Question about Klipsch Ifi System Dock Control Din Plug Repair
Klipsch ifi repaired
Speakers crackle or don't work. why?
How do I repair/replace a damaged USB port?
Do you using original cable from Klipsch?
Make sure your charger is on normal working conditions.
It is difficult to fix the USB port, except the experts.
Aug 23, 2015 | Klipsch GiG Portable Wireless Music System...
Asko repair melbourne
it's more likely the amp, which klipsch provides as a complete unit.
Apr 08, 2014 | Klipsch Audio Players & Recorders
Instead of base it is making a crackling noise like its blown but i know the speaker is good. any ideas
are you 100% that it is not blown, have you hooked up a meter to check the speakers resitance, if it is a home sun it should be a 8ohm speaker, if you have the owners manual check what impedance it is, if that checck out then try a different cable and then if you can try hooking it up to a friends AVR are you using high or low level inputs on the sub?
I’m happy to help further over the phone at https://www.6ya.com/expert/glenn_3b3dd885737c06f6
Sep 03, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
I have a 12 inch Klipsch synergy series sub. for my surround system and want to put my JL audio 12w6 speaker in the box, will the amp drive the woofer or is the ohms a factor?
ohms is a big factor. also it will probably take more power to drive the W-6 so it won't sound as good. I suggest you don't do it. especially if you can't match up the ohms. You will fry the amp, or it will sound like ****.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
May 19, 2012 | Car Audio & Video
My Infinity ps-10 subwoofer makes crackling sounds. I took it to a repair shop and they say it needs a new power supply and a new amplifer and that it will be over $200 to repair it. I only paid $400 (6...
Probably not, but you could make it into a passive subwoofer by disconencting its internal amp and powewring the driver directly by an external amp being fed by an LFE channel.
I did this with a problematic Klipsch SW.
May 14, 2010 | Infinity PS-10 Subwoofer
I sometimes lose sound from my left speaker and it crackles.
this is a speaker input pin problem, like pin is dameg or input pin is not atech proparly in computer problem is still present remove the cable and install new one cable in speaker
Mar 11, 2009 | Audio Players & Recorders
Klipsch/KLIPSCH, not BOSE, pleaz HELP!!! -ifi wont play anymore
I had the same problem, and it was the 4700uf 25v capacitor that was bad. I replaced it and the iFi's working great again.
Nov 25, 2008 | Bose 901 VI Main / Stereo Speaker
Klipsch Ifi System Dock Control Din Plug Repair Logo
57 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
