The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
This is typical. If the heating element is no longer working, the unit doesnt know to turn off due to the clothes still being wet. However, the timer has absolutely nothing to do with the heating of the unit. If the timer doesnt turn off the unit even when the time is short (example: 10 minute timed dry), the timer has a different issue. If you have merely set the dryer to dry the clothes (not a "timed cycle" to dry) then the dryer will continue to run as I have stated before. The dryer will run until the clothes are dry. Now, its time to address the heating part. Your dryer heating element has gone bad. It can be replaced if you are somewhat handy. You can pick one up from your local appliance store and it has simple instructions. Please make sure that you disconnect the unit from its power source prior to attempting any repairs. Safety First. You can also call someone to replace it for you and it shouldnt be too costly. Good luck on either option.
if you have timer on time dry and it doesn't move timer is probably bad, if you have it on auto dry or some say more or less the timer will not move if there is no heat
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Check the timer, and the sensor. Sounds like it is having a problem with the timer or sensor no noticing that the clothes are still wet. Please rate if satisfied. Thank you
Try this and let me know what happens.
TIP OF THE DAY To reduce the suction draft and drying time your drier and save some cash, remove the lint catcher and take it to the sink. Run water into it, if there is excessive pooling of the water (water not running straight through) then fabric softener is fouling the lint screen. Use a small brush and dish detergent to clean it and then shake off all the water and dry the screen. Remember this tip on future driers and you will make the dryer blower motor last much longer.
The timer naturally won't shut off till the sensors inside the drum no longer get a capacitance reading when the clothes are completely dry. The moisture control board relays power to the timer motor when it is sure the clothes is dry. The heating element could be broken.Unplug the dryer. Take the back off. Get the heater off and take a look at it. Check your vent pipe, if it has lint in it then your high limit is probably open. The fuse ain't broken because the dryer still runs. Both parts in the kit need to be replaced. because the big one is supposed to shut down at 250F the little one(high limit) mounts in the upper heater housing and gives up the ghost when the temp reachs 300F. The fuse mounted on the blower housing is rated to die at 350F. It is tied into the door safety switch, when it dies it is the same as if you opened the door. The dryer will not run. BTW: if you ain't got the $ to get a new limit you can reset it by banging it on the floor in a fit of rage. LOL
FIRST CHECK YOUR VENT IS CLEANED OUT THEN SEE IF TIMER MOVES WHEN PUT TO A TIMED CYCLE. IF SO MEANS VENT CLOGGED UP. IF STILL NOT MOVING MEANS TIMER CONTROL BAD. COST ABOUT 80-100 FOR PART. YOU COULD DO YOURSELF IF SOMEWHAT HANDI.
COULD BE ORDERED FROM SEARS PARTS DIRECT BY YOU.
OTHER WISE CALL SERVICER AND MAY COST 200.00 TO REPAIR. HOPE THIS HELPS
Jeff, almost sounds like a timer issue, but I was fooled on this once. Under the consol is a inline resistor from the main plug. If this resistor is bad, dryer keeps running in timed dry. Part number for the resistor is 3401076. Look it up on the web so you know what it looks like. Just splices in.. Catriver..post back.
