Question about Toro Garden
What can be wrong
Model # 13AP60RP744, LX500-621-616. It has problems shifting from forward to reverse, and vice-versa. It also still drives in either one when put into neutral. Not sure what the problem is. It still shifts, but shifts hard.
emissionwiz
  • 76846 Answers
SOURCE: Automatic Tranmission forward gear works reverse doesn't
YOU HAVE A SHIFT SOLENOID THAT HAS EITHER FAILED OR IS STUCK, DO YOU HAVE ANY TRANS TROUBLE CODES?
Posted on Nov 02, 2008
chuck943
  • 783 Answers
SOURCE: lincoln ls shifts hard into reverse
You will have to have the solenoid body replaced in the tranny and have the PCM reprogrammed.
Posted on Feb 16, 2009
66 chrgr
  • 1011 Answers
SOURCE: Transmission problem
im sorry to say no it will not.
Posted on Mar 02, 2009
  • 79 Answers
SOURCE: Clunking noise from underneath truck
Sounds like a bad ujoint.
Posted on Apr 24, 2009
mowerman1857
  • 389 Answers
SOURCE: My 2000 / 2001 17HP Yard Machine won't start. Battery and plug OK
It could be a burned fuse!
Locate the wiring harness at the back of the ignition switch and follow it until you locate the in-line fuse. Remove the fuse and check it. It should be a 20 amp fuse.
Posted on Sep 20, 2009
Testimonial: "I changed the fuse and the gas filter, not sure which was the problem, but it works now."
1998 land rover discovery transmission makes loud banging noise when shifting from pari to drive?
Tons of possibilities here (transmission, differential, motor mounts, transmission mounts....), so I'll ask some debug questions to help narrow it down. Does it make the noise when shifting into reverse? Also, does it make the noise only when shifting from park, or also when shifting from neutral (into drive or into reverse)? Did the noise start as an occasional, softer noise and get worse over time, or did it start suddenly? Does the vehicle lurch at the same time as the noise? What happens when you go from Reverse to Drive, or vice versa? Has any work been done recently (brakes, tires, alignment, suspension, transmission)?
Jul 20, 2014 | Land Rover Cars & Trucks
Reverse is forward and vice versa
To get a dc motor to spin in reverse you have to change the polarity of the battery. This is normally done in the switch by which set of poles is connected . Have you connected the battery up correctly in the first instance.
Jul 13, 2013 | Minn Kota Endura 40 Transom Mount Trolling...
2006 XC-90 V8 AWD CLUNKING OR KNOCKING NOISE WHEN SHIFT FROM REVERSE INTO DRIVE OR VICE VERSA
very probable a motor mount is broken; or it could be a constant velocity joint.
Feb 12, 2011 | 2005 Volvo XC90
My scooter goes backwards when i push the forward leverand vice versa. is something connected wrongly?
Mickey
It would depend on what model Compnanion Scooter you have. The latest version has a Delta Tiller and these are designed to be pulled towards you as opposed to being push away. Trust me it is an ergonomic thing. However, if your scooter does not have a Delta Tiller the wiring may be reversed.
The best bet is to call Golden's Technical Service Dept. at
1-800-624-6374 Ext 501
May 10, 2010 | Golden Technologies Companion II Travel...
Transmission question
hi i will try help, well yes it will have adverse results on his gear box if he is putting it in drive and then reverse before the vehicle stops going forward, ile explain, when you engage the gear and drive forward, the centrifugal force is sent to the torque converter This engages reverse gear within the transmission, giving the ability for the vehicle to drive backwards. In order for the driver to select reverse, they must come to a complete stop push the shift lock button in (or pull the shift lever forward in the case of a column shifter) and select reverse. Not coming to a complete stop can cause severe damage to the transmission. Many modern automatic transmissions have a safety mechanism in place, which does to some extent prevent (but does not completely avoid) inadvertently putting the car in reverse when the vehicle is moving forwards. This mechanism usually consists of a solenoid-controlled physical barrier on either side of the Reverse position, which is electronically engaged by a switch on the . Therefore, the brake pedal needs to be depressed in order to allow the selection of reverse. Some electronic transmissions prevent or delay engagement of reverse gear altogether while the car is moving. Some shifters with a shift button allow the driver to freely move the shifter from R to N or D, or simply moving the shifter to N or D without actually depressing the button. However, the driver cannot put back the shifter to R without depressing the shift button to prevent accidental shifting, especially at high speeds, which could damage the transmission.so hope that answers your question and end the feud lol, please vote thanks
Mar 03, 2010 | 2002 Volkswagen Jetta TDI
I have Troy-Bilt storm 7524 snow blower which normally works fine, however, it has started to have problems shifting back into forward gear after being reversed. I'll put the snow-blower into reverse gear...
Try lubing the linkage where it shifts from forward and to reverse the linkage is most likely freezing up or has snow or ice build up causing it not to shift, My thought is your shoving it hard enough that it finally engages when you get the snow or ice to break off.
Jan 05, 2010 | Garden
Gear shifter sticking (auto) from Park to reverse and vice versa.
you need to have the shifting cable lubricated or replaced.
Apr 26, 2009 | 1996 Honda Civic
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
