Question about Garden
John deere gx345 starter - Garden
3 Suggested Answers
  • 6468 Answers
SOURCE: John Deere starting problems
check to see if you loose spark when this happens the coil could be failing
Posted on May 11, 2012
SOURCE: John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Posted on Aug 07, 2012
John Deere GX345 54C deck belt adjustment
Greetings, I read your question and I think Reliable-Store can help you in this. Here's the site link.
Best Manuals
May 22, 2017 | John Deere Garden
I have a GX345 with a bad upper main bearing, can this bearing be replaced or is the engine shot?
Whose engine in on the machine? If you can get the parts, you can probably fix the engine. ... let me rephraise that, if parts are available, the engine can be repaired. You can do it if you are engine savy and if you do the reading first. Take lots of pics and pay attention to what you are doing and it is doable ... if you can get the parts.
Dec 03, 2012 | John Deere Garden
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
May 10, 2012 | John Deere Garden
Is the carburetor on a John Deere GX345 adjustable? I have read it is not, but told it was... I have a "hunting", surging problem. Any thoughts...thanks in advance.
Hi, the problem you have is not adjustable. The carby needs to be stripped down and all jets removed and cleaned. Your problem is caused by a partially blocked jet, hope this helps, regards Phil
Jun 15, 2011 | Garden
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
