Question about Nova Kool RS4600 119L Two Door Side By Side Refrigerator RS4600 DC Only
Warm right side
Right side is not cold
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
Heater work on one side
Right side blend actuator bad or system recalibration required
Mar 10, 2014 | Cars & Trucks
Getting cold air only on right side of heater assy, hot air on left side
you most likely have a bad blend door motor, or the actual door is broken inside the heater box. Jeeps used to have this issue, the door shaft snaps and only half will work. If you can turn from hot to cold on the side that's warm, then that's most likely what is going on.
Dec 07, 2013 | 2009 Dodge Journey SXT
I have a side by side double door fridge. My freezer is cold and working fine but my fridge side is not getting cold.
check yor damper door, it's the little door at the top and or bottom of the fridge insid near the top and or at the bottom behind the crisper drawer when working right they open to let cold air in from the freezer and warm air out. top one cold in, bottom one warm air out.they work on a sensor/relay when the freezer fan goes on they open when cold air is needed.
Mar 12, 2011 | Jenn-Air JCD2389G Side by Side...
Cold water is leaking on to hot side causing luke warm water
i have a 7570 salora that took the top off and i can't get it back together right
Feb 19, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Passenger side only blowing cold air.
You need to replace the "blend" door actuator motor on the pass side. I recommend getting that from your nearest gm dealer to ensure proper fit. When you adjust the air from cold to warm to hot, the blend door moves to direct the right amount of cold, or warm, or hot air your desire on that side of the vehicle
Dec 04, 2009 | 2000 Buick Regal
No cold air on the right side.
Designed that way . The fan stops , so that warm outside air , is not sucked in by the fan , and circulated thru the refrig . The freezer door switch is what activates and de-activates the fan .
Nov 11, 2009 | Refrigerators
Driver Side ac Warm Passenger Cold
they actuator door is stuck or acuator motor is not working right sounds like it could be mixing warm air into get book at library and troubleshoot system!!! :)
Jul 06, 2009 | 2003 Chevrolet Impala
GE washer
if you are only getting hot water on warm setting possible bad inlet valve cold side ck wiring first just to be sure wire to cold side not loose
Jun 08, 2008 | GE WHRE5260E Top Load Washer
Nova Kool RS4600 119L Two Door Side By Side Refrigerator RS4600 DC Only Logo
16 people viewed this question
Top Nova Kool Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Nova Kool Refrigerator Expert? Answer questions, earn points and help others
