Question about Health & Beauty
Us balance us-50xr
It wont calibrate. when it turns on it shows 7.00 and I cant get it to zero out or calibrate.
Avery 1770, keeps beeping and number one keeps repeating as if someone is constantly pressing number one.then it could stop for six weeks then just start again.is ther anyway of stopping this?
I think this has been answered very fully by Dazzy B - his answer is below :-
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press and hold the micro switch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Oct 13, 2016 | Watches
Zero point calibration
Performing Zero Point Calibration using Diagnostic Computer.
The ECM memory should have been reset due to which the calibration of the accelerator pedal has been erased. Use a scan tool and calibrate deceleration sensor.
You can do the calibration by clicking Engine and ECT > > special function > > and then click "deceleration 0 point calibration" while you do that make sure that coolant temperature is 80 degrees Celcius, IGN switch is "ON" , engine "OFF" and your gear shift is on "P
Performing Zero Point Calibration WITHOUT using Diagnostic Computer
1. If the vehicle is equipped with A/T, ensure that the shift lever is in the "P" range and the parking brake is applied. If the vehicle is equipped with a M/T, ensure that the parking brake is applied.
2. Turn the ignition switch ON.
3. Using a paper clip or auto wire, repeat a cycle of short and open between terminals Ts and CG (Pin 12 and pin 4) of DLC3,(16 pin Data Link Connector located under the steering wheel side) 5times within 8 seconds.
4. Verify that the VSC indicator light is lit indicating the recorded zero point is erased.
5. Turn the ignition switch OFF.
6. Be sure the terminals Ts and CG of DLC3 are disconnected.
7. Turn the ignition switch ON.
8. Check that the VSC warning light goes off about 15 seconds after the ignition switch is turned ON.
9. After ensuring that the VSC warning light remains OFF for 2 seconds, turn the ignition switch OFF.
10. Connect terminals Ts and CG of DLC3 using paper clip or auto wire.
11. Turn the ignition switch ON.
12. After turning the ignition switch ON, check that the VSC warning light is lit for about 4 seconds and then starts quick blinking at 0.13 second intervals.
13. After ensuring the blinking of the VSC warning light for 2 seconds, turn the ignition switch OFF.
14. Remove the clip from terminals Ts and CG of DLC3.
15. Drive the vehicle for at least 5 minutes to confirm Zero Point Calibration is complete.
Thank you for visiting Fixya.
Aug 08, 2013 | Toyota Corolla Cars & Trucks
Can not get the incline to go all the way down,so I can fold it up
please go to the HOOD motor, and see the instruction for to RUN the software calibration for easy diagnose, troubleshooting, and fix it.
Sep 03, 2012 | New Balance Balance 1500 Treadmill
Avery H500/L200 Avery Weighing Scales For ForkliftTruck When scales powered on, screen displaying ''balance limit''. Scales will not function.
The zero capture is out of the 2percent tolerance so the cell is either faulty or requires zeroing. Open the unit and press the micros itch on the left of the board. The display flashes s. Press the zero key to change to flashing E. Press store to scroll to zero balance. Press semi auto tare. This captures zero without clearing the span calibration. The display will scroll around for a short period when complete press store.. Release the micro switch and scale will go thru warm up routine then display zero. Hope this helps, regs Darren.
Sep 28, 2011 | Health & Beauty
I replaced my battery and now I have a engiine light vsc light and 4wd light warning no throttle response and problem code p2118. checked all fuses all good. any ideas please help.
Tests/Procedures: 1. Perform zero point calibration of the yaw rate sensor/deceleration sensor. Potential Causes: Deceleration Sensor Zero Point Calibration
Tech Tips: Code C1336 is for Deceleration sensor zero point calibration undone. To perform zero point calibration, have the steering wheel in the straight ahead position and have the vehicle on a level surface within an inclination of 1%. Turn the ignition switch OFF. Use a jumper wire and connect terminals TS and CG of Data Link Connector (DLC) 3. Turn the ignition switch ON. Keep the vehicle stationary on a level surface for 2 seconds or more and verify that the VSC warning light blinks. Diagnostic Codes: C1336
Jan 24, 2011 | 2006 Toyota RAV4
Board wont calibrate
ifif your talking about the Wii and the balance board wont calabrate, you need to sync the balance board to the Wii by removing the battery lid and pressing the sync button. The board power button lights should blink for about 20 seconds. At this time, you open up the SD card lid on the council and press the sync button on there. The board will stop blinking when it is synced. After this, insert a video game that requires a balance board. You go to "controls" on the main menu and set it to Wii balance board mode. after this you press "ok" and it should tell you which way to set the board. After this, you go to Wii home by pressing the button that looks like a house in the middle of the remote. Then, you hold down the power button on the board and wait until player 4 shows life. (player 4 is the board.) The board should work now.
Jan 09, 2011 | Video Game Consoles & Games
Most of my ds lite touch screen is not responding
try getting to the calibration menu with the buttons and calibrate if u can if not send it in to nintendo for repairs
Sep 21, 2009 | Nintendo DS Lite Console
Touchscreen wont work
touch screen wont work,
what is it doing ?
if the touch screen feature is not working, and you cant navigate to the calibrate screen, push the off switch but release right away, so it dont turn off, it will bring up the calibrate operation, its a default to access the calibrate when you cant navigate the screens.
Aug 14, 2009 | Sylvania SMPK8854 Digital Media Player
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
Volume wont work
In the menu for initial setup look for a setting for center channel and turn it off. If it is on you will have no sound because it turns the TV speaker into the center speaker for a surrond sound receiver input.
Jun 27, 2008 | JVC AV-48P775 48" HDTV
Health & Beauty Logo
16 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
