Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GAS RANGE OVEN CAN'T SEE THE MODEL ON THIS SITE JPBC????
Hello, I have a GE gas stove but don't see the model on this site. I think that it's JPBC.... Anyhow, I just replaced the spark module because I didn't have any spark at all top burner & oven. My stove is sparking the top and oven the same time . Well with the new spark module the top burners work fine, but when using the oven the spark goes on forever. first it light up some kind of pilot light and the main flamme pops up after a while. the problem is the sparking stay on and the flammes doesn't even come on. Could I have a bad oven switch that will not shut off by itself? What about the main flammes? I hear the gas coming out inside the oven. How do I trouble shoot it thank you Sorry if this is confusing
  • pierre larue Aug 07, 2007
    Ok the model is JGBC15GEK1 and the spark module is WB20X104
    tHANKS FOR ANYONE TRYING TO HELP ME OUT
  • 3 Answers
Sounds like the sparker in the oven isn't correctly installed, if you hear gas try and light it with a lighter, (WATCH OUT FOR YOUR FACE)
Posted on Aug 17, 2007
Ge model jb400d oven will not heat up
Troubleshooting Why Your Gas Oven Won't Ignite or Heat ...
? 4:39
https://www.youtube.com/watch?v=Oe0BJmXhh7M
Dec 20, 2012 - Uploaded by PartSelect
Remember, parts are specific to your model and the ones shown t. ... Range/Stove/Oven Repair - Replacing ...
Gas Oven Won't Heat - How to Repair (Part 1 of 2 ... - YouTube
? 9:20
https://www.youtube.com/watch?v=sHWRRMrIpfU
Jan 29, 2012 - Uploaded by Tomahawk DIY
If I order on ebay for ge gas range oven ignitor do they as formodel #? .... removed the entire gas tube with ...
GE, Hotpoint & RCA - Wall Oven Diagnostic - Not heating ...
? 11:16
https://www.youtube.com/watch?v=BQNs4gHlT_A
Jun 13, 2013 - Uploaded by ApplianceVideo.com
Fix a GE Wall Oven which has some of the following dilemmas:Not heating By ... GE, Hotpoint & RCA ..
Dec 30, 2015 | GE Kitchen Ranges
The oven temperature on my GE XL44 propane range is inconsistent. I set it at 350, and then I'll check the inside thermometer a half hour later and it will read 450. Drives my wife crazy. Some days it...
Hello. One question has your range burner jets been changed to LP (liquid propane). If you are using natural gas jets for the burners and ovens this make the heat and flam fluctuate in temperature and the same for the oven. Natural gas jets are larger. One more thing here! There is a control valve spring with cap in the stove gas regulator that has to be taken out and turn around.
Search the operation manual on how to changes jets from natural gas to LP. In back of the stove behind one of the panels is a small cloth bag contain these LP jest and also there should be set of instruction in a bunch of languages.
If you are going to do this yourself--- DIY. Read those instruction ever carefully. There a bass ball valve that hook to the gas line before the flex stainless line behind you stove. Turn the nob to where it perpendicular to the gas line. Open the windows in the house and turn off all electric equipment such as, fans, toasters, don't be clicking the light switches off and on. Just a precaution for you and your family safety.
Check with your city zoning ordnance about home owner changing their gas jets in the range. Some cities and states won't allow you to due this. Then you will need a technician to preform this operation. I wish you and family well being and you safety first... GB you...stewbison
Aug 22, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
My GE XL44 Gas Range (Model JGBP34 GEP 1A) control
If you like the stove and it in good shape otherwise, have it fixed. The parts are still available. The stove in good used condition (without leak) is probably worth $75.00. May cost that much to repair it. Will cost approximately $450.00 to replace it with equal range. If it's a standing pilot model (no electricity needed) they are unavailable and your new range will require power to use the oven. Hope this helps.
Dec 07, 2009 | GE Spectra JGBP35 Gas Kitchen Range
I purchased a new natural gas range a couple years ago for our cabin. I need this range to use propane.can this oven be changed to use propane instead of natural gas?
should be able to change orifices to propane. some ranges offer these on the back of the stove or you can buy them at a local parts dealer. take your model # with u when you research a part
Jun 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE Profile Gas Range, serial at235522p, model JGBP79WEW1WW
If this is a newer range, the instructions to recalibrate should be in the manual that came with the stove
Sep 27, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE range stove #317B6641P001
Hi thanks for the question. the problem you are having is with the igniter. it does not get hot enough to work at 100 % . replace the igniter. thanks te appliance doc
Sep 10, 2008 | GE Profile JGSP44 Dual Fuel (Electric and...
Similar problem but ignitor replacement did not fix mine
try the gas valve behind the storage drawer. it may be closed. that was my problem.
Aug 20, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Need info.......
i don't think that model has a pilot try the oven and see i think its electronic ignition
Mar 31, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
151 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
