Mitsubishi hd1080 series tv, about 7 yrs old was
Mitsubishi hd1080 series tv, about 7 yrs old was working fine but now picture is distorted like 3d and black box appears? What's the problem and can I self fix or call tech?
    Top Expert:
  • Televison & ... Master
  • 74,377 Answers
It sounds that the convergence circuit has failed. It is a skilled work to make it right. If you have sound knowledge in electronics, you can do it by yourself. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
  • 1694 Answers
SOURCE: Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Posted on Dec 26, 2007
  • 1153 Answers
SOURCE: Mitsubishi HD1080 60in TV
First do a self test diagnosis. you can search Mits tv or read my solutions.
Posted on Mar 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Projection TV HD1080
you need to replace your convergence ICs. Post your model number of your set, and I will post the correct stk numbers and a link where you can get new ones.
Posted on Apr 16, 2008
Ecollier2012
  • 3459 Answers
SOURCE: convergence problem?
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Jan 27, 2009
Slinteriors
  • 8617 Answers
SOURCE: MITSUBISHI HD 1080 series
most likely the convergence Ics have failed. Check F9a04 and F9A05 pico fuses if they are blown you will need to replace them and the convergence Ics.They are located on the center board they are green and look like resistors without the color band. see the photoa193b32.jpg82b89b8.jpg
Posted on Feb 09, 2009
My Mitsubishi HD1080 series screen is coming inward from the top & bottom.. and occasionally red & green lines or black lines will flash through it... It started out just being inwards once in a...
You have either bad convergence ICs or just bad grounds on the IC. I would go ahead and replace the ICs and check those small ohm resistors, as you have to pull the signal board out anyway. For futher instructions see the website www.TvRepairKits.com. They may have what you are looking for. Be sure you have the TV model number next to you. Thanks for asking and show a few hands of support!
Nov 07, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Red and green
Replace both of your STK ICs they are big black ics will have part number on them STK392-570
Call Mats 1-800-628-1118 Parts are 10.95 each
Dec 30, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-A55, HD1080 Series TV picture scrolls horizontally
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Mar 05, 2017 | Televison & Video
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
Mitsubishi WT-A42 projection 42" HD1080 series
It sounds like your regulator circuit is defective. Not an expensive repair, maybe $200.or a little more.
Apr 08, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Mar 10, 2008 | Mitsubishi VS-60609 60" Rear Projection...
Picture distorted and blurry with color
bad convergence amp ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Looks like 3d picture
Sounds like the convergence amplifier ICs . What kind of TV and what model number and I will be better equiped to help you.
Jan 13, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
