Question about Dishwashers
Bosch silence auto 3 in 1
I would like a manual to this dishwasher because I need to know how to make it run a program over 65 degrees. I don't know what model it is, the only thing written on the front is silence 3 in 1. Very grateful for help
textonor
  • 130 Answers
SOURCE: BOSCH DISHWASHER RUNNING TOO LONG PROBLEM
Bosch dishwashers are designed to heat the water to temp. However it has a 3 hr default if it doesn't reach temp. Start the cycle and see if after 1 hour if the water is hot or cold. If hot, then it is heating the water and the water coming in is just too cold. You may try running the water at the sink to get it hot there first before starting the dw. If the water is cold, then your unit isn't heating the water. At this point I pull the outer door panel, find the largest wires on the control unit and put my meter leads on them then start the machine. You will see 120 volts on your meter. Start the machine in light washes and with in 10 to 15 minutes you should see 0 voltage. Than means the relay has closed in the control and the hot line of the 120 volts is being sent to the heater. If this never happens, then you have a bad control. Bosch dishwashers have a 5 yr part warranty on the electronic control. Now If you get the 0 volts, I will put my amp meter on one of the same wires and check for 9 to 11amps. If that isn't there, then you have a bad heater assy. Hope this helps
Posted on Jan 06, 2008
  • 409 Answers
SOURCE: Bosch Exxcel Dishwasher - manual please?
hi there,
no problem. the model # is usually located on the inside rim of the cabinet. open the door and locate the sticker itself. i will also need your e-mail address, so i can e-mail you the pdf file.
Posted on Nov 05, 2008
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
ginko
  • 19396 Answers
SOURCE: We have an error message on our Bosch Exxcel
Hi Martin.
There is no Error H24 on Bosch machines. What the display is trying to tell is H2O, incorrect displaying may be caused by defective LCD display or board.
H2o is displayed when there is an inlet problem, either because water pressure is too high, too low, inlet hose is kinked or blocked, inlet valve is devective, or pressure switch is defective.
If you get problem only when selecting Intensive, which requires higher water pressure, then the problem can be pressure from the house lines, inlet valve blocked or pressure switch.
Let me know if this helped, in case do not forget to accept.
Regards.
Ginko.
Posted on Aug 28, 2010
ZJLimited
  • 17970 Answers
SOURCE: what is E25 on my
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Posted on Apr 03, 2011
Bosch silence plus showing fault E24. Have lost our manual . How do we fix this ?
Check the manual online:
https://www.manualslib.com/products/Bosch-Silenceplus-She45r55uc-3787557.html
Jul 01, 2017 | Bosch Dishwashers
Tip
Conversion chart for dH to Clark BOSCH EXXEL Dishwashers
I couldn't find any info on my new BOSCH EXXEL dishwasher the codes in the manual are all in dH (german) while the H:XX codes mean nothing unless you have this table I created here it is for you all so you don't have to worry, it has all the conversions between Clark, dH and mmol/l and mg/l if you find one that applies to you just look across the table and find your corresponding H code.
You will need to go to your suppliers own website to find one of the above numbers for the quality of water usually in mg/l they will give you this value and then you can select the H code for you area.
Water hardness is measured in either European °E (clarks) or in the German °dH( Deutsche Härte) you will find this on all Bosch Dishwashers if you water is Extremely hard then you will need to program your Bosch dishwasher using the Code H:06 to give you maximum protection, if your water like mine is Extremely soft then the H:00 works well and also saves you loads of dishwasher salt.
HARDNESS CHECK TOOL
• Clark degrees (°Clark)/English degrees (°E) conversion to mg/L calcium: divide by 0.175 One degree Clark corresponds to one grain of calcium carbonate in one Imperial gallon of water which is equivalent to 14.28 parts calcium carbonate in 1,000,000 parts water.
•Deutsche Härte (German hardness) (°dH) conversion to mg/L calcium:divide by 0.14 One degree German corresponds to one part calcium oxide in 100,000 parts of water
on Dec 12, 2009 | Dishwashers
I have a Bosch dishwasher Auto 3in1 Silence Comfort, type: S9LT1B that dosen't warm up the water. The heating element is OK. Is there anyone who have a wiring diagram for this machine. Harald
There is a wiring diagram inside the cabinet of the machine, so if it is a built in you must pull it out to get the repair paperwork and diagrams.
Feb 02, 2017 | Bosch Dishwashers
Code E15 bosch super silence dishwasher
Use dish washing rug and soak water out trough salt inlet. Only 10 degrees tilt needed. Boch Super Silent dishwasher. E15 error code.
Mar 02, 2013 | Dishwashers
How do I reset the child lock on a Bosch dishwasher model # SHE4AP06UC/05?? Can't find the owner's manual and can't figure out how to get the childlock off and change he cycles from scrub to...
Here is your manual:
http://www.managemylife.com/mmh/lis_pdf/OWNM/1006474L.pdf
Let me know if you need further instruction.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 10, 2011 | Bosch Dishwashers
When dishwasher runs it is continuous for about 3 hours Bosch clasixx free standing
It is possibly the water heater, basically if you run a normal wash at 65 degrees and the heater has failed, the d/w stat is waiting for the water temp to reach the desired temp. It will continue to wash, waiting for this to happen and eventually it will give up the ghost and time out, aborting the cyle.
The instantaneous water on this model is around £100 and too be honest is best fitted by an expert, so if this is the problem you'll be looking at a reasonable repair bill.
If you decide on a repair and you are in the UK, contact BSH Home Appliances who are the repair section of Bosch as they offer a one off payment on your first call out (even though they know there is definately a fault) this covers the repair cost for the first visit and then covers the complete machine for 12 months. You can pay in instalments for 10 months which will take the stick out a touch (this is called repair +).
Really hope this helps, good luck.
Jul 12, 2010 | Bosch 24 in. SGS43C12 Classixx...
My dishwasher smells
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removed) this will expose the pump impellor and you can check for any obstruction.
Try running a 65 degree wash with a couple of caps of baby sterilising fluid. If the d/w is connected directly to the sink, remove the spigot and check there aren't any blockages. I run a dishwasher cleaner thru my d/w every 3 months and every couple of week I will load the machine for a wash, add tab to dispenser and just after starting a 65 degree wash, I will open the door and tip in approx one capful of sterilising fluid.
baby fluid is also good as a sluice wash for your washing machine on 90 degrees (w/m empty, approx every 4 weeks). https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S
ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Jul 11, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
