Question about Utilitech 0.5-HP Stainless Steel Waterfall Pump PPWF33
Waterfall pump problem
I have purchase 3 of the PPWF33 1/2 HP waterfall pumps from lowes. The first two lasted less than a month and I took them back to lowes. Spoke to your customer service people at that time and we decided I should insure that I was using a large diameter hose from the pump to the water fall (lift abour 3 feet) to insure no strain on the pump. As a result the 3rd pump has laste about a year with no problem. Then recently it too froze. This time I opened the pump expecting to find a bad bearing but actually found that there were too problems - the impeller had shattered (slthough there was no debris that seemed to be the cause) and, water had seeped into the motor itself and had corroded the rotating mechanism. I can clean it and re-seal the pump but I will need to purchase the lower shaft bearing and impeller. Where can I do this - or is there another solution? Richard Geck 732-644-4339
4 Suggested Answers
  • 512 Answers
SOURCE: I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Posted on Sep 16, 2012
hunter19_46m
  • 7482 Answers
SOURCE: I have a utilitech convertable pump. It is used as a shallow well pump at the moment. It worked fine untill last week, the hot water tank went bad and we replaced the tank and all the above ground li
Hi mid_age_elf
Your problem is that your "water bound"...
Your water tank must have a cushion of air for the pressure switch to work properly.
Turn off your pump and drain about 1/3 of the water from your tank.
Once you have an "air cushion" the pump and switch will work properly.
You can also add air pressure using an air compressor and an air valve installed on the top of your water tank or maybe on the side or bottom of the tank.
You would put air into the tank until about 1/3 of the water is gone replaced with the air.
Once that is complete your problem will be solved.
Please take time to rate me
Bud
Posted on Oct 25, 2012
boysor2933
  • 293 Answers
SOURCE: I bought a unitech 1/2 hp transfer utility pump. I would like to remove coming uderground water fron the shallow pit. What happened after the pump remove this water. When the new water come isit start
Install a foot valve (check valve) at the end of the suction line so that you don't have to prime it again. Install a level controller so that it will automatically switch on and off according to your predetermined high and low water levels.
Posted on Nov 06, 2012
I have a Century 1081 115v, 2 speed pump for my waterfeature. The motor runs fine in low and high spped, the pump impeller is spinning but it dies not pump water.It is a 3/4 horse. The waterfall reservoir...
I don't know the answer to this ... your pool service company can advise you. To my way of thinking, you are asking a lot of a 3/4 horse. I have a 1 1/2 horse lifting water in a two inch pipe about 4 feet to my water feature with no reservoir.
Since you have a two inch pipe, why not run a bigger motor? I have two HP on all my filtered lines which are 2" suction and 2" discharge.
Are you absolutely sure you have suction? ... and no air leaks on the suction side?
Apr 24, 2011 | Century New Magnetek Pool Spa Pump Motor...
My waterfall pond pumps keep burning out. The
I found that little giant pump are oiled filled and if it gets hot it frys itself... As for submersible pumps Magnetic drive Beckett Pumps are nice. My Beckett pump has been going for 4 years now it pumps 4800ghp. the cost $269 last I looked.
Oct 14, 2009 | Little Giant Submersible Fountain Pump
My flotec 4/10hp waterfall/utility pump was working fine for about 1 hour, now it's only humming and not pumping any water... ?
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Sep 21, 2009 | Flotec 4/10 Hp 3000 Gph Waterfall Utility...
I installed a 2 hp high head pump on a waterfall and the amps are running about 16 when I start closing the discharge side of the pump the amps come down where they are suppose to it is going out on...
make sure your wireing is up to the job and your back presure at the pump discharge is within limits. both of these should be in your pump book that comes with your pump. If you don't have one you should be able to look it up on-line or order one from Pentair.
Aug 15, 2009 | Pentair Challenger High Head 1.5 Hp Pump...
Is it possible that my well is going dry? second submersible pump I've burned up 1/1/4 hp gould pump lasted less than one mouth
several things will affect the pump, has there been a lot less rain than normal or using a lot more water such as more showers and toilet flushing ? if no then something else is wrong. the pump should3 feet from bottom of the well and should have roughly 10 feet of water above. when pump was replaced did they put it low enough in the well? The capacitor and wiring are they in good shape and supplying enough power? if voltage is low such as bigger pump or long wire run, too small a wire the voltage can become to low and cause pump failure. suggest having wiring tested first (cheapest) if all fine from there need to check water level and pump depth setting.
Jul 10, 2009 | Craftsman Professional 1/4 Hp Submersible...
Parts for Garden Treasures 2 tier fountain
You can find replacement parts on amazon. click here Amazon com tier fountain parts and search for your part. Hope this was helpful. cheers
Apr 05, 2009 | Garden
Pw5500 Calpump not working
replace the breaker with a higher amp breaker . Thank you for useing fixya please take the time to rate me
Feb 09, 2009 | PW Calpump Pw5500 Waterfall Pump 5750 Gph...
Utilitech 0.5-HP Stainless Steel Waterfall Pump PPWF33 Logo
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
