Question about Gilmour No. Xp30 3 - Gal. Premium Tank Sprayer
Green thumb sprayer parts
Won't pressurize
Why does my Green thumb .5 gallon sprayer leaks when pressurized?
sounds like your your rubber seals have worn out,or one has broken fully or you have not put it back on properly
Jul 18, 2014 | Green Thumb HD Hudson 79142GT Gt 2L Hand...
Whirlpool quiet partner 2 top sprayer fell off and won't stay on
It should lock into place. Check a parts lookup on searspartsdirect.com to see if you are missing parts. it is a easy fix unless a part is missing , you have a spray arm and a lock tabtab
Feb 16, 2013 | Whirlpool Dishwashers
Graco x9 won't hold pressure
If it comes up to pressure but won't hold it when the motor stops, you have either damaged packings or a bad check ball-to-seat seal. If it's the check ball(s) not seating properly a real good cleaning should take care of it. If it's the packings the only remedy is to replace them.
Aug 11, 2012 | GRACO INC Magnum Pro X9 Electric Airless...
440i titan only pressure is between 0-200 psi no matter the setting
If an airless paint sprayer won't prime it's usually because one or both check balls are stuck. First try hitting the head where the pump is sharply with a hammer, hard enough to knock the balls loose but not so much that you do any damage to the pump. If that doesn't free them up you may have to take the pump apart and clean them and their seats.
If an airless paint sprayer won't develop pressure, it's usually because the packing rnigs are damaged or collapsed. The only way to check this is to totally disassemble the pump and check them. Also look for any damage to the piston and cylinder. They must be very smooth and shiney, if they are scored they will eat up any new packing rings you put in.
Jul 19, 2012 | Titan 440 Impact Airless Paint Sprayer...
Graco Magnum XR5 electric airless sprayer won't start
It could be something as simple as you have the pressure turned down so low it won't appear to be working try to turn the pressure up and see what happens.
The worst thing could be you did not clean the sprayer out properly and now the paint has dried and the shaft is frozen to the packings and the other internal parts of the your sprayer.
Jun 27, 2012 | GRACO INC Magnum XR5 232740 Paint Sprayer
Won't seal and hold pressure
Try smearing some Vaseline on the gasket that goes around the pump shaft at the top.
Aug 06, 2011 | Ace Hardware Acer Spray and Go Sprayer
Dishes won't get clean. I opened the door, pushed the button and re-latched the door with the door open to see if the water was spraying out of the bottom properly... it is just trickling out of the...
Your lower spray arm is probably clogged. The clog may be caused by grease or scum OR it could be from bits of debris that has not been flushed from the machine.
Generally, the lower spray arm is easily removed by unscrewing a nut or thumb screw on the top of the arm. The arm will lift off easily and you can flush it at your kitchen sink. I sometimes have to take a toothpick, a brush, and/or tweezers to remove bits of paper, bone, or peelings. You can also soak it in ammonia to cut the grease that may have built up inside it.
Then put it in place and rescrew the nut or screw.This should restore the water pressure.
I hope this helps. If it does, please come back to Fixya and rate my solution
Jul 19, 2011 | Maytag Dishwasher
I am not getting pressure in the sprayer. Any suggestions?
Generally, the problem is either a leak or a bad pump. If you listen carefully and you hear air escaping try making sure the top is on tight (don't go nuts because you will never get it off again) Also many tanks have a gasket or O-ring under the lid. This is often lost or gets out of place, and then crushed by the lip. There is also a gasket or stopper thing at the bottom of the pump cylinder, sometimes this gets loose or gets a piece of stuff in it. It also could be the pump piston itself. HERE is the manual with a section on troubleshooting.
Be careful if you have used hazardous chemicals in it before.
Hope this helps, If it does please rate it.
Jun 18, 2011 | Gilmour Group #Xp20gt Green Thumb 2 Gallon...
How do you get pressure into the sprayer. I have pumped and pumped nothing seems to happen
IT'S AN INTRINSIC FAULT WITH THIS PIECE OF JUNK. THE DIAPHRAM INSIDE THE PUMP TUBE IS ABSOLUTE GARBAGE, THEY DON'T EVEN WORK PROPERLY WHEN BRAND NEW, BUT AFTER A FEW MONTHS THEY WON'T PRESSURISE AT ALL. BUY A QUALITY SPRAYER, THAT REPLACEMENT PARTS ARE AVAILABLE FOR.
Jul 23, 2009 | H.D. Hudson 1 Gal Poly Deck Sprayer
Gilmour No. Xp30 3 - Gal. Premium Tank Sprayer Logo
49 people viewed this question
Top Gilmour Garden Experts
cackelberry
Level 1 Expert
Charles T Nevin
Charles T Nevin
Are you a Gilmour Garden Expert? Answer questions, earn points and help others
