Question about Garden
Itt marlow model HX73SC
Where can i find user instructions and spec. for itt marlow pond pump, model HX73SC.
5 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: I have an ITT marlow bath spa pump which runs fine
If this motor is not turning then you will likely need a new motor. it has brushes inside the motor like a cordless screwdriver.
There are no parts for it. you will need to find another one.
http://www.uspartscenter.com/index.asp?PageAction=PRODSEARCH&txtSearch=nr2ac&btnSearch=GO&Page=1
Posted on May 08, 2009
uspartscente
  • 717 Answers
SOURCE: What is the wiring sequence for itt marlow sd 100
universal wiring on the Gemini pump since it works 50 Hz or 60 Hz
black=hot
white=common
green-ground
Posted on Aug 19, 2009
aquaman987
  • 927 Answers
SOURCE: Finding a replacemnt motor/pump for my Swirl-Way.
R150VS-19 - Gemini Plus
Call these people, see if they carry a replacement for the pump that you have.
Gary
Posted on Feb 21, 2011
uspartscente
  • 717 Answers
p, li { white-space: pre-wrap; }
This Pump & Control you have is no longer being made. It hasn't been made for over 5 years. You will need the following items: • new pump • air button • air tubing You will have to change the control on the tub to an air button. You will now only have on/off options instead of the multiple speed you currently have. The link below shows the replacement pump and just under that shows an Air Button you can use and get some air tubing as well.
http://www.uspartscenter.com/ittmarlowgeminiplusiinr4a-c15hp.aspx
Aqua Glass whirlpool with a Pentair pump wont turn on.
the pictures are not showing up. Sounds like maybe you have an ITT Marlow pump that has a circuit board on the back of it.
What model number pump do you have? I believe what you tell us here is model number R150VS11-C
If this is the case then what you have is a control with a knob on the top of it that controls the 6 speeds.
The control & "VS" series pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system includes the following items:
• New 1.5 hp Pump
• AirStreme Control box and topside control panel
You will change everything from the old system to what comes with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/airstreme_system.aspx
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Mar 26, 2013 | Home
Finding a replacemnt motor/pump for my Swirl-Way. Failed pump is an ITT marlow, 11.5 amp. Mo: R150VS-8-C, Spec: 0094C00C Any help would be appreciated
Feb 21, 2011 | Home
This is an older beckett pond pump about 550 gph. The impellor will not turn unless you give it a spin . Could it be the capacitor ?
check bearings may need to be lubed then check motor amp draw if within specs then test cap if weak or not holding charge replace
Mar 25, 2010 | Beckett Water Gardening Beckett Statuary...
What is the wiring sequence for itt marlow sd 100 bath pump in uk (colour code of wiring?)
black=hot
white=common
green-ground
Jul 10, 2009 | Home
I have an ITT marlow bath spa pump which runs fine until the pump is attached when it wont start. It just sits and hums until I give the impeller a spin. Any ideas?
Apr 26, 2009 | Home
Looking for specs
You can get from BJ Hydraulics 269-623-6743
Jan 07, 2009 | Danfoss Sundstrand-sauer-danfoss...
Drive systems difference
Magnetic Drive: In a magnetic-drive pump, an electrical charge creates a magnetic field that causes the magnet on the impeller to rotate and pump water. Magnetic drive pumps are completely sealed and do not require lubrication. Because they do not contain oil, magnetic drive pumps are safer for ponds with fish as oil leaks do not occur. This type of pump does not generate high head heights, meaning it is unable to lift pond water vertically, which you might need to supply water to a fountain. Work best in cleaner environments with little or no debris Highly efficient, cost-effective operation Since they have no seals to wear out, they require little maintenance Occasionally clean the impeller and its chamber to ensure efficient operation Direct Drive: Direct-drive pumps have an enclosed motor that is powered by electricity, which turns the impeller shaft. Direct-drive pumps achieve significant head height so they tend to work well for fountains or waterfalls. Some models seal the motor in an oil-filled shell with seals around the cord and impeller shaft. These are risky to use if you have a pond stocked with fish as there is an ever-present danger of water contamination if a leak occurs. Many newer pumps, however, feature alternative lubrication over oil that is safe for fish. Look for oil-free models if you house fish or other aquatic life in your water garden. Typically more expensive to operate Ideal pump type for fountains or other accessories Pushes water rather than pulling it Not easily repaired by the user
Aug 27, 2008 | VIA Aqua Pump 4900
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
