Question about Garden
Toro lx500 not starting has new battery new selinoid and gas
2 Suggested Answers
goldenglove1
  • 144 Answers
SOURCE: i have a toro lx500
Check the belt on top of the mower deck. Make sure the belt didn't slip off or break.
Posted on Aug 04, 2010
Toro zero turn: clicks when trying to start. Battery is new and has 12.6 volts. Jumped across the solenoid and engine turns about one revolution then stops. Any suggestions?
If its clicking quiclky you say its 12+ volts so i will say you have a bad connection on the battery or on your selinoid. check both sides of selenoid.
Apr 05, 2017 | Toro Garden
What type of oil do I use in my Toro LX500?
In the northern US, I would use a 5W - 30 year round, or 30 in the summertime. Do not use "non-detergent".
In the southern US, I would use a 10W - 30 or 30 in the summertime. No non-detergent.
Nov 06, 2015 | Toro Garden
Toro zero turn mower does not want to start
i think that engine has a compression release arm on the camshaft f its not releasing it will be hard to crank over
Sep 27, 2012 | Toro Power Lawn Mower
Toro lawn tractor starting problem
both of the small wires to the solenoid go threw safety switches start with the one on the clutch/brake pedal
Jun 09, 2012 | Garden
My Toro LX500 is demon possessed. I'm certain of it. After 2 repair shops and $500, it still doesn't work. Everything was fine until all of a sudden, the gas pedal goes loose and the engine...
Gary, Sorry for your woes. I'm not a "Tractor" guy and I'm sure there are much better qualified techs on here for your question. However, I'll tell you what I know. By "Gas Pedal", I assume you mean the clutch. When you depress that pedal all the way, it engages some kind of switch (along with the brake), that allows your starter to engage. When you let that pedal out, it engages some kind of belt which allows the tractor to move. So I would check all that pedal linkage/switch/and belts first off. It sounds like you have a mechanical problem in there somewhere. Without looking at it personally, that's all I've got. Appreciate the personal 'reach out' though; You're my very first one of these. Best of luck to you and sorry I can't be of more help.
James
Oct 01, 2011 | Toro Garden
I have a toro lx500 riding mower. the blades won't engage.
Aug 04, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
Ride on lawnmower isnt starting.
You may have a bad starter - the solinoid is "clicking" but not engaging. Remove the starter and clean it up and connect it to 12 volts to check if can turn. If not then buy a new starter and replace it out.
Aug 03, 2009 | Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
