL circuit failure. Low screen voltage or lack of emission from picture tube cathode. Just advance the screen voltage to a little, and observe the result. Screen control can be located on its Line Output Transformer [LOT]. there will be two variable controls built on to LOT marked as screen and focus. Screen control will be at lower side, and focus will bw on the top. Just advance [clockwise movemnt] to a little, not more, advance it till retrace lines are just visible on the screen. Before doing this, set all the picture controls, contrast, colour and brightness of the TV to zero. Once the retrace lines[thin horozontal white lines across the entire screen at about 1 inch distance with each other]; are visible, stop there, turn the screen control counterclockwise to just a point when these lines are just goes off. make this adjustment in a dark room so that you can set this point very correct. After this check the perfomance of the picture. If this does not help you, ABL circuit should be checked for any fault.
If emission of the picture tube has got down, even the screen adjustment said above won't help you. The only way is to replace the picture tube with same type and number. OK.
Apr 16, 2011 | Sanyo DS24424 24" TV
My TI-84 Plus Silver Edition Calculator is missing pixels or lines in the middle of the screen. If I press 2nd then + sign, i get menu to reset, but three lines are not visible. This happens in the...
this happand when you dont use the Calculator long time
try the 2nd and Arrow up make the screen dark for 15 to 30 min
keep puse any key until will pass the 30 min
if it will not help than it could be the screen or the connection on the mainboard
Oct 13, 2010 | Texas Instruments TI-84 Plus Silver...
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
Thin blue lines across screen more visible when picture is dark
blue crt is shorted you will need it replaced more than likely is NOT avail
Dec 01, 2009 | Televison & Video
Dark screen when trying to take pics Can review
I've had that happen to me too. Try pushing the screen display button and it should work again. (It's the 1st button under the mode dial).
Sep 28, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Lines show across my camera when I take a picture
Try the steps below.
Remove the Memory card
try to take picture w/out the card
if there are lines, transfer picture on the computer.
If lines exist when pics are transferred to the computer, call 1.800.235.6325 for repair.
Thanks.
Neerak21
Sep 25, 2009 | Kodak EasyShare Z612 Digital Camera
Lines
Have you try'd cleaning the screen, my friend had lines on his, he took the screen out, seperated it (2 pieces) and took his time cleaning it, seem'd 98% better when he finished
Aug 06, 2008 | Samsung SP42P2S Television
P5100 Nikon
I have the same problem as you... Nikon acknowledges that they have this problem on other Coolpix models, see: http://home.nikon-asia.com/pagearticle.php?pageid=43-7cc915b40d
Now, how do we get Nikon to acknowledge that this is a problem on the 5100 as well?
Jul 10, 2008 | Nikon COOLPIX 5100 Digital Camera
Kodak EasyShare C533 Digital Camera Logo
124 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
