Question about Garden
G1000 Wood lathe Manuals - Garden
4 Suggested Answers
  • 905 Answers
SOURCE: My powermatic wood lathe has
Hello Edmund,
Normally bearing noise will happen in both directions, forward and reverse.
You didn't mention the model # of the lathe itself, but here are few things that you can do to narrow the scope of the problem.
1) Your motor probably turns at the same RPM regardless of spindle speed. So, if your spindle is turning at say 150rpm, and you hear the click at the same speed as 500rpm, then the noise is likely coming from the motor, or the transmission.
2) Most motors also turn in 1 direction. Verify that yours follows this or not. If the motor doesn't reverse, then again, you are likely looking at the problem being in the transmission.
3) If the clicking noise is present all the time, then you can eliminate the tail piece if you don't have work in the spindle.
4) Try disconnecting the motor from the transmission, and see if noise goes away. If it does, then you should be able to rotate the transmission by hand, and possibly feel the noise as it occurs.
5) Otherwise, with the motor disconnected, rotate the spindle to see if you can feel the clicking noise.
6) A definite sign of bearing failure will be play on the input shaft, spindle, or an intermediate shaft. Check these and make sure that there is no lateral movement.
It would be best for you to contact the manufacturer and obtain a parts manual for your lathe. Then you are able to see how the lathe is assembled, as well as likely sources or areas that can be the source of your clicking noise.
Good Luck!
Posted on Aug 30, 2010
al_kupchella
  • 843 Answers
SOURCE: how can one use a
You need a phase converter. The link below is a a selection from Grizzly. You can also find them on e-bay. There are two types - static (no moving parts) and rotary (much more expensive). The rotary type give you full performance delivering true 3-phase power to your machine. But for a minor loss in power (maybe 20%) the static type does the job quite well - assuming you don't need all of the power that your 3-phase motor can deliver. Here's the link: http://www.grizzly.com/products/category.aspx?key=275030
good luck. Vote if you found this helpful. Al K
Posted on Sep 09, 2010
SOURCE: I need a manual for
I have the lathe and got a manual emailed to me from the jet people since it doesn't show on their web page. I just called them off the contact us link.
Posted on Sep 17, 2011
I'm looking for a owners manual for a ML618 wood lathe. I'm looking to see if it has more than one Chuck?
Most wood lathes, like most metalworking lathes, have a spindle that is threaded to accept a variety of fairly standard accessories including chucks and faceplates of various sizes and types to accommodate different types of work.
Any lathe that does not accept a variety of such accessories would be a complete waste of time.
Obtaining a manual for much imported machinery is almost impossible to obtain but most imported machines are close copies of industry standard machines and so generic information such as can be obtained from almost any supplier or experienced user is all that is required.
Oct 19, 2015 | Tools & Hardware - Others
I have a Ryobi ml618 wood lathe and need to know if they sell different chucks for it like a bowl Chuck
Ryobi Lathe Parts‎
www.wow.com/Ryobi+Lathe+Parts‎
Search for Ryobi Lathe Parts
Look Up Quick Results Now!
Oct 19, 2015 | Ryobi Drills
Where are the gears ?
I see no gears in the manual You can move the belt over to get a different speed if that is what you are asking.
http://content.wmhtoolgroup.com/assets/manuals/1352001_man_EN.pdf
Nov 28, 2013 | Powermatic 1352001 3520B 20x35" Wood...
Motor stopped while turning. It does have power but will not run.
Motor should have red push botton on back or bottom of motor. This is reset over load breaker . Should be out, just push in until it clicks.
Feb 15, 2013 | Powermatic 1352001 3520B 20x35" Wood...
My wood lathe is making noise
Thats a good thing, means you making chips. lol. What kind of noise exactly?
Oct 09, 2012 | Powermatic 1352001 3520B 20x35" Wood...
Manual for nu-tool wood lathe nwl 900
Hi had any one got a manual for Nutool NWL 900 also a face plate
Jan 27, 2012 | Tools & Hardware - Others
Need spare parts for wood lathe WTL12A not out of date. Any ideas
I am looking for an operating manual for the Draper WTL12A wood lathe,can you help ?
Apr 26, 2011 | Garden
Looking for info/ manual for a wool lathe
look under cwl12d clarke wood lathe manual. this has all the instructions that are almost the same as the nwl37-2 i have a nwl37-2 and this manual shows what should be there.
Jan 22, 2009 | Powermatic 1352001 3520B 20x35" Wood...
Garden Logo
210 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
