Question about Craftsman Garden
Lt200 My LT200, will start right up, when I engage the blade for cutting, it will start cutting, but then it will start stalling out, and white smoke bellows out, when I put my foot on the brake the brake it revs back up,,, but after I take off again, it will start trying to stall out again, and again the white smoke bellows out,,, with the blade disengaged, it does the same wanting to stall out, with less white smoke ?
    Master:
  • Craftsman Master
  • 645 Answers
Sounds like you may have some internal engine issues. Check your spark plug(s) to see if they are oil soaked. If so, you may have some issues with the engine.
Posted on Jan 02, 2018
4 Suggested Answers
M2Tech1
  • 313 Answers
SOURCE: engine stalls when blade is engaged
the best way to check is to run the engine with you on it then lift off the seat and see if the seat sensor is cutting off then put a bag with some weight in it and turn on the engine it should run ok if the sensor is working and lift the back box to see if the sensor works there.. the other cause could be a build up of grass in teh cutter area stopping the blades fron moving this can caus a stall if you get a hose and blast under the cutter guards and make shure the grass shute is clear for the grass to exit this may help to mine cuts out if there is a blockage here and the grass cant get out after it has been cut it builds up at the exit plates.. Hope this works AB
Posted on Sep 07, 2009
bbreton
  • 437 Answers
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Posted on Sep 28, 2009
suzukiracing
  • 200 Answers
SOURCE: smoke bellows from exhaust and stalls
sounds like the piston rings are worn out.Thank you for asking and I hope this helps you.Please leave me a 4 thumbs up.
Posted on Jul 20, 2010
M SNAPPER LT200 STOPS RUNING WHEN I TURN ON THE BLADES
check the safety switches with that problem look at the one on the seat
Apr 02, 2012 | Snapper 20 HP Lawn Tractor 2690578
Belt diagram for snapper lt 200 riding mower
PLEASE SHOW ME A DIAGRAM OF ACTUAL BELT AND PULLEY'S FOR SNAPPER LT 200, MODEL #2690441?
Mar 12, 2011 | Garden
Doesn't turn on after it's initial charge. This is the product, but it's not listed. HFBLU-LT200 Bluetooth Headset
follow the instructions on the warranty card and send it back to us. we will issue you a free tested replacement.
Jan 04, 2010 | Cellular Innovations HFBLU-CX1 Wireless...
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Aug 31, 2009 | Husqvarna 19.5hp 46" Yard Tractor
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
