What is the WACC for Apex Printing given these assumptons: weight of 40% debt and 60% common equity, a 35% tax rate, cost of debt is 8%, beta of the company is 1.5, risk - free rate is 2% , return on the market is 11% .
SOURCE: tax rate
press button CA then TAX+ and enter tax rate figure, then press TAX+ again to store.
Posted on Oct 07, 2008
  • 4090 Answers
SOURCE: Royal Petroleum Co. can buy a piece of equipment
Hello, this is a project that you have been set to achieve. We are not here to do your homework, you have to study this subject and make your own decisions, that's what study is all about, getting you educated and earning the certificate of proficiency in your chosen subject.
For any of us who have made it in the world to answer this question on your behalf would be unfair to your lecturer or teacher in awarding marks to you for our work.This is cheating! Surely you would want to honestly earn your merit rather than be a sham in life.
Contact your teacher fo help if you don't fully understand how to work this through.
Now please honestly rate our advice to keep us in work doing what we have earned the right to do++++Thanks for using FIXYA
Posted on Sep 13, 2009
  • 8068 Answers
SOURCE: You are given the following data.
OK, you convinced me to do your homework for you.
Before doing statistics, you have to prepare the calculator by clearing old data that may generate errors.
A. To clear old data
  1. Press [2nd][+] (MEM) to open the memory management screen.
  2. Press [4:ClrAllLists]
  3. The command echoes on main screen, press [ENTER] to run it.
  4. Calculator displays Done.
B. Run the SetUpEditor command
  1. Press [STAT][5:SetUpEditor] [ENTER] ; calculator displays Done.
C. Turn DiagnosticsOn option (optional)
To obtain the correlation coefficient in a statistical analysis on the TI8xPlus family of calculators you must activate the DiagnosticsOn option. To access the command
  1. You press [2nd] [0] (CATALOG)
  2. While the list of commands is displayed, press [X^-1] (D)
  3. Cursor jumps to first command that starts with D, dayOfWk(
  4. Press the DownArrow 9 times to reach DiagnosticsOn
  5. Select it and press [ENTER]
  6. Command echoes on main calculator screen with blinking cursor
  7. Press [ENTER] to set the option
  8. Calculator displays Done.
From now on, if a correlation coefficient has meaning for a regression model, it will be calculated along with the other statistical results. If it has no meaning to the model it will not be calculated.
D. Enter the data
Press [STAT][1:Edit]
Type in the X values in L1 and the Y values in L2 (see picture 1)
To obtain the statistical results
  1. After you finish entering the data, press [2nd][Quit] to exit StatEditor.
  2. Press [STAT] and highlight Menu (CALC)
  3. In the list select [2:2-Var Stats]
  4. Command echoes on main screen.
  5. Press [ENTER] to calculate the stats
Here is what you get (with you data).
Notice the down arrow next to n=7. That means the results screen has more values. Press the down arrow to display.
You notice that the n=7 line now has an arrow pointing Up. Notice the Down Arrow on the bottom line (more data is coming). Here is the rest of the statistical results.
There is no arrow at the bottom of the picture. End of statistical results.
The screen captures with 2-Var Stats summarize all the satistics. Some of the values your are looking for are among the result. NOW it is you mission to identify what you need (I chewed all the work for you).
However there is no correlation coefficient, no line of best fit, etc. To obtain that you have to perform a regression analysis.
Perform a Regression analysis
To perform a regression analysis, you must try several regression models and then find the one that mimicks the raw data best. In this particular case, you have already decided to do a linear regression, and that is good for me. I do not have the time to take you through all of them. A linear regression it will be.
  1. Press [STAT] , highlight [CALC]
  2. In the list of regression models select [4:LinReg (ax+b)
  3. The command LinReg(ax+b) echoes on main calculator screen.
  4. If you press [ENTER] you will get you equation but you will not be able to draw the curve on top of your data to verify the goodness (no it is not a swear word) of the fit. So you must save the equation as a function in Y1 variable.
  5. While LinReg(ax+b) command is still in command line, press the [VARS] key.
  6. Highlight the [Y-VARS] menu and select [1:Function], then press [ENTER].
  7. In the Y function variable list select [1:Y1]
  8. At the command line, you have LinReg(ax+b) Y1.
  9. Press [ENTER] to save the equation of best fit in Y1.
Here are your results.
The slope is a and the y-intercept is b. You also have r and its square. You need to read your theory to know which of the two correlation coefficients you have been asked to obtain.
Since you saved the equation in the Y1 function you can draw it. You just have to press GRAPH and it will be drawn. But that will not tell how good the fit is, until you see the function drawn on top of the raw data.
Drawing the scatter plot and the raw data on the same screen.
Regardless of the curve of best fit, you can draw a scatter plot as follows.
