SOURCE: plastic lug securing paddle in drum have broken off
It is easy to fit.
To remove paddle ,grasp firmly and pull it towards you, then slide new paddle into slots and push firmly towards rear of. drum
You should feel it clip into place..
Make sure you get right paddle as there are at least 3 versions of drum paddles
Plz rate my solution.
Thanks.
SOURCE: Hotpoint WMA 22 drum not turning
Hi, common problem with this make of machine but easy to repair. Take off the lid and make sure it is un plugged from the mains...... You will need a pair of hook nose pliers to remove the carbon brushes from each side of the motor. They should be an inch long if not there is your problem.. Just replace and it will run.
Let me know how you get on..........
SOURCE: How do I replace Drum paddle on Hotpoint WF860 washing machine
To fit new paddle,line up the lugs on the paddle in the slots in the drum, and push firmly with both hands towards the rear of the drum, you should feel it click into place, make sure you fit it the correct way round.
Please rate my solution.
Thanks.
