Question about Leadtek Winfast 760m02-gx-6lrs Socket 754 Amd Motherboard System Board Tested Working
Motherboard i need to know how the power supply buttons connect to motherboard
  • 5,660 Answers
The front of your computer is the Front Panel
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
What you are asking for is a Front Panel header pinout.
I do not have the exact Front Panel header pinout, for your motherboard.
Tell you what I do have though..........
Looking at the Front Panel header on the Ebay link, for the Winfast 760m02-GX-6LRS; the Front Panel header looks to be below the CMOS battery, and close to the Bottom edge of the motherboard.
(Motherboard installed in computer case)
Black rectangular strip of plastic, with contact pins sticking up.
Also looks to be a GENERAL set-up for all Winfast motherboards.
(COULD be wrong here)
This is what I am referencing off of,
http://www.devhardware.com/c/a/Motherboards/Foxconn-Winfast-NF4SK8AA8EKRS-Motherboard-Review/3/
Go to the third photo down. Here you see the Front Panel wires, connected to the Front Panel header; on the motherboard.
(Below round CMOS battery)
Note that the contact pin on the Bottom row, and all the way to the Right; is NOT being used.
(I'm using a 26 inch HDTV as my primary monitor, so it may be easier for me to see)
Now look at this Front Panel header pinout, for another Winfast motherboard,
http://www.techsupportforum.com/forums/f15/winfast-mobo-front-panel-connection-558456.html
(Scroll down a little)
PWRLED is for the Power On LED (Light)
PWRSW stands for Power On switch
HD-LED stands for the HarDDrive activity LED (Light)
RESET stands for a Reset switch, IF USED.
Note where it has a Positive ( + ) sign, next to the pin for the PWRLED.
This is the pin the + wire from the Power On LED connects to.
It is the SAME for every LED that connects to the Front Panel header.
Let's number the contact pins, to make the explanation easier;
Starting at the Left side, Top row; going towards the Right;
Pins 2, 4, 6 and 8. There is NO Pin 10.
Starting on the Left side, Bottom row; going towards the Right;
Pins 1, 3, 5, 7, and 9.
Pin 2 is for the Positive wire.
Pin 1 is for the Positive wire
If the LED's are dim, (PWRLED, and HDD LED), OR; the LED's do not light up, switch the wires around.
(Pin 9 is N/C.........Not Connected. This is probably a 5 Volt test point, that was used by the factory)
There is a method you can use though, and find out what the individual contact pins are, in the Front Panel header;
Use an LED with two wires
Computer (Power Supply) plugged into power, go along the top row, and touch two pins at a time, with the two wires of the LED.
Example; Pins 2 and 4, as shown in the pinout.
Did the Power Supply come on?
No?
Go to the next two pins. Try again.
When the Power Supply comes on, you naturally know that is the two contact pins; for the Power On switch.
DO NOT touch them again. In fact connect the Power On switch wires.
Power Supply on, computer running;
Now go back along again;
1) LED light blinks?
You have the HarDDrive activity LED, contact pins.
2) LED light stays on?
You have the Power On LED, contact pins.
3) Computer restarts?
Those are the Reset switch, contact pins.
4) Nothing happens?
May be contact pins for a speaker, or contact pins that are not used.
(Speaker is for hearing BIOS Beep Codes.
You have a Piezo buzzer, to the Left of the CMOS battery; for that)
Post back in a Comment, as to the results.
If possible, I would like to ask upon you; to post the Front Panel header pinout; when you find what it is.
That way when a person in the future also has this same problem; the solution will be posted on the internet, for them to find.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Apr 30, 2013
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
There is no power switch on the enhance atx 1123b that I have . What actually powers it up?
Just about every power supply I've owned doesn't have a power switch. The power supply is turned on by one of the wires in the 24 pin connector. According to this it looks to be pin 16 and how to turn it on:
"Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF."
Hope this helps
Ray
Mar 01, 2011 | Enhance Technology ATX-1123B, Enhance...
My old power supply had 4 wires going to the front panel on\off switch. The Dynex power supply does not support the switch. what do I use to turn the unit on or off. Will the unit function with out the...
Normally the front panel on/off power button and the front panel reset button plug into connector pins on your motherboard.
If you can find a User Manual for your motherboard it will show you exactly where the switch leads plug in on the motherboard. The motherboard's manufacturer and model number will be printed on the board somewhere.
Good luck.
Feb 05, 2011 | Dynex DX-400WPS 400-Watt Power Supply
Have replaced this board, hooked everything back into its place, have checked off/on switch,have tried another power supply, yet, when i push the off/on button the fans jump but the green light on the...
Hello, You might have a bad motherboard and need to replace.
First, I know its a pain but disconnect and reconnect all cables verify that your not missing one of your power cables look for any connections on the board that don't have cables hooked up to it. take extra care when hooking up your power button cable. Its easy to accidentally place them in the wrong pin.
Hope This Helps
Jan 30, 2011 | ASUS PTGD1-LA Motherboard
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
Hi: We have a Dell Latitude D620. The battery is low and blinking. When connecting the power supply, it won't take the charge, keeping blinking. Tried with a different power supply; same problem. So...
Yes you'll need to replace the motherboard if the laptop won't turn on using the power supply (ac adapter) you can either try a known good power supply, but if it still does the same thing you'll need to replace motherboard.
And for the battery you can check it there's a button on that battery to check if it still works good or simply access BIOS setup that will be on f2 check on the battery life it will say if you need to replace it too.
If you have a warranty on the computer that's good.
You can get the parts replacement for free!
Hope this helps!
Jan 18, 2010 | Dell (002TR) Motherboard
Is It required to connect Tower Front Panel I/O to Motherboard
The power button on the front panel would definitely need to be hooked up to the motherboard so you can power up the computer.
If you have any usb slots or a media card reader on the front panel, or both, then you would need to hook those up as well, otherwise the main one you need to connect would be the power button.
May 23, 2009 | ASUS P4V8X-MX Motherboard
Blue button flashing
The reason why the button is flashing is cause the power supply is not putting out the right voltages and the motherboard can't power on.
Best thing to do is to see if you can try a different known good power supply and hook up the connectors to the motherboard only and see if it turns.
This usually takes care of the problem. I have also seen it where the motheboard is bad on rare occasion. To verify the motherboard after trying a different power supply is to make sure there is no cards in the pci slot and makes sure none of the drives are connected and the only cables that should be connected to the motherboard is the power supply.
Hope this helps and let me know if you need extra help.
May 13, 2009 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
Power switch notworking ( ASUS P4PE-X Motherboard)
Please refer your motherboard manual and fix the front panel cable including power button. After this if power button is not working than swap the power button cable and reset button cable.
And then start your PC by pressing the reset button.
Else you just recheck all the cable + RAM + CPU.
Mar 09, 2009 | ASUS P4PE-X Motherboard
Leadtek Winfast 760m02-gx-6lrs Socket 754 Amd Motherboard System Board Tested Working Logo
281 people viewed this question
Top Leadtek Computers & Internet Experts
Cliff
Are you a Leadtek Computer and Internet Expert? Answer questions, earn points and help others
