Question about Behringer XENYX 2442FX Mixer
How do i connect my Behringer UB2442fx pro mixer to my NJA 760 Amp ?
  • 5603 Answers
SOURCE: my behringer ub2442fx pro has the numbers 88
A high likelyhood of a power supply problem.
I had a similar thing on a GX110 and it was an electrolytic cap that filters for the 5 volt regulator on the DSP board.
As the DSP starts up, the load on the supply sucked it below the operating point and caused the DSP to keep reseting. The display did flash.
The unit will have to be opened and trpunbleshooting done to find and repair the problem.
Posted on Dec 20, 2009
  • 5603 Answers
SOURCE: How do I connect my behringer mixer desk to
The first thing to do is to swap teh L & R INPUTS to the amplifier. Did the speaker that works change?
If som the problem is with the setting of the mixer deck. If it did not change, then the problem is with your speaker wiring of the dead speaker, the speaker itself, or that side of the amp.
If the working speaker did swap, that means problem is with the mixer. The question then becomes how are you connecting to the mixer. You should be using TRS 1/4 inch connectors or preferably XLR from the MAIN outputs. These are balanced outputs connections.
If the inputs are from one of the mono inputs, the PAN control for that channel will control how much goes to each speaker... If at center, both will get same signal.
There are so many possibilities that I can't evaluate them until you try the test to find if it is problem of the amp or the mixer that I have given you to try.
Posted on Dec 28, 2009
SOURCE: Need Behringer V-Amp Pro repaired or find diagram & parts
my euro2442 is not prperli runing so plese send me your service center in india
Posted on Jan 04, 2011
  • 5603 Answers
SOURCE: Will a Behringer UB2442fx-PRO run
ALL the speakers will either have to be POWERED or have external amplifiers. The mixer has NO power amps capable of driving speakers. When connecting, make sure that the mixer is powered by the same receptacle as the speakers or amps. Used balanced line for interconnection.
Posted on Jan 24, 2011
  • 140 Answers
SOURCE: I'm looking for a solution how can i connect my
You can use the compressor in two ways. 1st you can go inline from the main outputs into the compressor out of the compressor to the rest of the world using normal cables. You may also insert the compressor into the main inserts using a cable that is tip, ring, sleeve 1/4", to seperate 1/4" tip sleeve mono plugs. any more questions give us a call at the store 215-736-8055
Posted on Jun 10, 2011
Pdf manual by ub2442fx-pro
You can download from here... http://www.behringer.com/EN/Products/UB2442FX-PRO.aspx
Sep 30, 2014 | Behringer EURORACK UB2442FX PRO Mixer
How to link 2 mixers
VIa, XLR, TRS, 1/4 Jack, phono,,
Jul 19, 2014 | Behringer EURORACK UB2442FX PRO Mixer
Effects won't work stuck on d2
Hi, did you find a solution for this problem? I have it too.
Nov 16, 2013 | Behringer EURORACK UB2442FX PRO Mixer
I need a new fx push knob for eurorack ub2442fx pro
This place has a great selection of Behringer parts. You should be able to find your knob here: http://www.dbmproaudio.com/behrparts.html
Jan 10, 2013 | Behringer EURORACK UB2442FX PRO Mixer
My EURORACK UB2442FX-PRO has audio coming in but nothing coming out...
The outputs of these mixer needs to be connected to an active speaker.
An active speaker have an amplifier and a preamplifier.
Oct 02, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
Jun 10, 2011 | Behringer EURORACK UB2442FX PRO Mixer
When i have my FX on and sending to main they make a horrible clicking (shorting out) sound. if I push the main mix button it shuts off the effects and the noise goes away...bad side...then I have no...
Check the 5 volts to the FX unit, If the voltage is low, the FX processor will keep reseting generating clicks, In a different product, the 5 volt filter cap was degraded and voltage dipped down to 4.5 volts causing resets.
May 31, 2011 | Behringer EURORACK UB2442FX PRO Mixer
Noisy headphone amp in ub2442fx
Download schematic here:
http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to the small "Get Manual" link and click on it.
The headphone amp is on sheet 13.
Mar 22, 2011 | Behringer XENYX 2442FX Mixer
Will a Behringer UB2442fx-PRO run 2 main PA speakers plus two passive stage monitors without blowing up?
Jan 24, 2011 | Behringer Music
Behringer XENYX 2442FX Mixer Logo
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
