Toshiba 50a62 no color, just black and white. Could I just replace the rgb bulbs to fix the problem?
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
No color is not the problem with its bulb. It must be a problem to its chroma processor section circuit. If you have knowledge in electronics, you can do the repair by yourself. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electric shock. Instead, contact any experienced service technician, or the nearest service center. If you wish to get more details, check this site linked below. Pull up older posts there. Check the site with patience, as it has over 2380 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window. http://electronicshelponline.blogspot.com/
Posted on Apr 30, 2013
5 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: rear Projection Tv Problem! black and white... Please help
go into menu turn color off see if you have a black and white picture if not adjust red,green, and blue screen drive on controls in back of tv you have red, green, blue it will have focus /screen controls cover each tube do one at a time blue focus and screen drive adjust to clear blue picture do all 3 tubes, then adjust them to where you have a black&white picture once this is done turn color controll back on.Thank You for using FixYa and Have a Nice Day.
Posted on Feb 05, 2008
  • 108 Answers
SOURCE: Blue doesn't work
replaced the blue crt drive pcb or the large transistor on the crt driver pcb.
Posted on Jan 08, 2009
  • 33 Answers
SOURCE: black and white picture only
The color wheel is not the problem. If the spinning color wheel is impaired in its RPMs it will cause picture distortion, not black and white picture. If the color wheel looses any of its color fins, like if it is broken, there will be a loud vibrating noise inside the tv which you did not mention. Also if the color wheel is broken and doesn't spin, the tv will not start up.
The likely problem is on the digital control board or the power supply and should be referred to a local repair shop for repair.
There is an outside chance that you will receive color if you experiment with using all of the different input ports to see if you can find one that will bring back color.
Posted on Apr 29, 2009
asnowman
  • 788 Answers
SOURCE: Toshiba Model No. 50A62 When the set is first
It sound to me like your tuner is going out. I would suggest that you contact a local service center to get the tuner replaced or just put up with it as long as you can.
I hope this helps.
Thanks
asnowman
Posted on Sep 21, 2009
How do I change from black and white to color
input source :Computer RGB (Digital) and RGB(Analog)
you should select the RGB(Analog)
Video ,select Auto
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 22, 2014 | Sanyo PLC XU35 Multimedia Projector
Just clicks want come on
there is a few things that can cause that 1 the bulb blew 2 the cooling fan quit or 3 the hitemp sensor for the bulb is bad sometimes its cheaper to replace a rear projector tv then to repair a bulb on some models can run $600.00
Aug 23, 2013 | Toshiba 50A62 50" Rear Projection...
Toshiba model 50a62 had no color just black and white
Check its chroma processor section circuit.
Apr 30, 2013 | Televison & Video
Where is the remote sensor for the Toshiba 50A62?
Hello
Remote sensor is an internal component, and can be locakted just beneath the remote sensor window at the front panel of all TVs. It is usually a three terminal black colure component, diretly soldered to a circuit board. In some sets, it will be on a seperate circuit board, and in some otheres it will be soldered to the front panel control switches board. OK.
Mar 06, 2011 | Toshiba 50A62 50" Rear Projection...
Toshiba Model No. 50A62 When the set is first turned on, the screen is black with white snow and no sound. After 5 minutes, we get a normal picture. I get the same results, everytime it is turned off and...
I hope this helps.
Thanks
asnowman
Sep 21, 2009 | Toshiba 50H82 50" Rear Projection...
Blue doesn't work
Jan 08, 2009 | Toshiba TP50G60 50" Rear Projection...
Toshiba 50A62 blurred screen
does it look like these?
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 03, 2007 | Toshiba 50A62 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
