Question about LG 50PQ10 50 in HDTVReady TV
Plasma tv usb port
It have a "usb service only port" and i tried the simultaneous menu press and the simultaneous ok press from remote and tv .. But nothing appear .. I cant get the service menu .. I need to use this port for videos and music
5 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: i have a 2006 samsung
Plasma tvs do not have a backlight. That being said this is a problem with the sustain board. I believe it is where the blown capacitor is. I would like you to turn off the set, unplug it from power and take off the back cover. Locate the boards labelled X-main and Y-main. See if you can find anything blown on them and let me know
Posted on Dec 03, 2010
Dumaine
  • 112 Answers
SOURCE: I have a LG 42LD450, I read and saw videos online
I used a Magnavox MG500S, some simply use a Comcast Cable remote, some just use a universal from radio shack......all in all....once you get the remote programmed to the TV you have to find its "Magic Button" to open the password screen........then enter code.(0413) for the remote I used. Some were using code 0000. All in all I guess it depends on the remote used.......sorry I cant help anymore than that.........then I can if you find the same remote I used!!!
Posted on Dec 11, 2010
SOURCE: I have the lg 42ld450
Hi my nameis Mike Houston of DISH Network and I see you are trying to play movies throughyour LG TV. I will send a link to help program the remote to the LG TV, http://www.dishnetwork.com/SupportSection/power-scan-instructions.If the DISH remote is programmed to the TV and you still can not get into theService Menu you will need to refer to the TV manufacture, I will send the linkto help with that, http://www.lg.com/us/support/index.jsp.
Posted on May 09, 2011
gopakumarg43
  • 75311 Answers
SOURCE: I want to know how to open the service menu on my LG tv
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Check this link too.
Posted on Oct 31, 2012
Cat stepped on remote TV went black have sound but no picture i have tried every menu option?
Try doing this:
Self-check indication only:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [OK] button on the remote control
for more than 3 seconds.
Self-check indication and forced to factory shipment setting:
Produce TV reception screen, and while pressing [VOLUME ( - )] button on the main unit, press [MENU] button on the remote
control for more than 3 seconds.
9.1.2. Exit
Disconnect the AC cord from wall outlet.
This is straight out of the service manual.
Regards,
Joseph Van Buren
Aug 01, 2014 | Panasonic TH-42PX75U 42 in. Plasma HDTV
PC HDMI W4201C 42 CONNECTION
Hi Caleb,
To resolve this, please perform the following steps:
  • Turn off the TV and unplug the power cord
  • Connect the HDMI cable to the HDMI port of your laptop.
  • Connect the other end of the HDMI cable to the HDMI input on your HDTV
  • Connect your device using the HDMI connector (Refer to image below)
  • Plug in the power cords for the TV and Xbox
  • Turn on your TV and Xbox
  • Enter the TV Menu and select Setup (Refer to the image and steps mentioned below)
  • To enter the TV Menu, press the Menu button on Remote control
  • Use the left and right buttons (volume buttons) to move between the icons
Select correct input source
  • Input allows you to select the proper source based on how you have your TV and video equipment connected.
  • Press Input on the remote to go directly to the Input Select menu
  • Select HDMI 1 or HDMI 2 (Refer to image below)
If the TV does not work, please follow these steps:
Verify the PIP/POP/PBP function is disabled ( PIP/POP/PBP Compatibility - The only input sources that cannot work together are HDMI with HDMI)
  • Press the Menu button on the remote control or TV
  • Use the Left and Right arrow buttons (Vol +/-) to select PIP/POP/PBP, and then press <Enter>
  • Use the Up and Down arrow buttons (Ch Up/Ch Down) to select PIP/POP/PBP/OFF
  • Use the Left and Right arrow buttons to select Off
If issue is still persists, please move to the next step
Reset the TV current input to its default configuration
  • Use the left and right arrow buttons to select Setup, and then press Enter/OK
  • Use the Up and Down arrow buttons to select Factory Reset, and then press Enter/OK
  • Select Current Input Setting and press Enter/OK
  • Re-check the TV functionality
Feb 19, 2014 | Dell W4201C 42 in. Plasma HDTV
Both hdmi ports dont work Vizio 50" model P50HDM
Reset Vizio TV default:
1. Press the MENU button on the remote. The on-screen menu is displayed.
2. Use the Arrow buttons on the remote to highlight the Help icon and press OK. The Help menu is displayed.
3. Highlight Clear Memory (Factory Default) and press OK.
4. Enter your parental control passcode. If you have not yet set up a parental passcode, enter the default, 0000.The TV displays, "Are you sure you would like to Restore Defaults? This will erase any custom settings."
5. Highlight Yes and press OK. The TV displays "Memory is being cleared. The TV will reset shortly."
6. Wait for the TV to turn off. The TV will turn back on shortly afterward and the Setup App will begin.
Feb 12, 2014 | Vizio P50HDTV10A 50 in. Plasma HDTV
TCL Blue Screen "No Media"
I HAVE FOUND THE ANSWER!!!! I just bought an TCL TV last night and was given the wrong remote. Screen was stuck on "no media" screen BUT I noticed that when I turn the tv on and keep pressing the menu button, the menu screen would pop up for a half second before the no media screen popped up again. So I knew it was able to access it. SO, it took a few try's and with no exact method I turned the tv on, waited til I saw the TCL logo and then simultaneously pressed the menu and channel up button repeatedly. It will open the menu for you and allow you to move between the input channels!!!! It WILL take a few tries to catch it but it worked!!! Your welcome!!!!
Dec 29, 2012 | Televison & Video
We need the device code of the panasonic Tc42px24 plasma HDTV thank
Hello
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save
OK.
Feb 13, 2011 | Panasonic Tc42px14 42 in. TV
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
Power light blinks 13 times
need replaced A-BOARD
Manufacturer Panasonic Part Number TNPH0716ABS Description A- BOARD
After the installation of a new A board, unit has the characters "CHK" on screen. The usual reset procedures of [VOL -] and [MENU] or [OK] or [SLEEP] will not get rid of "CHK".
1. Enter the service mode by holding down the [VOL -] button on the TV (main unit) and simultaneously pressing the [INFO] button on the remote control three times.
2. Press the number [2] key on the remote to highlight [SRV-TOOL].
3. Press the [OK] button on the remote control to select [SRV-TOOL].
4. Use the [DOWN ARROW] on the remote control to scroll down to [PCTC].
5. Use the [RIGHT ARROW] button on the remote to open the box to the right, then press and hold down the [MUTE] button on remote to display Time/Count.
6. Press and hold the [RETURN] button on the remote control until the TV turns off.
7. Immediately press and hold down the [VOL -] button on the TV (main unit) and the [MENU] button on the remote. The TV should come up in the Self Check mode.
8. Remove AC power.
Jul 06, 2010 | Panasonic Viera TH-50PZ80U Plasma TV
LG 50PQ10 50 in HDTVReady TV Logo
26 people viewed this question
Computer Repairing
Computer Repairing
