Question about Garden
Flymo rollermo Appears to be overheating-cutting out
HOW DO YOU CHANGE THE DRIVE BELT ON A FLYMO 360
Your question is in the video game consoles categories???
If you actually have a Flymo 360 lawnmower you will find a link below to the users manual. However I looked at the manual and it appears to be direct drive ie. no belt. http://www.flymo.com/ddoc/flyo/flyo2012_gben/flyo2012_gben__a505284803.pdf
Aug 16, 2014 | Video Game Consoles & Games
Cut through cable on flymo how do i rewire
it best to get a waterproof cable connector then you do not have to take the flymo apart.
Apr 10, 2014 | Yard Man YardMan 11A41K3001 21Inch 173cc...
My flymo 350 turbo compact isint cutting can i adjust the blade height ?
You can put spacers under the blade, a twin pack of spacers are available from Flymo part no. 513811081., from memory you are allowed to fit three spacers.
Aug 10, 2012 | Garden
Flymo mlite 28 cuts out after short operating time
Next time this happens remove spark plug and see if it is very wet if so leave plug out turn to where the hole is down
Pull starter for few times until no more fuel comes from the sparkplug hole reinstall plug and try. If it now starts you will need to rebuild or buy new carburetor.
Sep 02, 2017 | Garden
Model HTC24 Flymo Hedgetrimmer
Are both the blades still moving? Are the blades sharp?
Aug 01, 2010 | Husqvarna Garden
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
Lack of information before purchase
Hi. I think I can put your mind at rest.  I work in a Flymo service agency. The Flymo Contour Cordless Power Plus has a guide wheel for accurate edging but, in common with all other Flymo edgers and trimmers, the actual cutting is done by a whirling thin (1.5mm) plastic cord that is designed to wear out and is fed from a replaceable reel under the cutter shield.  The only risk in cutting up to stone, concrete or other hard material is rapid wear of the plastic cord.  Unless your step is made of exceptionally soft stone there is no reason to think that the step will be damaged at all.
Good luck.  If this helps, please rate my response.
Apr 14, 2009 | Vacuums
Flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
Oct 16, 2008 | Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
