Mitsubishi xd6800u will not fully turn on
Shuts off while driving
When was it last fully serviced? Its 25 years old? You may need to invest in some TLC for your poor old Mitzi. Good to see its still alive though after 20 + years
Jul 21, 2014 | 1991 Mitsubishi Mighty Max
Hello, my Mitsubishi XD28U doesnt turn on, it keeps blinking Red and green (in the power led) and ambar in the status. What might that be?
This means that an abnormal condition is present in the machine.
Contact mitsubishi.
if it were just the red and green blinking on the power, then that is the lamp cover not on fully.
anyway check the lamp cover is fuuly in, and check the filter cover and filter
Feb 28, 2011 | Mitsubishi XD280U Projector
I own a 2001 Mitsubishi Mirage, ES. Battery is fully charge and car won't turn on. I'm able to listen to a slight click and it doesn't crank.
Even if the battery is fully charged, a dirty or loose connection could cause an interruption in the current flow to the starter. Make sure all connections are free of corrosion and properly tightened.
If, after doing this it still clicks, then your problem may well be a bad solenoid on the starter.
If this turns out to be the case, you can purchase a warrantied rebuilt (or new, if you prefer) starter at your local auto parts store.
Be sure to remember, if you change the starter, to disconnect the battery until the installation is complete, so as to not cause a short if a tool inadvertently touches bare metal while installing.
Jan 30, 2011 | 2001 Mitsubishi Mirage
I have 2 units of 2 hp mitsubishi split type air-con. both units are having problem with timers. the timer will blink after 20 to 45 minutes of operation and then it will turn off by itself but the light...
the timer may have been activated at installation or by someone not fully conversant with the operation
use the remote and follow the instructions in the owners manual to turn the timer off
Sep 06, 2017 | Mitsubishi MSZ12UN Air Conditioner
Engine idling rpm is erratic when cold. low power during startup. fuel mixture is very rich.
ajust your mixture screw on your carb turn it in fully then unturn two and half turns that should get your mixture ok you mat need to fine ajust later
Nov 11, 2009 | 1996 Mitsubishi Eclipse
My car will crank over but will not turn completly
check the coil and other high voltage cables
Sep 27, 2009 | 2002 Mitsubishi Galant
My 1998 Mitsubishi galant won't start. it was to be started but developed this problem recently. I hear a loud click on the first turn of the ignition and clicking noise gets smaller if i continue. the...
Check and clean the ground on your battery cable. Also charge battery even if is new. Starters use all the amperage a fully charged battery produces to turn that starter. Make surecables are clean and tight :)
Sep 07, 2009 | Mitsubishi Galant Cars & Trucks
My 2001 mitsubishi Gallant power steering went off while driving
Check the power steering pump. Make sure that it is working correctly. You can have it checked at autozone or kragen . That is most likely your problem is that the power steering pump has gone bad
Jun 01, 2009 | 2001 Mitsubishi Galant
22 people viewed this question
jasbo
jasbo
