Question about Ralph Lauren Polo Pima Cotton V-Neck Vest Sweater
What does classic modern fit in clothing mean
What are gease certs
It is a grease zerk. That is the fitting that a grease gun fits over to install grease,
26251185-xiyfjxhjclaahpd5o5v1fuxw-5-0.png It looks like this, but may be at an angle. The top of this is what you will see.
Aug 02, 2016 | Cars & Trucks
Google chrome has replaced my google classic how do I get it back all favourites gone too
You cant, google classic has completely withdrawn the classic view as part of modernization. The one's who are left with classic view will be gradually moved to the new one very soon.
Nov 20, 2014 | Google Computers & Internet
How to clean bosch washing machine classic WAE24270AU?
Not sure what you ,mean, since when you wash clothes, that cleans the washer too from the detergent used to wash the clothes.
Sep 19, 2012 | Bosch Washing Machines
I have this card on my current system...Windows 98........Will I be able to use it on a new Windows 7 system?
If you mean will this card work on a modern PC..NO
It uses a PCI connection, then came AGP, and now the standard is PCI-express, and we are up to Version 3 i think.
So unfortunatly this card will not run on a modern motherboard, and Windows 7 will not run on a motherboard that this card would fit.
A modern card costing £40 or so would outperform that card many times over
This card had 16mb ram, you will find it hard to get a new card with less than 256mb
Jul 29, 2010 | Appian Graphics Jeronimo Pro Graphic Card
My monder 2 has ciercl lines arond the edg and now it is not working
I assume you mean modern 2, as in Modern Warfare 2. Using details will help us help you alot easier. Purchase some scratch out disk cleaner, or as I prefer, you can buy vehicle rubbing compound, buff the scratch out with a terri cotton cloth and, pretend like you are sanding it, which is what you are doing on a fine scale. Use a clean cloth to clear it off once you rubbed it in in smooth circles. It is recommended to wipe from the center out, but is way too time consuming. Now play the disk once you have it looking smooth.
Jul 12, 2010 | Microsoft Xbox 360 Console
My dryer not heatin up and dryin clothes hotpoint aquarius CTD00
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "sfGInKA3yp8" placeholder (do not delete)
We have a full video library on appliance repair video’s
Dec 30, 2009 | Hotpoint Dryers
Can't Change Code on MOD600 Alarm
Hi Michael, we have a MOD600 in our home also & need to reset the whole system - did you end up finding anything useful?
Apr 26, 2009 | Computers & Internet
LG washer (WM1832CW) error: UE
This is a problem with modern machines that have a lot of sensors - compared to older models that just used to bang about a lot.
The dampers on this machine may not have been 100% since day 1, so should be replaced. It is their job to reduce the bounce in the drum. As a "belt and braces" attempt, manufacturers often fit foam blocks to the sides of the drum, and there is no reason why you shouldn't fit larger ones to fill up the gap entirely. Foam is cheap, so just use silicone to attatch it either side of the drum - leaving just a centimeters clearance on each side.
This should solve the problem.
Dec 31, 2008 | LG WM1812C Front Load Washer
Ralph Lauren Polo Pima Cotton V-Neck Vest Sweater Logo
71 people viewed this question
Top Ralph Lauren Clothing Experts
ray gallant
Da Doc
Are you a Ralph Lauren Clothing Expert? Answer questions, earn points and help others
