Question about Dell Latitude C640 Notebook
Screen turns dim
Whenever my laptops is on charging mode ie AC,my screen turns dim and dull..and turns normal whenever the charger is removed.please someone should help me out.
    President:
  • 317 Answers
Hold down the Fn key and press the UP arrow key when this happens.
Posted on Aug 07, 2007
    New Friend:
Omg thanks haha been fixxing up my "new" d630 had many issues with it trying to play basic games such as warcraft 3 the screen being dim was annoying^^... for others having issues with d630 gaming i suggest rolling back your display driver from A07 to an earlier A06 version you will no longer have random blue screen crashes.. also i8kfanGUI allows you to be able to control your fan to high mode which dramaticlly helps this model function properly and delays the dreaded "time to clean out the dust" time of year :p
Posted on Mar 29, 2013
SOURCE:
I have dell inspiron n5110 get charging problem sometimes then after a week my display becomes dim. I can able to see that my display is working with without brightness. I connect it to external display it...
Is the brightness ok if the charger is connected to the laptop and dull when the charger is not connected - also what operatng system are you using ???
Oct 13, 2013 | Computers & Internet
What is the life of my satellite l30-101 battery off the ac charger
Toshiba's line of Satellite PC laptops offers a variety of screen s that are customizable when ordered online. The laptops offer built-in webcams and backlit keyboards. Most Toshiba Satellite laptops use six-cell lithium-ion batteries that can last up to six hours. To reach that six-hour mark, you can use several tricks to maximize your battery's capacity.
Charge your battery completely before its first use. Check your user manual for the exact charging time required, which is typically at least 12 hours. Discharge your battery completely every two months. Allow it to drain fully before recharging it. Recharge it completely, for at least 12 hours before using it again. Remove CDs and DVDs from your laptop's drive when not in use. These drives spin when loaded, which can drain your battery unnecessarily. Set your laptop to hibernate mode when you need to take a break. This conserves more power than standby. Store your laptop battery in a cool place. Never let the battery sit in direct sunlight or leave it in your car on a hot day. For even longer battery life, remove the battery from the laptop which can get hot while in use when you are plugged in. Turn off your Wi-Fi connection when not in use. Constantly searching for a Wi-Fi connection can drain your battery faster. Work in only one program at a time. The more programs you have open, the faster your battery will drain. Unplug any USB devices, especially those that charge when plugged in, such as your cellphone. These will drain your battery quickly. Dim your Satellite's screen to conserve battery. Hold down your "Fn" key and tap "F6" several times to dim the screen. The "F6" key should show an open circle with small lines radiating out, to symbolize a dim display.
b>
Feb 12, 2013 | Toshiba Satellite Computers & Internet
Inspiron 1525 charging problem
Try the following steps to solve it:
it of googling on the web and finally found the solution here.1 Turn off laptop.2 Unplug AC power.3 Remove battery.4 Replace AC power.5 Turn on laptop, allow OS to boot.6 Once logged in to the machine, perform a normal shut down.7 Unplug AC power.8 Replace battery.9 Replace AC power.10 Turn on laptop, allow OS to boot. The battery should once again be charging as normal.If it can't still resolve this problem, try a new laptop charger or repair your laptop dc jack.
If you plan to be on a budget for your dell 1525, you may try the following third party charger:
Replacement Dell Inspiron 1525 AC Adapter 65Watt 19.5V 3.34A
Oct 20, 2012 | Dell Inspiron 1525 Laptop Midnight Blue
Toshiba laptop display goes dim
If you are operating on battery this is a power saving mode. Go into setting and see what the power settings are. Try running on charger and see if this still happens.
Oct 20, 2017 | Computers & Internet
My HP Pavillion Laptop is not turning on. Whenever I press the on button the tiny lightning sign under the screen flashes 3 times but the computer does not turn on!
The lightning bolt you describe is the laptop trying to accept a charge, I'd also look at the charger, if the led on the charger is blinking, there is a fault on the mobo charging circuit ( power not being able to complete a circuit)
If you are lucky it could be the powerboard button connection to the motherboard, remove the powerswitch cover carefully and check for broken or crimped connections.
If removing the battery and running on ac power alone will not work, you may have a faulty dc port, and will need to replace it ( cheap enough).
After that, the indications are that there is a more serious fault on the motherboard.
Jan 28, 2011 | Computers & Internet
Dim lighting
You need to configure the power options.
Go to control panel and then click on power options.
Select advanced power options and there select the power mode as balanced or high performance.
Jul 20, 2010 | Acer Aspire 5100 Notebook
Laptop ACER Aspire 4920 Screen goes dim.
there is a configuration of each one of the three plans of energy, and there you can change the time the screen is on when plugged or unplugged, the brightnes, and some stuff more like the wireless. you have to go to "energy option", or something like that... mine is in spanish. and then under each option is the configuration. good luck!!
F.R.C.
Jul 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
I have a hp 6735s laptop that i bought recently and when the adapters not plugged in the screen keeps going bright for a second then dull how do i stop this?
So you mean the screen goes dimmer when you remove the AC POWER ADAPTER?
If so, then this is due to the POWER SAVER mode that most laptops use for when not plugged into AC.
In control panel (if using XP) there should be a POWER MANAGMENT or BATTERY MANAGEMENT icon or section. In here there are usually settings for what you want the laptop to do with regard to power under different scenarios (ie. No adapter, with adapter, etc).
In the settings there should be an option to turn off power saving mode when the AC adapter is not plugged in.
Mar 27, 2009 | HP 6735s Notebook Laptops
Screen flicker (only when ac power is removed)
Hi there
yes its the graphic drivers that needs installing, i must also tell you that when you remove AC power from the laptop it will go into power saving mode and you will notice that the screen dims a little, this is normal and nothing to worry about
Kind regards and please don't forget to rate us
Dec 12, 2008 | Acer Aspire 4315 Notebook
Thanks
Well, the battery is it's own separate module. The battery most likely will just pop out of the laptop wherever it is.
The AC cord is a power supply ran from a normal household outlet. It also charges the battery. So, you can both charge the battery and run the laptop at the same time. The battery is probably only going to be used on the run anyhow. :) So, you can just use the AC cord whenever you have access to an outlet.
Sep 14, 2008 | Dell Inspiron 1501 Notebook
Dell Latitude C640 Notebook Logo
174 people viewed this question
Ekse
Clive
Clive