  1. Press [2nd][Y=] (STATPLOT)
  2. Select [1:Plot1...Off] to open plot1 configuration screen
  3. Use arrow to highlight On
  4. Use the down arrow to move cursor to the line Type.
  5. Select the first icon for a scatter plot. NOTE: To navigate the 6 statistical stat plots on the line Type, use the right or left arrow (to backtrack), but not the Up or down arrows.
Here is the configuration screen
Here plot1 is active (ON), it is scatter plot (first icon) the Xlist is L1 by default but you can change it to some other list. Notice the highlighted A cursor on XLIST line. It means that the [ALPHA] keyboard is active.
On the line Mark you can choose the appearnce of the raw data point.
And here is your two graphs: the raw data scatter plot and the line of best fit on the same screen
Now, it is up to you to accept this model or to try another model.
N
Posted on Jan 21, 2010
  • 8068 Answers
SOURCE: how do i find out how much taxes were paid on a
8% =8/100 =0.08
Your question is not clear so I have to consider the two possibilities.
A. First case
2553.12 is the taxless price (may not be your actual case)
Simple tax (to be) paid =2553.12*0.08=204.25
B Second case:
2553.12 is the total price (including the tax) and you want to find out the tax that was paid on it.
In this case 2553.12 is (1+0.08) the sale price
The tax-less price is given by
2553.12/(1.08) =2364.00
and the tax paid is 2553.12-2364.00=189.12
Examine the two cases and find the one that corresponds to your situation. Whichever it may be, your solution is here.
Posted on Mar 19, 2010
  • 102366 Answers
SOURCE: Tax Rate....no manual
You can download the manual from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/office/calculators/desktop_printing/p170_dh#BrochuresAndManuals
Posted on Aug 02, 2010
Tip
Pros and cons of home equity loans
There are some really great benefits to taking out a home equity loan. First because the loan has a fixed interest rate there will be no fluctuation as the economy changes. The money that you borrow in a home equity loan can be used to pay off credit cards and will help you to consolidate all your debt into a single payment that you make monthly. Even though the interest rate on a home equity loan may be higher than that of your mortgage it will still be lower than if you were to use credit cards to pay off your mortgage. And finally the interest on the loan may be tax deductible and depending on the use of the loan you may be eligible for leeway in deducting the interest.<br><br>At the same time there are a few things that you have to keep in mind before you take out the loan. When you take out a home equity loan you are borrowing a whole lump sum unlike home equity line of credit in which you only borrow as much as you need. You will want to be careful what you spend the money on, if you were to spend the money on remodeling your house then you have a greater chance of the value of your house appreciating as opposed to buying a car that as soon as you drive it off the lot beings to depreciate in value. Probably the most important thing to keep in mind is that when you take out a home equity loan your house is held as collateral so in the case that you are unable to make payments then you will lose your house.
on Aug 26, 2013 | Finance
I own 2 homes,no mortgages. I do not work. I need to borrow $ from the equity in 1 of them. I am selling 1 home & can pay back as soon as it sells.
If you have no mortgage on the home you are selling then there is no equity to release as equity is the difference between the sale value and the debts still on the property
Jan 25, 2017 | The Computers & Internet
How to calculate the cost of equity
final value = principal value x (1+I)^n
I= interest rate for n say 10% it would be 0.10
if n= 1 year then interest rate if
one year interest rate so if 5 years n= 5
if interest rate is monthly then divide year int rate by 12
and increase n by 12 so 5 years equals 60 terms of interest calculation.
cost of equity would be pv + pv * CPI
if CPi was 2.5% as an example
cost of equity for year one= PV + (PV * 2.5/100)
fv = pv*(1+2.5/100)^1
if cpi is different each year then
fv= pv1(1+2.5/100)^1 + pv1(1+cpi2/100)^1 + pv1(1+cpi3/100)^1
If CPI is same for each year then FV = PV (1+0.025)^number of years.
^ 2 is like squared
Jul 20, 2016 | Furniture
Hello, TAX-AMT is not printingon receipt after changing tax rate.
Go back to system options and print options and select PRINT TAXABLE or TAX AMOUNT
Jan 04, 2013 | Casio TE-2000 Cash Register
Flat screen 40" apex digital
Hi:
Check the power supply for faulty capacitors, there are usually two or three of them that go bad. You can tell the bad ones because they become puffy on their tops. The most common value of capacitors used for the inverter board to light the back lights are 3300uf rated at 35 volts. Replace with same value and voltage ratings.
Mar 04, 2011 | Apex Digital Televison & Video
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70...
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
Oct 23, 2009 | Microsoft Excel for PC
Royal Petroleum Co. can buy a piece of equipment that is anticipated to provide a 9 percent return and can be financed at 6 percent with debt. Later in the year the firm turns down an opportunity to buy a...
Sep 13, 2009 | Vorton Financial Tools 1.0 (509) for PC
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
70 people viewed this question
k24674
jasbo
jasbo
