Question about Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo
Www sunaiservice com
Dvd light and power light are on and the tv will not respond to remote or manual commands
    Top Expert:
  • Philips Master
  • 74,106 Answers
Main board is faulty. Should be replaced.
Posted on Apr 30, 2013
I have a ge universial remote i need the code fora dynex flatscreen tv dvd combo
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device Button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed, If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below. Codes for brands are located at the bottom of this link. http://www.directutor.com/content/ge-universal-remote-instructions
GE Universal Remote Codes and Instructions direcTutor
Nov 15, 2016 | GE Televison & Video
No sound, no picture
Try with external monitor and let me know did u see ur desktop with external monitor?
OK?
Nov 24, 2007 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
029,022,021,027. Try these codes. If you wish to get more, check the sites linked here. It has setup codes, and setup procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 23, 2013 | Sylvania LC195SLX LCD TV
The basic problem is that your TV does not control your remote. You have it backwards. The remote contains the codes that control your TV. Try removing the batteries from your remote and pressing all of its buttons in case one is stuck. Reinstall the batteries or install new batteries and try operation.
Aug 14, 2013 | Sylvania Televison & Video
Can not find codes for toshiba remote for my sony dvd home theater changer nor any specifics on hooking it up properly and it has s video but no hdmi hook ups help By the way i already pd 1459.00 dollars...
To find the code for the Toshiba remote to the Sony DVD changer.
If you do not know the device code for a particular device, you can view each available code for that device mode and sample the functions to find the code that operates the target device. 1 Press a mode select button on the remote. 2 While holding down INFO button , press 8, 5, 0, 0. The remote control enters program mode. 3 Point the remote at the target device and press Power button, 1, VOL UP, CH UP or PLAY. Some keys are ignored if they are not applicable to a specific device mode. 4 If the device responds to the remote control: Press INFO button to store the device code. The mode select button blinks twice. The remote exits program mode. 5 If the device does not respond to the remote control: Press UP. Press POWER. Repeat this step until the device responds to the remote. Press INFO . Note: When a search cycle is completed, the mode select button blinks 3 times. The remote displays each available code again. If no key is pressed within 10 seconds, the remote exits program mode and returns to the previous code.
The previous section was from the manual p.86: http://www.iusermanual.com/tv/toshiba-46vx700u-tv-manual.htm
Hooking the DVD changer to the TV: The TV has composite video inputs and can accept s-video by a adapter cable as in: http://www.amazon.com/S-Video-3-RCA-Composite-Cable-Laptop/dp/B002ZKTCUM/ref=pd_cp_e_1
May 05, 2011 | Toshiba 46VX700U LCD TV
Need codes for the tv. the remote is ge universul rc24912 d
Here is the link. it should be the right codes.
http://www.jascoproducts.com/support/download-files/RemoteCode-4-digit.pdf
here is how to enter them:
DVD, etc.). For AUX, press AUX then the device button you are assigning to
turn off.
Note:
If your
device does not respond to the first code listed, repeat steps with the next code
Apr 17, 2011 | Audio Players & Recorders
Recorder is set to DVD command mode 1 and remote is set to DVD command mode 3 . Remote will not respond so i can not get to menu to reset. Is there any way around this problem
There is a manual for this model available in pdf format unless you have the original instruction book. Page 23 outlines 'command mode' where you can try pressing ENTER and the corresponding number buttons simultaneously on the remote for more than 3 seconds while pointing RC at the recorder. In your case, because your recorder is set to command mode 1 - press ENTER and 1 together on the remote. This should allow you back into the on-screen menu to revert the command mode back to 3 (which is the default) and it should work.
The online pdf manual for this model: http://www.docs.sony.com/release/RDRVX560_EN_ES.pdf unless you still have the original. Pages 22-24 show some of the setup procedures. The pdf is not very big so you can save it for future use if needed.
Feb 01, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Sony MW24FM1 either won't respond to DVD commands, or turn-off
Sounds like a bad power board. They have random meltdowns all too often. Usually the cause is an overheated transformer caused by power transistor short outs. Possibly sell it. Could get over $100 for it if sold online.
Nov 14, 2008 | Toshiba MW24FM1 24 in. TV/VCR/DVD Combo
I need codes for a rca d770
Programming For TV
1. Turn on the device to be programmed.
2. Look up the brand and code number(s) for the device on
the code list at the end of this section.
3. On your remote control, press and hold the device button
you want to program.
4. Enter a code from the code list.
5. Release the device button, and then press ON•OFF to
see if the device responds to the remote control
commands. If it doesn’t, try pressing the device button
and then ON•OFF again.
6. If you get no response, repeat these steps using the next
code listed for your brand, until the device responds to
the remote control commands.
Emerson ..................1004, 1006, 1012, 1014, 1023
..................................1024, 1025, 1026, 1027, 1028
..................................1029, 1030, 1031, 1033, 1034
..................................1035, 1036, 1038, 1039, 1041
..................................1042, 1043, 1044, 1046, 1047
..................................1123, 1124, 1162, 1171, 1176
......................................................1177, 1179, 1191
Your user manual is available for download and option printing at the following link :
http://www.retrevo.com/s/RCA-D770-Universal-Remotes-review-manual/id/402ci568/t/1-2/
May 16, 2008 | RCA D770 Remote Control
DVDrecorder not responding
try a power on reboot. hold the power button for 12 seconds until it reads "recover"
Rolling picture could be a loose cable or TV on the wrong channel.
Jan 06, 2008 | Philips DVDR3320 DVD Recorder/VCR
Philips Magnavox 26MD357B-37 26 in. LCD TV/DVD Combo Logo
48 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
