Question about HP Office Equipment & Supplies
Laserjet m1212nf Dial tone detection fail
SOURCE: mx700 fax connection problems
I can not received fax from my mx 700 when why answering machine is on.
Posted on Nov 07, 2008
  • 4340 Answers
SOURCE: Looking manual for my HP LaserJet M1212nf MFP,
You can get one from HP.com, I reccomend downloading the current install directions and software, all which should be for free. Follow the directions exactly, many HP printers only partially function if you plug and play.
Posted on Oct 20, 2010
viperuz
  • 82 Answers
SOURCE: unable to resolve "scanner error
it depends on you operating system. follow the instructions click here.
Posted on Jul 23, 2011
seeker5211
  • 1089 Answers
SOURCE: laserjet m1212nf mfp, getting "suppy
Supply memory error is referring to a defective toner cartridge. Actually it's the electronics chip that is attached to the cartridge. The printer gets toner information by reading the chip. Replace the cartridge.
Posted on Aug 13, 2011
ghost2233
  • 3606 Answers
SOURCE: load cartridge for HP Laserjet M1212nf
HELLO DOWNLOAD A USER MANUAL HERE:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&tmp_geoLoc=true&document=&product=3965849
THE FILE IS IN THE PDF FORMAT SO YOU NEED ADOBE READER TO READ THE CONTENT.
GOOD LUCK
Posted on Dec 02, 2012
I have a hp laserjet m1212nf its says memory full
Print or delit stored fax messages in memory..
Sep 25, 2014 | HP LaserJet M1212nf MFP Printer
Hp laserjet3015 when sending fax fax call report sez no dial tone
change from menu the dial tone go to link and see how to change dial tone HP Support document
Mar 13, 2014 | HP LaserJet 3015 All-In-One Printer
Memoy reset for HP LaserJet M1212nf MFP
Turnoff the printer.
Hold Cancel button and start/Copy button at the same time.
Turn on the printer.
Release the buttons when display shows "Permanent Storage Init".
Wait till the display shows "Ready"
Jan 10, 2014 | HP LaserJet Pro M1212nf MFP -...
Laserjet m1212nf mfp, getting "suppy
Aug 12, 2011 | HP Hewlett Packard LaserJet 3000dn Printer
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
No fax detected message
Hi
Please plug a regular phone into the wall jack and listen for a dial tone.
Connect a phone cord to the LINE port on the fax machine.
Guess it should work :)
Jul 12, 2010 | HP LaserJet CM1312 All-In-One Printer
My Dell 962 All-in-one printer cannot detect a dial tone.
Make sure that you the phone cable you are using is plugged into an active phone jack. You can take a phone from another room and test the jack.
If you get a dial tone with another phone on that jack, then try replacing the cable that you use to connect the AIO printer to the phone jack.
If that fails, the modem inside the AIO printer may be dead and it may be more cost efficient to just replace the whole AIO printer. Hopefully it's under warranty.
Sep 02, 2009 | HP LaserJet 3030 All-In-One Printer
Computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Printer can't send or receive faxes
Same problem here - I got it work:
- Error Correction: off
- V34: off
(both Menu -> Fax-Setup - All Faxes)
- detect-dial-tone: off
(Menu -> Fax Setup - Fax Send setup - detect dial tone)
:-) Stefan
Aug 30, 2008 | HP LaserJet 3055 All-In-One Printer
Trying to launch internet explorer.it gives me error 680.
680 - There is no dial tone.
All versions of Windows are affected by this error.
No dial tone: There are many possible causes of a No Dial Tone Error.
First, try testing the modem's ability to detect dial tone and to dial by using HyperTerminal with the direct to COM port connect method - see Using HyperTerminal. If you give your modem an AT&FX1 command, and then a dial command, dial-tone detection will be disabled; if you still do not get dial tone, the modem may not be installed correctly (especially if it is a PCI or soft-modem); or the cable from the modem to the phone-line jack may be bad or installed in the wrong connector on the modem - try another line cord, and make sure you are plugged in to the LINE - not phone - jack on the modem. Plug a regular phone into the phone jack on the modem and make sure it has dial tone. The modem may also be defective. Many new modems come with an electronic circuit instead of the traditional electro-mechanical relay used to take the modem off-hook. Some of these designs are proving less reliable; often, they will be 'stuck' in the off-hook position, so unplugging, the plugging in the phone cord may give dial-tone. If this is the case, the modem needs repair or replacement.
If the modem will blind dial (x1), but not detect dial-tone otherwise, the problem is likely to be in the proper selection of the Country in Windows->ControlPanel->Telephony or in improper installation of the modem or lack of support for your country in the driver you are using. Check to see if there are updated drivers for your modem.
If the modem dials properly with detection (x3) in HyperTerminal, but does not detect dial tone when using DUNs, the problem may be DUNs (check for upgrade or re-install) or the proper setup and modem selection for the DUNs connectoid.
For Embarq telephone service customers, this error can indicate that you have a message waiting in your voicemail. Embarq changes the dial-tone sound to a "fast" busy signal when a new message is present in your voicemail box. This "fast" busy signal can confuse the modem into thinking there is no-dial tone present on the line.
Jul 02, 2008 | Microsoft Windows XP Home Edition
23 people viewed this question
Seeker5211
Seeker5211
