Question about Sony Ericsson W800i Cellular Phone
Sony ericsson w800i
When i attempt to charge my phone the message optimized charging appears followed by the battery symbol showing dat it is charging my phone however, when i chack my phone 2hrs later at the percentage of battery it is still the same why is there something wrong wid the battery?
  • intruder Aug 08, 2007
    thank you for your reply would i be charged as i have had this phone over a year?
  • 3 Answers
No there isn't something wrong with your battery.There also isn't anything wrong with your charger. You have to take your phone back to the shop,this happens with most of these phones.
Posted on Aug 08, 2007
SOURCE:
Xperia x1 won't charge. The charging symbol will appear on the screen for a short period of time (perhaps 2 or 3 minutes) before disappearing a showing the full battery symbol. This shouldn't appear...
First try to replace the battery, a drained or low voltage battery won't charge up.
For infos on how to fix the Sony Ericsson Xperia X1 Not charging:
http://mobilephonerepairguides.blogspot.com/2011/01/sony-ericsson-xperia-x1-not-charging.html
Aug 31, 2010 | Sony Ericsson XPERIA X1 Smartphone
I connect it and it appers charging-non-standard-battery
off the phone 4 some time and on it then charge,if no change, change ur charger if nothing happen change ur battery or check ur charging port
Apr 07, 2010 | Sony Ericsson Walkman® W610i Cellular...
W800i not charging
Since you've got a new charging unit, you may need to try using different battery. If same problem occurs, then plug the charger to the phone and slowly wiggle the charger to see if the power jack is loose.
If everything looks okay, then there's a loose connection inside or a bad IC that needs to be replaced. And you may need to contact the manufacturer for repair.
Have a great day!
Oct 18, 2009 | Sony Ericsson K800i Cellular Phone
My k550i shows, 'charging alien battery' some times i'm connecting to plug, some times it shows 'optimized charging'. wats d difference between these 2 messages.
The battery you are using is not of good quality.Alien battery actually is categorized as the lowest quality of compatible batteries, Optimized Charging refers to the advanced charging circuit in SE phones that prevents damage and ensures the battery is properly charged.
Jul 16, 2009 | Sony Ericsson K550i Cellular Phone
Charge meter problem
i have sony ericsson w800i
when i put to phone charge does not work charge, sometime connect charger & start charge
Jan 12, 2009 | Sony Ericsson W800i Cellular Phone
Battery problem for my k800i
if charge down in 3 hours mean battery problem. if the mobile show "not charging" message mean charger problem.
Jul 07, 2008 | Sony Ericsson K800i Cellular Phone
Unlock sony ericsson w800i
Yes Just purchase the code from http://www.onlinegsmunlock.com/ then follow the instructions as follows:
Warning : Do not enter any wrong unlock codes on your Sony Ericsson W800i mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W800i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W800i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson W800i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2 & 4. We mean by "Down Arrow" to direct the Jogdial down! In the Sony Ericsson W950i and some other models, the down arrow button/key would be located on the side of the phone.
Apr 12, 2008 | Sony Ericsson W800i Cellular Phone
Sony Ericsson w800i
you need to clean the bit at the end of the fone with a rubber and gently blow away the dirt then clean your battery see if that works becasue thats wot happended with my fone and that worked for me hope i helped thanks x
Aug 12, 2007 | Sony Ericsson W800i Cellular Phone
Sony Ericsson W800i Cellular Phone Logo
148 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
