Question about Samsung Televison & Video
Aa59-00431a The enter button will not work? All other buttons seem to work ok anything that I am doing or have done incorrectly
  • 848 Answers
SOURCE: helps with time - - - - what about date - that doesn't seem to work
try this one have your calculator set on "on" press the "time/clock" button once, when date appears on calculator press the "M+=" and hold until first number on date flashes, enter the date you want, when done switch your calculator from "on" to "print". date should be saved.
Posted on Jun 25, 2008
SOURCE: Unlocking codes
SECURITY CODE
Posted on Jun 27, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Display window doesn't show anything
The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
The repair service saves you a lot over the cost of a new control unit and comes with a full year's guarantee.
At our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Oct 08, 2008
consultel1
  • 860 Answers
SOURCE: I cannot get into admin programming menu. After
although the buttons aren't showing anything they're working. once the correct code is entered (266344) the screen will change.
Posted on Oct 06, 2010
  • 6 Answers
SOURCE: when i go to enter anything on the psp i.e
it might be that the right button/right side of the curser is jammed or something like that
Posted on Jan 30, 2011
I have a remote but my tv is on child lock and it saysplease unlock.i don't know what to do .I've tried pressibg other buttons nothing seems to work.
Hello
Philips sets use a four digit code to control the v-chip. The override code for Philips sets is 0711, although it may say "Incorrect code" the first time to trick you. If "Incorrect code" is displayed, simply enter 0711 again. To use it hit the MENU key to get to the menus. Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote. Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key. Go to BLOCKING OPTIONS and press the "right arrow" key. Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE ON". The v-chip is now reset.
OK.
Jan 09, 2011 | Philips Magnavox 20MS3442 20" TV
Incorrect Pin Error message coming on HP LaserJet M4345 MFP printer..
The pin for this specific machine should be 11434506.
If that doesn't work you must cold reset the machine.
Turn it off the machine.
Turn machine on hold 6 down until the memory count is done and all 3 lights are on release 6 and use 3 to arrow up to cold reset and press 6 "acts as the enter button"
FYI
3 works as arrow up
9 works as arrow down
6 works as the Enter button
Oct 15, 2010 | HP LaserJet M4345 MultiFunction Printer
2003 Escalade Keyless Remote not responding
You need to take it an have scan tool method done .
Mar 29, 2017 | 2003 Cadillac Escalade
I can't signing into yahoo messenger
It may be the server is down, it's been happening a lot lately or your Yahoo! Messenger connection information may be incorrect. Yahoo! will fix it soon. To configure your connection, what you should do? Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Firewall with no proxies" option. Select the correct Internet connection type and country from the pull-down menus. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. The above configuration works in most situations. (However, if you connect in this way, you won't be able to use the Voice feature.) If this configuration doesn't work, follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "No network detection" option and then click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in again with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If neither of the above options work, you're probably behind a firewall or proxy server that requires you to enter its address. Follow these steps: Click the "Messenger" menu in Yahoo! Messenger and select "Connection Preferences." Enable the "Use proxies" option. Enter your firewall or proxy server's address and port number. Contact your network administrator (if you're at work), or your Internet service provider (if you're at home) to determine the correct firewall and proxy settings. Click the "OK" button at the bottom of the window. Yahoo! Messenger will ask you if you want to sign in with your new proxy settings. Click the "OK" button. Enter your Yahoo! ID and password and click the "Sign In" button. If you try all of the steps above and Yahoo! Messenger still can't connect, contact your network administrator, Internet Service Provider (ISP), or the person who initially set up your computer to ensure that your firewall and/or proxy settings are correct. Hope it was helpful!
Jun 09, 2009 | Yahoo Messenger
Comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Apr 07, 2009 | Universal Remote Control Remote Control
Hey There! philips dvdr3370h After 2 years of no problems. disc stuck in drawer - fixed that Now , none of my discs will play. "error - incorrect region code" PLEASE Help! Thanks! Ben.
Try and see if this will work...
1-Power on the player.
2-Ensure disc tray is empty.
3-Wait for (no disc)to be displayed.
4-Enter 0086000 with the remote control ,then press ok.
5-Then enter with the remote control 00009 then ok
this should verify you have region 0
if it does all is ok.
6-Then you need to push system menu button.
7-The first page you come to will be general
you need to change the video output to ntsc,dont worry it will revert back to pal when you exit system menu..and only has to done once to set the hack.
THIS HAS TO BE DONE TO ALLOW HACK TO READ ALL TYPES OF DISCS E.G NTSC AMERICAN.
I hope this helps.
Plz let me know^^ Goodluck!
Dec 29, 2008 | Philips DVDR3370H DVD Recorder/HDD...
Helps with time - - - - what about date - that doesn't seem to work
Jun 25, 2008 | Office Equipment & Supplies
Remote control
I was able to get my Motorola DVR Cable Box to work with my Universal Remote using the following instructions:
The Instruction Manual for Manual Code Search seems incorrect. (Page 5).
A) Manually turn on the device to be controlled. (O.K.)
B) Press and hold the code search button until the red indicator stays on, then release the code search button. (O.K.)
C) Press and quickly release the desired mode button (TV, VCR). The red indicator blinks off once. (O.K.)
D) Face the remote control directly to the device you want to control. (O.K.)
E.) Press the ON/OFF Button (this should read CHANNEL UP button) repeatedly until the device to be controlled changes channel. The red button blinks off with each button press.
F) Press and release enter to install the code. (O.K.)
-Note, the remote is able to change the channel, however, it does not control the volume.
Jan 03, 2008 | Televison & Video
Televison & Video Logo
65 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
