Question about Canon PIXMA MP510 All-In-One InkJet Printer
5c00 canon mp540 printer
Na aanzetten ratelt de printer
SOURCE: canon pixma ip90 printer
if your printer is flashing 4 orange and then back to green repeatedly - i found a solution to it for my ip90v - i opened the printer and checked the right hand side cogs - carefully turn them and you may see that some stray paper jam debris is blocking the cleaning unit from returning to its home in the bottom front of the printer - carefully remove it and replace the casing - turn on and with any luck you will have a dully functioning ip90 like i did.
Hope it helps some others out
Posted on Dec 13, 2008
SOURCE: canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Posted on Jun 07, 2009
cene765
  • 787 Answers
SOURCE: canon ip3000 shows service error 5c00
5C00 is Purge unit error.Check for object around the purge unit.
Posted on Oct 15, 2009
  • 37 Answers
SOURCE: Canon MP540 Error 6C10
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
Posted on Aug 02, 2010
duane_wong
  • 6826 Answers
SOURCE: how do i reset canon mp540 printer?/disable ink
These are instructions for the Pixma mp560 printer, I couldn't find the mp540 printer on the canonusa.com website.
I do not know how to disable ink monitoring levels.
Default Settings Instructions to change the machine back to its default settings.
  1. Press the <HOME> button.
  2. Use the Easy-Scroll Wheel or the right / left arrow to select [Settings], then press the <OK> button.
  3. Use the Easy-Scroll Wheel or the right / left arrow to select [Device settings], then press the <OK> button.
  4. Use the Easy-Scroll Wheel or the up / down arrow to select [Reset settings], then press the <OK> button.
  5. Use the Easy-Scroll wheel or the up / down arrow to select [Yes] on the confirmation screen and then press <OK>.
  6. Press the <HOME> button to return to the HOME menu.
Note: Changes the settings back to the default (factory settings), except for the language for LCD messages and the position of the print head.
Posted on Aug 21, 2010
Mijn Canon MP540 geeft in het display error 6C10. Wat is hier aan te doen? De papierlade is bijgevuld en inktpatronen zijn vol
not the printhead
clean the ink absorbers located at the right side
bottom remove them and put them in can with water
also the transparant flaps in front of the absorbers
Sep 19, 2011 | Canon PIXMA MP540 All-In-One InkJet...
How do I fix my printer, it is showing B200 error?
B200 error means "Print head Temperature exceeded". In your to solve your problem you need to perform a printer reset. Click Here to view the Canon reset guide or you can follow the steps below:
1) Hold the On/Off button for 1 sec. until the printer shuts off.
2) Unplug the USB cable and then the power cord.
3) Press the power button for 1 sec.
4) Wait 10 minutes, then plug the power cord back in and then the USB cable.
5) Press the power button to turn it on again.
I hope this information will be helpful. Thank you for using FixYa!
Your feedback is greatly appreciated.
Feb 22, 2011 | Canon PIXMA MP540 All-In-One InkJet...
B200 error Canon Mp540
B200 is print head overheating error. Find details here:
Canon E200
Jul 09, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Canon ix4000 error 5c00
error [5C00] & Light Blinking 4 times = PURGE CAM SENSOR ERROR
you may need to replace :
- PURGE UNIT
- LOGIC BOARD ASSY
Oct 14, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Jul 21, 2009 | Canon PIXMA iP90 InkJet Printer
Error code 5C00
Error code 5C00 refers to a purge unit error. This is a service call error and requires that the printer be taken into a canon authorized service facility for diagnostic and proper repair.
May 15, 2009 | Canon I900D InkJet Photo Printer
Canon ip3000 shows service error 5c00
Feb 23, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA  MP510 All-In-One InkJet Printer Logo
41 people viewed this question
old marine
old marine
