Question about Canon EOS-20D Digital Camera
Dark Pictures in Auto setting
Ever since I took my Canon EOS 20D in for a cleaning all my pictures, when set in auto mode, are really dark, even in bright sunlight. I am new to photography and have no idea what could cause this problem.
  • DrPepprLover Aug 07, 2007
    No, here is a photo taken at about three in the afternoon.
  • wolob Jan 08, 2009
    i have a 20d with 17-85mm and 580 flash, almost all of my pictures are dark. maybe i am new to camera, therefore could it be my steeing? whats the best setting for a clearer picture on this camera?
Do you have a polarizing filter on the lens?
Posted on Aug 07, 2007
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
T2i pictures not coming good.
Load up the ATG Canon EOS Utility on your camera & check by shooting tethered. Then view it on a big screen,
Dec 11, 2012 | Canon EOS 550D Rebel T2i Digital Camera
Taking dark pictures, any suggestion, advise on setting?
Press i think it is upwards on your little d-pad.
put the exposure up more.
May let more light in?
Jan 08, 2009 | Canon EOS-20D Digital Camera with 17-85mm...
Grainy, Spot Filled Images when using Manual Modes Only
It sounds like the aperture is getting set very high. If the aperture is a high number, the lens opening is very small which lets less light in and would cause a dark image. This would also show any dust that is in or on the lens or image sensor. The dust doesn't usually show on apertures with a larger opening (smaller number). Make sure your aperture is being set to a reasonable number, probably no higher than 8 or so.
Oct 29, 2008 | Canon EOS-20D Body only Digital Camera
Everything is so dark!
If the camera is working properly with other lenses, then you have a problem with that lens. In M, you can set the aperture yourself, and the photos come out properly exposed. When the lens is set to auto, apparently it is going to minimum aperture and not responding to the camera's 'instructions'. The thing that makes me think so is that you say everything looks dark through the optical viewfinder. Normally the aperture stays full open so you can see and compose your shot, and only stops down to the correct aperture when you actually take the shot. I would suggest having the lens checked by an appropriate camera service shop.
May 29, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Cannon XTi
Try the camera in the full Auto mode to see if it is working correctly. Also check to see that there is no compensation set in the exposure settings for both apature and speed.
Check in the instruction manual to see how to get in to these settings from the user menus.
If this does not work, the camera will need to be serviced for a fault condition.
Jerry G.
May 28, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Pictures too dark
The settings in Auto Mode are factory set. If you want to adjust exposure and shutter speeds then you will have to shoot in Manual Mode (TV=Shutter Priority, AV=Aperture Priority, M=Full Manual)
May 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
I had the same problem before. Did you check to make sure your exposure compensation wasn't set at a negative number? half press the shutter and rotate the large dial on the back of the camera to change the exposure to 0. If this just changes your auto focus points, you have to change your custom function 13 from a value of 2 to 0 and then try half pressing the shutter and rotating the large dial in the back again. This fixed my problem with shooting in P mode (which I only used when absolutely necessary) and I hope it helps you.
Nov 09, 2007 | Cameras
CANON Rebel RTI Outdoor pictures are dark
learning to use light metering correctly can have its challenge.
the manual will guide you on how to set up to read light from the subject. spot metering a dark area will cause general overexposure, or a washed out look. spot metering a bright area will cause a dark image. if you are on spot meter and shoot two people standing together against a bright lit background, your meter will see between them if they are centered, and read all that bright background, setting the camera to a less sensitive combination of aperture / shutter speed, resulting in a dark image. use field averaging meter setting and be sure you are metering the subject and not the background. try shooting a wall that is fairly clear of other colors and uniform it light hitting it, you should have a correctly exposed image. since it works in other modes (at least 1, anyway) then it is unlikely you have an exposure compensation issue. that is the only other non defect issue that would cause your problem.
once you confirm that you have these settings correct and still get a dark image, its time to have it serviced.
good luck
mark
Sep 01, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Dark image....even using flash.
go to the menu & open setting file.properly check the settings of auto mode
Aug 18, 2007 | Canon PowerShot A630 Digital Camera
Canon EOS-20D Digital Camera Logo
195 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
