Honeywell Diagrams rth3550d1006 - Heating & Cooling
Installed a rth6350 now no power
The RTH6350 is a battery-powered thermostat. Did you correctly install the AA batteries? Press down and pull the battery holder away from the thermostat on the right hand side. Try new batteries. Did you remember to secure the C wire with a wire nut and push it back into the wall. It should not be connected to the thermostat.
If you connected the C wire, you may have damaged the thermostat by providing too much current. Honeywell has the documentation for the RTH6350 on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH6350D.htm . The installation guide is here: https://customer.honeywell.com/request.cfm?form=69-2416ES . See page 23 and subsequent pages for the wiring diagrams.
I hope this helps.
Oct 11, 2014 | Honeywell RTH6350 5-2 Programmable...
Unclear directions on motion detector installation
Contact Honeywell co directly they are great people and great cust service and will walk u through the process
Feb 05, 2014 | Honeywell Home Security
Honeywell wiring diagrams
WE R GOING FROM A HONEYWELL TAYSTAT500 THERMSTAT (HEAT PUMP) TO A NEW HONEYWELL to (WHOLE NEWHEATING/AIR CONDITIONER) WITH A HONEYWELL RTH8580WF1007 THERMOSTAT? WHERE WOULD THE C WIRE BE. WE DO NOT HAVE A WIRING SCHEMATIC FOR THE OLF THERMOSTAT. IT HAS 7 WIRES. HELP?
Jan 10, 2014 | Heating & Cooling
Wiring diagrams
I sent you both a heat pump and gas wiring diagrams
bcdbc16a-2dce-44b7-9caf-23449270684b.png6fc00210-56df-45c5-b534-b02c97c792ca.png88979b18-fd81-4408-9c6c-6c03740833cb.png0d534ff0-4e77-4d35-bcc0-1fc2eb1f10d0.jpg
Dec 11, 2013 | Honeywell Programmable Thermostat Heater
Wiring a Honeywell V8043E for two zones
Honeywell posts pdf manuals.
Google seArch Honeywell V8043E .pdf
Include .pdf in search parameter to find manual with wiring diagrams.
http://www.forwardthinking.honeywell.com/related_links/water/5000_series/install/95c_10932.pdf
Oct 26, 2012 | Honeywell V8043E1012 Zone Valve 3/4 Sweat,...
Need to connect a universal fan relay with a transformer
I hope you are good at electric becaue you are biting off a chunk here...
Check out these diagrams they are for Honeywell but all the fan centers are pretty much universal...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2023.pdf
or this one...
http://customer.honeywell.com/techlit/pdf/60-0000s/60-2171.pdf
one of those should be pretty much like yours...
heatman101
May 06, 2010 | Carrier 38CKC036 Air Conditioner
I've just moved into an oldish house and there is a honeywell heating/water controller installed. its quite old and i cannot find any identifying marks on it. It looks like a st699, 2 on/off per day. I...
If you go to your local home depot, and get a new thermostat, it will come with different diagrams for wiring in the instructions that are pretty easy to understand. I hope this helps.
Nov 04, 2009 | Honeywell Electronic Programmable...
Wiring diagrams schematic (boilers)
call me alan 0776 7494009 have books on c, s,y plans
Mar 04, 2009 | Cooper Wiring Devices 1301-7B GROUNDING...
Replacing thermostat: tstatccshp01 with th8320u1008
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Jan 21, 2009 | Heating & Cooling
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
