Question about Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo
Not responding will not repsond to manual or remote commands dvd and power light are on at the same time
    Top Expert:
  • Philips Master
  • 74,243 Answers
Main digital board is faulty. Should be replaced. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2350 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
Www sunaiservice com
Main board is faulty. Should be replaced.
Apr 30, 2013 | Philips Magnavox 26MD357B-37 26 in. LCD...
The player does not respond to commands from the remote. The sensor on the player does not light up when the remote's buttons are pressed. The light on the front of the remote does not go on when the...
Your remote may have gone bad. Using a digital camera there is a way of checking out a remote for proper operation. Google it and see what happens with fresh batteries.
Jul 23, 2017 | Koss KD260 DVD Player
Recorder is set to DVD command mode 1 and remote is set to DVD command mode 3 . Remote will not respond so i can not get to menu to reset. Is there any way around this problem
There is a manual for this model available in pdf format unless you have the original instruction book. Page 23 outlines 'command mode' where you can try pressing ENTER and the corresponding number buttons simultaneously on the remote for more than 3 seconds while pointing RC at the recorder. In your case, because your recorder is set to command mode 1 - press ENTER and 1 together on the remote. This should allow you back into the on-screen menu to revert the command mode back to 3 (which is the default) and it should work.
The online pdf manual for this model: http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf unless you still have the original. Pages 22-24 show some of the setup procedures. The pdf is not very big so you can save it for future use if needed.
Feb 01, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Power light is yellow and won't respond
Return or take to a tv repair, most fix dvd players.
Dec 23, 2009 | Cyberhome CH-DVD 300 DVD Player
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Sony MW24FM1 either won't respond to DVD commands, or turn-off
Sounds like a bad power board. They have random meltdowns all too often. Usually the cause is an overheated transformer caused by power transistor short outs. Possibly sell it. Could get over $100 for it if sold online.
Nov 14, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
Can I use the Smart Remote 15-2104 for a Cyberhome DVD Recorder?
The product manual doesn't list the Cyber home product. You might want to try a code scan, that might turn up a code set that is close. Here are the instructions:
USING MANUAL CODE SEARCH
If your home entertainment device does not respond
to remote control commands after trying all of the
codes listed for your brand, or if your brand is not list-
ed, try searching for your code.
Follow these steps to search for codes manually.
1. Turn on the desired device.
2. On the 6-In-One Remote, press the appropriate
device key once.
3. Hold down P until the red light blinks twice.
4. Press 9 9 1. The red light blinks twice.
5. Aim the 6-In-One Remote at the desired device
and slowly alternate between pressing POWER
and the appropriate device key. Stop when the
device turns off — a working code has been
found.
Note: In the search mode, the remote sends IR
codes from its extensive library to the selected
device, starting with the most popular codes.
Because of the library’s size, this procedure may
take some time. When the red light blinks three
times, the search of every code is complete.
6. Press P once to lock in the code.
Mar 20, 2008 | Radio Shack 15-2104 Remote Control
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
DVDrecorder not responding
try a power on reboot. hold the power button for 12 seconds until it reads "recover"
Rolling picture could be a loose cable or TV on the wrong channel.
Jan 06, 2008 | Philips DVDR3320 DVD Recorder/VCR
Non responsive dvd600 by Oritron
Can you take led off, see if DVD stuck inside unit? Find the tray release button and manually open the tray and replug. and see if unit respond.
Aug 10, 2007 | Oritron DVD600 DVD Player
Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
