Epson Perfection V500 Flatbed Scanner Logo
Posted on Mar 14, 2009
Epson V500 scanner will not scan film
It starts to scan and stops and the status light flashes red. my operating system is Windows VISTA
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1338
Points
You're problem is Vista, not the v500!
tip
Fix Red Flashing Light on Epson V500 Photo Scanner
Try moving any excess film (if your strip is longer than the holder ie scanning medium format film cut too long to fit the holder) to the other end of the holder so it hangs out of the end where the controls are on the front of the scanner.
The pdf button does not work
Make sure Epson Scan and the Epson Creativity Suite are installed correctly. See the Start Here sheet for instructions.
  • Make sure your Windows system is set up for scanner events as follows.
  • Windows Vista:
    Click sw_startbutton_1_er.gif > Control Panel > Hardware and Sound > Scanners and Cameras, or click sw_startbutton_1_er.gif > Control Panel and double-click the Scanners and Cameras icon. Click your scanner's icon, then click Properties. (When you see the User Account Control window, click Continue). Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows XP:
    Click Start > Control Panel > Printers and Other Hardware > Scanners and Cameras, or click Start > Control Panel and double-click the Scanners and Cameras icon. Then right-click your scanner's icon and select Properties. Click the Events tab in your scanner's Properties window and make sure Take no action is not selected. Also, make sure the desired button is selected in the Select an event list box, and Start this program is selected.
    Windows 2000:
    Click Start > Settings > Control Panel, double-click the Scanners and Cameras icon, then select your scanner and click Properties. Click the Events tab in your scanner's Properties window and make sure the Disable device events check box is not checked. Also make sure the desired button is selected in the Scanner events list box, and the desired application is selected in the Send to this application list.
  • In Mac OS X, make sure you did not install the scanner software in Classic mode.
  • Epson Perfection V500 Photo Scanner
    Epson v500 flashing green light
    I have the exact same problem, sometimes it works and it starts warming up, but most of the time it just shows a green light and no response.
    4helpful
    I'm trying to install my new Epson Perfection V500 Photo Scanner. I followed the instructions. The software installed . When I turned on the switch a loud grinding noise occurred and t I get an...
    Its the lock mechanism under the lid , lift the top to the scan bed and look at the lower right hand side of the inside of the lid there is a grey swithch , move it to unlock! Voila , fixed.
    Can't scan more than one page under one file
    you need to check for updated drivers from the manufacturer's website as the "old" drivers may not be completely compatible with windows 7.
    this often happens when changing operating system to a newer OS
    4helpful
    2answers
    WANT TO DOWNLOAD A USER MANUAL FOR THE EPSON V500 SCANNER
    Epson Perfection V500 installed. My computer recognizes it and diagnostic note says all okay. B ut when I turn on the power of the scanner, the grren light comes on in the front for about 15-20 seconds and then the scanner makes a loud grating noise and the green light turns orange and keeps flashing. No scan is attempted. TGhe noise sounds like something that should be moving can get started -- but nothing moves when you look at it. Should I take it back where I bought it?
    17helpful
    3answers
    Epson Perfection V500 photo scanner, carriage unit unable to move
    I have had the sam problem on 2 of the same scanners. Open the scanner cover and slide the transparency unit transportation lock to the unlocked position. Then close the scanner cover.Power it on and there you go.Somehow this little switch can get moved and there is the grinding noise and not working.
    11helpful
    2answers
    Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
    You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
    Top Epson Office Equipment & Supplies Experts
    Grand Canyon Tech
    Grand Canyon Tech
    NH TECH
    Level 1 Expert
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
