Question about Tools & Hardware - Others
Mastercraft 12 1/2" 99-7050-4 thickness planer adjustment
Neee adjustment advice for blade shaft
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Need a user manual for mastercraft thickness planer
I'd suggest calling 1-800-689-9928 and speaking with one of the customer service representatives
Posted on Dec 15, 2008
SOURCE: Ryobi AP12 Thickness Planer---rubber feed rollers do not rotate
It is fixable if you are technically competent. All parts are still available online. It could be one of two problems:
1 - The rollers are driven by two gear & chain mechanisms on the height adjuster side of the unit. I did have a drive chain break once.
2 - If it isn't that than the gearbox has cracked / gear stripped under the torque load. This is also fixable, each individual gear and the gearbox housing are still available (10-09), but it requires substaintial teardown.
As you disassemble the unit just be careful once you remove the crossover height adjuster shaft - you don't want to turn one lifter by itself and have the planer higher on one side. It really is a simple teardown, just lots of parts. If you like the planer it is worth it; parts are cheap. If you are like me, you enjoy tearing stuff down to see how it's made and you hate throwing out $200 tools because only one little part broke!
Posted on Oct 18, 2009
SOURCE: i do not have a manual for my mastercraft maximum
If it is anything like my 12 1/2 inch mastercraft planer you will need to remove the dust guide first, and then the drum with the blades will be visible. To remove the blades you need to loosen the bolts with the appropritate sized crecent wrench. Seems to be the only part of my planer that does not require an allen wrench actually.
Posted on Nov 27, 2009
rowdy45176
  • 2176 Answers
SOURCE: blade adjustment for dewalt dw733
go to dewaltservicenet.com and you can download an owners manual with instructions on how to adjust/install the blades.
Posted on Jun 15, 2011
I am looking for parts for a mastercraft thickness planer and was directed to this site...can you help?
I would suggest searching on line for your make and model of tool, you might be able to find an operating manual that should give you information for where to go for replacements.
Jan 08, 2017 | Crafts & Hobbies
How change blade on mastercraft planer
Richard, How change blade on mastercraft planer. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Dec 05, 2015 | Crafts & Hobbies
How do I change the blade on a Mastercraft planer?
as with any planer you need an alinement Jig this device "Holds" the blade at proper level to allow you free hand to tighten set screws if not it's lots of "lets try it here" sort of stuff
Nov 22, 2014 | Garden
Blade shadt adjustment
run a bit of timber through and measure the sides for the same measurement. adjust the thick side up till it is the same measurement both sides.
Apr 29, 2013 | Craftsman 1212 in Thickness Planer
Thickness Planer (DW733) leaves fine scratches on wood surface.
It sounds like your blade holder assy has become misaligned on the blade drive shaft. Try if you can to use a straight edge on 2 planes 90 deg apart and see if there are any gaps in either of the srtaight edges. I suspect that the blade drive holder has become slightly dislodged from the drive collar on one end allowing the blade drive to tilt on the drive shaft. I had the same thing happen on another brand named Planer and it was a matter of reseating the collar to cure the stripes. Sure took a long time to sort out. Good Luck.
Feb 06, 2010 | Dewalt DW735R Reconditioned Heavy Duty 13"...
I do not have a manual for my mastercraft maximum 13 inch planer and would like to know how to remove the blades for sharpening
Oct 20, 2009 | Tools & Hardware - Others
Aug 06, 2009 | Tools & Hardware - Others
Nov 18, 2008 | Tools & Hardware - Others
Tools & Hardware - Others Logo
448 people viewed this question
Top Tools & Hardware - Others Experts
Bill Boyd
ray gallant
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
