Question about Haier hwr10xc6 Air Conditioner
Water blows out of vent and collects at the bottom of the air conditioner, it does not seem to drain properly and I do have it slanted back to drain outside.
  • 1 more comment
  • Anonymous Jun 08, 2008
    what i E1 code on air conditioner
  • fensalir Jun 08, 2008
    I have the same problem with water blowing out of the vents. I do not have a tube to drain the water. The book says it is normal to hear water sounds and never drill holes in the bottom of the tray under any circumstances. The unit is tilted back, but after a few hours, water is spewing from the vents. Very frustrating and I have only had it 1 day.
  • hthrmre Jul 20, 2008
    every time it rains tons of water blows out and soaks our couch. we have tried tipping it back that doesnt help it has so much water in it.
I bought this lovely piece of sh*t for $200 dollars and it has done well over $200 worth of damage to the wood around the window and to the wall. We have to tip it backwards about twice a day to drain the water and it still drips out the front like crazy. I was unable to contact Haier at first and recieved automated responses on the phone and wasnt able to talk to an actual person. I gave up on that and lived with it for a few weeks and I finally got sick of it and spent about 45 minutes online looking for the phone number to contact them (I also found tons of complaints about this problem). So I decided I dont want this junk in my window and told Haier that on the phone. They told me to try to return it to the store I bought it at and if they wont take it back to call them again and they will have me cut the power cord and peel the stickers off and send that to them and they will send a replacement. THANKFULLY those idiots at Haier were dumb enough to put a decent warrenty on their faulty products. But I'm guessing those idiots are also dumb enough to send faulty products out as replacements too.
Posted on Jul 16, 2008
  • StupidHaier Jul 16, 2008
    I've actually only had this AC for 2 weeks. Sooooo much of a hassle I guess it seemed like a month or two.
    Problem Solver:
  • 19 Answers
Check that the small pipe at bottom of drip tray is inserted corectly and is unblocked.also check that the freon gas level is correct.
Posted on Nov 05, 2007
Water is setting in the air box and coming out onto counter.
find the drain line and blow out from either top or bottom, spiders love to web in them
Jul 12, 2014 | Dometic Rooftop RV Air Conditioner
Where is the drain pan drain hole on the bottom of the Fridgidaire FAC 127S1A air conditioner?
Good Morning Friend,
I understand you want to know where the drain hole is on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, instead of draining. The drain hole is located beneath the compressor. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire FAC127S1A Air Conditioner
How do I clean the condensation drain on my Fridgidaire fac127s1a?
I understand you want to know how to clean the condensation drain on your Frigidaire air conditioner, model# FAC127S1A. I see that the drain seems to be blocked, as water is collecting in the drain pan, and beginning to leak from the front. The drain hole is located beneath the compressor. You would have to get underneath that to clean the drain. You might want to try tilting your air conditioner slightly to the outside, to allow better water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
My Frigidaire Window Ac Unit is Collecting Water on the Styrofoam Thats Facing Inside The Home By The Vents,Why Is this Happening?
tilt your ac down on the outside,so it will drain properly,if that doesnt help,pour some bleach in the water inside to get rid of mold that clogs the drain
Apr 18, 2017 | Heating & Cooling
I have a sharp window AC unit, model af-609x. does it have a drain hole? there is no water coming out of it, but when we take it out of the window we get soaked from water somewhere inside the unitl
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
Jul 22, 2011 | Sharp AF-M609X Air Conditioner
Water is blowing out the front of my unit and collecting on bottom front. no water draining out the back drain.
Check to see that it is tilting outward. Use a level and should be 1/4 bubble backbobicehouse_28.jpg
Jul 12, 2011 | Heating & Cooling
Water won't drain out of the unit during high humidity
mcdevito75 here Yes they are suppose to drain from the part that is out the window, double chek the bottom of the A/C unit for a clear drain hole in the section of the unit that is outside the window.
Jun 24, 2010 | Fedders A6Y18F7BCOM Air Conditioner
It seems it's collecting water in the tray and blowing it out through the top vent, dripping from the bottom inside the house and is making a sound constantly like the fan is hitting water as it blows.
AC units do take the humidity out of the air and water collects in the bottom. The unit should be tilted slightly downward on the outside so that the water runs outrside. Make sure the drain holes are clear. The pinging noise is common, the fan is hitting drops of water, nothing to be concerned about
Aug 19, 2009 | LG Electronic Window Air Conditioner
Water collecting in the bottom tray and, at time, pouring out
The condensate drain is probably plugged w/dirt. You have to blow out the drain w/ some pressure to clear the drain.
Apr 15, 2009 | Heating & Cooling
Sunbeam air conditioner
It is normal for water to collect in the lower base of an air conditioner. See the section entitled: "There is water sloshing around inside." If water leaks out the front it is usually because the unit is tilted forward in the window frame. All air conditioners should be installed so they tilt slightly back to allow for proper removal of the condensation collected.
There is water sloshing around inside All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
if this helps please give me a fix ya
Jul 14, 2008 | Sunbeam Heating & Cooling
Haier hwr10xc6 Air Conditioner Logo
265 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
