Question about Garden
Powercraft chainsaw 38cc
Petrol engine starts and runs ok but the chainsaw blade fails to rotate
joboo1
  • 257 Answers
SOURCE: I have a powercraft chainsaw, do you know the
Hi, Most chainsaws use three mixes, which are 32:1, 40:1 or 50:1. Most are labeled somewhere on the saw. If you are unsure, use the 40:1 and watch the smoke, too much smoke use less mix, but don't run with too little, it is supposed to smoke some. If you see any oil coming from the exhaust it is too much and can't burn it all. Good Luck, hope this Fixsya!
Posted on Mar 05, 2009
  • 4088 Answers
SOURCE: I can't start Spear and Jackson 38cc Chainsaw
Remove the spark plug and test for blue, snappy spark. If nothing, try a new plug set for 0.020" gap. If still nothing, remove the cover from the flywheel side to expose the ignition module. Remove the ignition switch wire from the module and try for spark again--if ok, check for a grounded ignition switch or the wire itself. If still nothing, replace the ignition module. Use a thin business card for a pole gap between the module and the flywheel magnets. Allow the module poles to contact the magnets, then tighten the screws. Rotate the flywheel to remove the card. If you got spark in the first test, then place some fuel mix in the plug hole and try to start. You should get several pops. If ok, then work on the fuel system. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. If the machine is fairly old, you should check the condition of the lower chamber diaphragm in the carburetor--it may have become hard or cracked. Hope some of this helps!
Posted on Jul 01, 2010
  • 4088 Answers
SOURCE: powercraft pc40-38cc chain oil not getting to
Take the bar and chain off. Clean the engine area where the bar fits to and start the engine--oil should ooze out of the small port where you cleaned. If ok, clean the small drive-end oil passages that lead from the larger holes out to the chain groove on each side of the bar. They commonly fill with sawdust and dirt which plugs them. Clean the entire chain groove and check/oil the end sprocket if it has one. Reinstall the bar and chain, then start the engine and run the tip near some cardboard for a few moments--it should throw off a thin line of oil. Hope this helps!
Posted on Oct 17, 2010
  • 8 Answers
SOURCE: i have a gardentec 38cc
What kind of saw. How old? New Spark Plug? How old is the gas inside it? Is the air filter dirty? When you try to start it does it turn easy or is it a little stubborn or won't turn at all?
Posted on Mar 29, 2011
  • 5 Answers
SOURCE: I have a Wolf Gardenline
If you dont know use 25/1.
Or buy a 2stroke one shot bottle of oil, that does the mix for a gallon, most mower shops do it.
adam
Posted on Oct 25, 2011
The saw does not cut well at all. I've sharpened the blade and even purchase a new one. Still, I can barely cut through a 6" limb. Ideas?
It could be the clutch. If the chain slows down and the engine does not the clutch is slipping and needs to be replaced.
Sep 23, 2013 | Craftsman 38cc 16" Gas Chain Saw
Poulan 38cc wont start
quick check would be to pull muffler from engine check the screen if the screen is ok start engine if it starts without the muffler the muffler needs to be replaced.if it still dont start do pressure and vaccum checks on carb.
Jan 28, 2013 | Poulan Garden
I have a Wolf Gardenline chainsaw WPCS-38CC - what should I use as the oil to petrol ratio?
adam
Jun 05, 2011 | Garden
I have a gardentec 38cc petrol chainsaw which wont start
Mar 29, 2011 | Garden
Can anyone help with fuel mix and starting instructions for McCulloch 2214av chainsaw please
Ok, always use good quaility teo stroke oil, from a manufacturer who actually produces a chainsaw, ie Husqvarna/Stihl/Jonsered etc, all of these oils should be run at 50-1, avoid oil makes you have never heard of.
Starting instructions are as follows, switch the red ignition switch too on ( up ) depress the primmer bulb as many times as it takes to 3/4 fill the bulb ( you cannot flood the engine if you over prime, it is better to over prime ) pull the blue choke fully out, crank the engine until it fires once ( it will only fire once, do not continue to crank the engine after it first fires with the choke still out ) now push the choke fully back in, crank the engine until it fires up and runs on fast idle,now blip the throttle trigger to diss engage the fast idle position, the saw should now drop down to idle.
Regards
Jan 31, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
POWERCRAFT PC40-38cc.THE CHAIN OILER DOES NOT APPEAR TO BE WORKING! NO OIL IS COMING OUT THE SMALL HOLE IN THE HOUSING THAT THE BAR IS CLAMPED AGAINST, WHEN I RUN THE ENGINE WITH NO BAR AND CHAIN...
It would appear that you must 'go under the cover'. Look for a damaged oil line or split oil tank. The oil pump may have come loose from it's mounting. Be sure to check the oil filter for plugging. Hope this helps!
Dec 21, 2010 | Garden
Powercraft pc40-38cc chain oil not getting to chain manual is lost is there a simple fix?
Oct 17, 2010 | Garden
Jun 30, 2010 | Garden
Poulan 18" Chainsaw - Motor runs fine but blade stopped spinning
Chain may be locked in the bar. Caused by low oil flow to chain. You will probably have to remove the bar and blade. Then try to rotate the sprocket, if it will not rotate you may have to replace or repair the clutch. with the blade off try starting the saw and see if it is oiling. There is a small hole in housing that oil should be visible coming out at a fairly good rate. If not you will either have to open orifice in the housing or repairing the oil pump.
Apr 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a powercraft chainsaw, do you know the petrol / oil ratio ?
Mar 05, 2009 | Garden
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
